leyinlewis的个人空间 https://bbsx.21ic.com/?95532 [收藏] [复制] [RSS]
日志
移远 高通平台 NBioT CatM eMTC 物联网模块 规格
已有 1253 次阅读2017-8-20 13:57 |系统分类:通信网络| 移远, 高通平台, NBioT, CatM, eMTC
技术详情咨询QQ 11404232
Variant for North America    BG96-NA
Cat.M1/Cat.NB1:
LTE FDD: B2/B4/B12/B13主
Variant for the Global     BG96
Cat.M1/Cat.NB1:
LTE FDD: B1/B2/B3/B4/B5/B8/B12/B13/B18/B19/B20/B26/B28
LTE TDD: B39 (For Cat.M1 Only)
EGPRS:
850/900/1800/1900MHz
Data
Cat.M1:
Max. 375Kbps (DL), Max. 375Kbps (UL)
Cat.NB1:
Max. 32Kbps (DL), Max. 70Kbps (UL)
GPRS:
Max. 85.6Kbps (DL), Max. 85.6Kbps (UL)
EDGE:
Max. 236.8Kbps (DL), Max. 236.8Kbps (UL)
Voice
VoLTE (For Cat. M1 Only. Support Realtek ALC
5616 Codec by Default Firmware)
SMS
Point-to-point MO and MT
SMS Cell Broadcast
Text and PDU Mode
Interfaces
USB 2.0 with High Speed up to 480Mbps
UART × 3
PCM
ADC × 2 (15 bits)
GPIO × 2 (I2C and UART3 can be re-confgured as
extra 4 GPIOs)
(U)SIM Card Interface
NETLIGHT for Network Status Indicaton
STATUS for Power ON/OFF Indicaton
Main and GNSS Antenna Interfaces
GNSS (Optonal):
GPS, GLONASS, BeiDou/Compass, Galileo, QZSS
Firmware Upgrade:
via USB interface
DFOTA:
Delta Firmware Upgrade Over the Air
Output Power:
Max. Power: 23dBm
Consumpton (Typical):
LTE Cat.M1 Mode:
Power Saving Mode: 10.4uA
Standby State: 1.99mA @DRX=1.28s
LTE Connected Mode:
124mA @0dBm
136mA @12dBm
190mA @23dBm
LTE Cat. NB1 Mode:
Power Saving Mode: 9.8uA
Standby State: 2.77mA @e-I-DRX=20.48s
LTE Connected Mode: TBD
Sensitvity:
-107dBm @Cat.M1, 1.4MHz Bandwidth, CE
Mode A
-117dBm @Cat.NB1, CE Level 0
General Features
3GPP E-UTRA Release 13
Temperature Range: -40°C ~ +85°C
Dimensions: 22.5mm × 26.5mm × 2.3mm
Approx. 3.1g
LGA Package
Supply Voltage: 3.3V~4.3V, 3.8V Typ.
3GPP TS27.007, 3GPP TS 27.005 and Quectel
Enhanced AT Commands
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
