[PSOC™]
雷达和声纳通过发射信号,接收反射波来跟踪移动物体,类似用声波或无线电波“探路”...
277|4
丙丁先生|  楼主 | 2025-6-22 07:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[color=rgba(0, 0, 0, 0.9)]以下是一个使用Python模拟雷达/声纳基本工作原理的示例代码,结合了信号发射、目标反射和回波处理的核心算法:
import numpy as npimport matplotlib.pyplot  as pltfrom scipy.signal  import chirp, correlate  def radar_simulation():    # ======== 参数设置 ========    c = 3e8  # 光速 (m/s) - 声纳需改为声速(1500m/s)    fs = 2e6  # 采样率 (2MHz)    duration = 10e-6  # 信号持续时间 (10μs)    bandwidth = 500e3  # 扫频带宽 (500kHz)    target_range = 1200  # 目标距离 (m)    target_rcs = 5.0    # 目标雷达散射截面积     # ======== 生成发射信号(线性调频脉冲) ========    t = np.arange(0,  duration, 1/fs)    tx_signal = chirp(t, f0=0, t1=duration, f1=bandwidth, phi=-90)     # ======== 计算时间延迟 ========    time_delay = 2 * target_range / c  # 往返时间    delay_samples = int(time_delay * fs)     # ======== 生成接收信号 ========    # 添加延迟和衰减     rx_signal = np.zeros_like(tx_signal)     rx_signal[delay_samples:delay_samples+len(tx_signal)] = tx_signal[:-delay_samples] * target_rcs        # 添加高斯白噪声     noise = 0.1 * np.random.randn(len(tx_signal))     rx_signal += noise      # ======== 信号处理(脉冲压缩) ========    # 匹配滤波器(发射信号的共轭翻转)    filter_kernel = np.conj(tx_signal[::-1])     compressed = correlate(rx_signal, filter_kernel, mode='same')    compressed = np.abs(compressed)   # 取幅度      # ======== 距离计算 ========    peak_index = np.argmax(compressed)     calculated_range = (peak_index / fs) * c / 2     # ======== 可视化结果 ========    plt.figure(figsize=(12,  10))        plt.subplot(3,  1, 1)    plt.plot(t*1e6,  tx_signal)    plt.title(' 发射信号 (Chirp脉冲)')    plt.xlabel(' 时间 (μs)')    plt.ylabel(' 幅度')    plt.grid(True)      plt.subplot(3,  1, 2)    plt.plot(t*1e6,  rx_signal)    plt.title(' 接收信号 (含噪声和延迟)')    plt.xlabel(' 时间 (μs)')    plt.ylabel(' 幅度')    plt.grid(True)      plt.subplot(3,  1, 3)    range_axis = np.linspace(0,  len(compressed)*c/(2*fs), len(compressed))    plt.plot(range_axis,  compressed)    plt.plot(calculated_range,  np.max(compressed),  'ro')    plt.annotate(f' 检测目标: {calculated_range:.1f}m',                  xy=(calculated_range, np.max(compressed)),                  xytext=(calculated_range+200, 0.8*np.max(compressed)),                  arrowprops=dict(facecolor='red', shrink=0.05))    plt.title(' 脉冲压缩结果 (距离门)')    plt.xlabel(' 距离 (m)')    plt.ylabel(' 相关值')    plt.grid(True)      plt.tight_layout()     plt.show()  if __name__ == "__main__":    radar_simulation()
算法说明:
  • 信号生成:
    • 使用线性调频(Chirp)信号作为发射波形
    • 频率从0Hz扫到500kHz(带宽越大,距离分辨率越高)
  • 目标反射模型:
    • 根据目标距离计算信号往返延迟
    • 添加雷达散射截面积(RCS)模拟目标反射特性
    • 添加高斯白噪声模拟环境噪声
  • 核心处理(脉冲压缩):
    # 匹配滤波器实现 filter_kernel = np.conj(tx_signal[::-1])   # 发射信号的共轭时间反转 compressed = correlate(rx_signal, filter_kernel, mode='same')
    • 通过互相关实现匹配滤波
    • 显著提高信噪比和距离分辨率
  • 距离检测:
    • 在压缩信号中找到峰值位置
    • 根据时延计算目标距离:距离 = (时间延迟 × 光速) / 2
扩展功能:
  • 多目标检测:
    # 在压缩信号中查找多个峰值peaks, _ = find_peaks(compressed, height=threshold)for peak in peaks:    range = (peak / fs) * c / 2
  • 多普勒测速:
    # 需要多个脉冲的相位变化 phase_shift = np.angle(compressed[peak_index]) velocity = (phase_shift * c) / (4 * np.pi  * pulse_repetition_frequency)
  • 声纳适配:
    c = 1500  # 声速 (m/s)# 添加海洋环境噪声模型
典型应用场景:
  • 雷达系统:自动驾驶(毫米波雷达)、气象雷达
  • 声纳系统:潜艇探测、鱼群探测
  • 医学成像:超声波检查
  • 地质勘探:地震波探测
[color=rgba(0, 0, 0, 0.9)]此代码展示了雷达/声纳最基本的"发射-接收-处理"流程,实际系统还需考虑:
  • 多径干扰消除
  • 杂波抑制(CFAR检测)
  • 运动补偿
  • 阵列信号处理(波束形成)
[color=rgba(0, 0, 0, 0.9)]可根据具体需求扩展此基础框架,例如添加目标运动模型、环境衰减模型或多传感器融合算法。
huangcunxiake| | 2025-6-27 12:52 | 只看该作者
有没有办法做个简单的玩玩。
丙丁先生|  楼主 | 2025-6-27 13:40 | 只看该作者
huangcunxiake 发表于 2025-6-27 12:52
有没有办法做个简单的玩玩。
记的  ICEASY 有激光雷达,开源的硬件,还没有测,因为要焊插针,
中国龙芯CDX| | 2025-6-27 22:17 | 只看该作者
可以了解一下后期备用
丙丁先生|  楼主 | 2025-6-28 07:07 | 只看该作者
中国龙芯CDX 发表于 2025-6-27 22:17
可以了解一下后期备用
排版有点乱了,这方面值得研究。
