Wave Magic https://bbsx.21ic.com/?87260 [收藏] [复制] [RSS]
日志
Concept HDL-Multidesign in a Project
已有 1016 次阅读2005-11-1 13:25 |个人分类:EDA专题|系统分类:EDA/PLD
You can add multidesign for a project.
Procedural: Create new project just like normal, create first new design named: SFxxAA1_sd, then use the same project name to create the second design named: SFxxAA1_ufd.
Problem: Sometimes, you can process backannotate operation successfully, but the pin number doesn't appear. That is because in the multidesign project, Concept HDL can only back annotate the current working design. You can set the working design in Project Manager->Tools-> Setup->Design
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
