GD32E230F4P6串口发送中断进几次不能进入了
400|8
void USART0_Init(void)
                rcu_periph_clock_enable(RCU_USART0);
    /* configure USART Tx as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_9);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_9);
    /* configure USART Rx as alternate function push-pull */
    gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_10);
    gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_10);
          // PA10 - USART_RX (浮空输入)
    //gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_10);
            /* connect port to USARTx_Tx */
    gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_9);
    /* connect port to USARTx_Rx */
    gpio_af_set(GPIOA, GPIO_AF_1, GPIO_PIN_10);
                usart_deinit(USART0);
    usart_baudrate_set(USART0, 115200U);
                usart_word_length_set(USART0, USART_WL_8BIT); // 8位数据
    usart_stop_bit_set(USART0, USART_STB_1BIT); // 1位停止位
    usart_parity_config(USART0, USART_PM_NONE); // 无校验
    usart_receive_config(USART0, USART_RECEIVE_ENABLE);
    usart_transmit_config(USART0, USART_TRANSMIT_ENABLE);
                usart_interrupt_enable(USART0, USART_INT_RBNE); // 使能USART0接收中断
    nvic_irq_enable(USART0_IRQn, 0);
                usart_enable(USART0);
void USART0_IRQHandler(void)
        uint8_t ucChar;
        // 检查是否是接收中断
        if(usart_interrupt_flag_get(USART0, USART_INT_FLAG_RBNE) != RESET)
        // 读取接收到的数据
                ucChar = usart_data_receive(USART0);
                ms_comm.start_end = (ms_comm.start_end << 8) | ucChar;
                if (ms_comm.start_end == MasterStartRx)
                        ms_comm.rx_start_ok = 1;
                        ms_comm.rx_index = 4;
                        ms_comm.rx_len = 12;
                else if (ms_comm.rx_start_ok == 1)
                        ms_comm.rx[ms_comm.rx_index] = ucChar;
                        ms_comm.rx_index++;
                        if (MsStartEnd16_t[0] == MsEnd)
                                if (ms_comm.rx_index == ms_comm.rx_len)
                                        ms_comm.rx_start_ok = 0;
                                        Ms_Decode();
                        if (ms_comm.rx_index >= sizeof (ms_cmd_t))
                        //usart_interrupt_flag_clear(USART0,USART_INT_FLAG_RBNE);
        // 检查是否是发送中断(如果启用了发送中断)
        if (usart_interrupt_flag_get(USART0, USART_INT_FLAG_TC) != RESET)
                if (ms_comm.tx_index < ms_comm.tx_len)
                        // Ms_SendByte(MsTxBuf[ms_comm.TxIndex++]);
                                usart_data_transmit(USART0, MsTxBuf[ms_comm.tx_index++]);
                else
                                Clr_Ms_INT_TC;//关闭中断
                                ms_comm.tx_len = 0;
                                ms_comm.wait_time = 10;
                // LCDm_CTL_L;
cr315| | 2025-6-24 16:59 | 只看该作者
中断标志未正确清除?
elephant00| | 2025-6-24 16:59 | 只看该作者
如果发送缓冲区的数据在中断服务函数中被错误地处理,或者没有及时更新发送指针,可能会导致后续数据无法正确发送,从而影响中断的再次触发。
flycamelaaa| | 2025-6-24 17:00 | 只看该作者
发送寄存器未清空、发送线路故障等,导致中断无法正常触发。
powerantone| | 2025-6-24 17:00 | 只看该作者
如果系统中存在其他中断,且优先级设置不当,可能会导致串口发送中断被其他中断抢占或阻塞。
stormwind123| | 2025-6-24 17:00 | 只看该作者
在中断服务函数或主程序中,可能存在逻辑错误,导致中断无法再次触发。
tonykuai| | 2025-6-24 19:21 | 只看该作者
看你的程序,是没有清除TC标志位吧。
jcky001| | 2025-6-24 20:59 | 只看该作者
在中断服务函数中,如果没有正确清除发送完成中断标志,可能会导致中断无法再次触发。
probedog| | 2025-6-24 22:01 | 只看该作者
检查并清除中断标志。
