[研电赛技术支持]
GD32L233 standby低功耗唤醒
161|0
1.单片机选型
GD32L233KBQ6
PA0低电平mcu进入standby休眠态,检测到PA0高电平则唤醒,软复位重新执行main函数。
2.main.c
#include "gd32l23x.h"
#include "systick.h"
#include <stdio.h>
#include "main.h"
#include "gd32l23x_eval.h"
#include "gd32l23x_i2c.h"
void delay(volatile uint32_t t) {
    while(t--);
void usart0_gpio_config(void)
    rcu_periph_clock_enable(RCU_GPIOA);
    gpio_af_set(GPIOA, GPIO_AF_7, GPIO_PIN_9);    // PA9 -> USART0_TX
    gpio_af_set(GPIOA, GPIO_AF_7, GPIO_PIN_10);   // PA10 -> USART0_RX
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9 | GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_9 | GPIO_PIN_10);
void usart0_config(void)
    rcu_periph_clock_enable(RCU_USART0);
    usart_deinit(USART0); // 复位
    usart_baudrate_set(USART0, 115200U);
    usart_word_length_set(USART0, USART_WL_8BIT);
    usart_stop_bit_set(USART0, USART_STB_1BIT);
    usart_parity_config(USART0, USART_PM_NONE);
    usart_hardware_flow_rts_config(USART0, USART_RTS_DISABLE);
    usart_hardware_flow_cts_config(USART0, USART_CTS_DISABLE);
    usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
                usart_receive_config(USART0, USART_RECEIVE_ENABLE);
    usart_enable(USART0);
void wakeup_pin_init(void)
    // 1. 启用 PMU 时钟
    rcu_periph_clock_enable(RCU_PMU);
    // 2. 清除之前的 STANDBY / WUF 标志
    pmu_flag_clear(PMU_FLAG_STANDBY);
    pmu_flag_clear(PMU_FLAG_WAKEUP);
    // 3. 允许 WKUP0(PA0) 上升沿唤醒
    pmu_wakeup_pin_enable(PMU_WAKEUP_PIN0);
void enter_standby_mode(void)
    // 进入 STANDBY 模式
    pmu_to_standbymode();
int fputc(int ch, FILE *f)
    usart_data_transmit(USART0, (uint8_t)ch);
    while (usart_flag_get(USART0, USART_FLAG_TBE) == RESET);
    return ch;
int main(void)
    SystemInit();
    systick_config();
    usart0_gpio_config();
    usart0_config();
        printf("MCU started!\r\n");
    // 如果是来自 Standby 模式唤醒
    if (pmu_flag_get(PMU_FLAG_STANDBY)) {
        printf("Woke up from Standby mode!\r\n");
    // 如果没有插入外设(PA0 == 0) → 进入 Standby
    if (gpio_input_bit_get(GPIOA, GPIO_PIN_0) == RESET) {
        printf("No device detected. Entering Standby...\r\n");
        delay_1ms(10);
        wakeup_pin_init();        // 初始化唤醒引脚
        pmu_to_standbymode();     // 无参数,直接调用
    // 正常运行逻辑
    printf("Device detected. Running normally...\r\n");
    while (1){
                // 串口回显
                if (usart_flag_get(USART0, USART_FLAG_RBNE) != RESET) {
            uint8_t ch = usart_data_receive(USART0);
            usart_data_transmit(USART0, ch);
3.实现效果
起始PA0低电平,pmu_to_standbymode()进入休眠态,无法实现while循环中的串口回显功能。
PA0给高电平后,mcu唤醒,串口回显成功。
原文链接:https://blog.csdn.net/m0_60013390/article/details/149113289
