[APM32F0]
APM32F003F6P6芯片,想要ADC采集5个引脚的电压,实际只能读取3个.
231|8
APM32F003F6P6芯片,ADC采集五个引脚的电压,实际只能读取到3个,原因不明.
void ADC_Calibration(void){
    uint8_t i;
    int8_t offset = 0;
    uint16_t adcData = 0;
    ADC_SetOffset(0);
    ADC_EnableCompensation();
    ADC_ClearStatusFlag(ADC_FLAG_CC);
    ADC_Enable();
    ADC_StartConversion();
    for(i = 0; i < 10; i++) {
        while(ADC_ReadStatusFlag(ADC_FLAG_CC) == RESET);
    ADC_Disable();
    adcData = ADC_ReadData();
    offset = (int8_t)(0x800 - adcData);
    ADC_SetOffset(offset);
    ADC_DisableCompensation();
void ADC_ContinuousScanInit(void){
    ADC_Config_T adcConfig;
    GPIO_Config_T gpioConfig;
    gpioConfig.intEn = GPIO_EINT_DISABLE;
    gpioConfig.mode = GPIO_MODE_IN_FLOATING;
    gpioConfig.pin = GPIO_PIN_5 | GPIO_PIN_6 | GPIO_PIN_4| GPIO_PIN_3;    //AIN0:PC5, AIN1:PC6,AIN2:PC4, AIN3:PD2--烧录口,AIN4:PD3,AIN5:PD5,AIN6:PD6,AIN7:PC3
    GPIO_Config(GPIOC, &gpioConfig);
    gpioConfig.pin = GPIO_PIN_3;
    GPIO_Config(GPIOD, &gpioConfig);
    ADC_SetMode(ADC_MODE_SINGLE_END);
    ADC_ConfigStructInit(&adcConfig);
    adcConfig.div = ADC_DIV_4;
    adcConfig.convMode = ADC_CONV_MODE_CONTINUOUS;
    adcConfig.scanMode = ADC_SCAN_MODE_ENABLE;
    adcConfig.interrupt = ADC_INT_CC;
    adcConfig.channel = ADC_CHANNEL_2; //ADC_CHANNEL_0  ADC_CHANNEL_1 ADC_CHANNEL_2
    ADC_Config(&adcConfig);
    ADC_Calibration();
    ADC_Enable();
void ADC_PollForConversion(void){
    uint16_t voltage = 0;
    uint16_t adcArray[10] = {0};
    uint8_t bufferIndex;
    SEGGER_RTT_printf(0, "===========ADC_PollForConversion===2222=======\r\n");
    if(ADC_ReadStatusFlag(ADC_FLAG_CC) == SET){
        // SEGGER_RTT_printf(0, "===========ADC_PollForConversion===55555=======\r\n");
        for(bufferIndex = 0; bufferIndex < 8; bufferIndex++){
            adcArray[bufferIndex] = ADC_ReadBufferData((ADC_BUFFER_IDX_T)(bufferIndex));
            voltage = (adcArray[bufferIndex] * 3300) / 4095;
            // printf("ADC Channel %d Value:%d\r\n", bufferIndex, voltage);
            SEGGER_RTT_printf(0, "===========ADC_PollForConversion=1111==========ADC,  Channel:%d,  vol:%d \r\n",bufferIndex, voltage);
Alden| | 2025-6-27 09:59 | 只看该作者
003的ADC连续扫描模式是只能固定从0通道开始扫到n通道,如果用4个ADC通道最好用0,1,2,3的顺序通道,PC3是通道7,用的话之间几个引脚会受影响。把adcConfig.channel = ADC_CHANNEL_2;改成ADC_CHANNEL_3,bufferIndex 的数组加大就可以了
Gfan 2025-6-27 10:56 回复TA
@yuanliangbeyond :数据手册里面有的噢
yuanliangbeyond 2025-6-27 10:27 回复TA
我需要采集ADC的总共有5个引脚,分别是"PC3,PC4,PC5,PC6,PD3", 请问, 我应该如何写程序呢?
yuanliangbeyond 2025-6-27 10:20 回复TA
你上面说"PC3是通道7", 请问, 这个从哪里查到的呢,告诉我吧, 我也去查一下手册.
yuanliangbeyond 2025-6-27 10:18 回复TA
好像不行, 改成ADC_CHANNEL_3以后, 单片机能正常运行程序, 但是烧录口好像被占用了一样, 无法再次烧录程序. 只能复位恢复出厂设置.
yuanliangbeyond|  楼主 | 2025-6-27 10:26 | 只看该作者
真的问题不大| | 2025-6-27 10:59 | 只看该作者
翻了下他们的手册,大概数据手册的第8、9页的位置,PC3引脚可以被配置用作通道7
SirenSong| | 2025-6-27 15:18 | 只看该作者
你看下是adc的第几个通道,然后照着其他几个通道的样子去搞不就好了
