[APM32E0]
APM32E030R Mirco-EVB开发板驱动flash
586|7
很荣幸在《@开发者们!100+开发板免费领,上海慕尼黑 电子展见》活动中获得一个块APM32E030R开发板。
此次,我首次通过回帖的方式收获幸运,这究竟是幸运之神偶然的恩赐,还是我本就是幸运之子,此刻不过是命运轨迹中一次恰到好处的回归?
不管怎样,感谢极海半导体,感谢21IC。
下面是APM32E030R开发板:
原理图:
可以看到原理图上留有FLASH的扩展(开发板上这部分没有焊接)。
所以我在开发板上补上了一个W25Q80并进行了驱动
1、SPI初始化
对时钟、引脚、SPI等进行初始化
void SPI_InitForFlash(void)
    SPI_Config_T spiConfig;
    GPIO_Config_T gpioConfig;
    // 使能时钟
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_SPI1);
    RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_GPIOA);
    RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_SYSCFG);
            /* Config alter function*/
    GPIO_ConfigPinAF(GPIOA, GPIO_PIN_SOURCE_5, GPIO_AF_PIN0);
    GPIO_ConfigPinAF(GPIOA, GPIO_PIN_SOURCE_6, GPIO_AF_PIN0);
    GPIO_ConfigPinAF(GPIOA, GPIO_PIN_SOURCE_7, GPIO_AF_PIN0);
    // 配置SPI引脚
    // PA5 - SCK, PA6 - MISO, PA7 - MOSI
    gpioConfig.pin = GPIO_PIN_5 | GPIO_PIN_7;
    gpioConfig.mode = GPIO_MODE_AF;
    gpioConfig.speed = GPIO_SPEED_50MHz;
    gpioConfig.outtype = GPIO_OUT_TYPE_PP;
    gpioConfig.pupd = GPIO_PUPD_PU;
    GPIO_Config(GPIOA, &gpioConfig);
    // 配置CS引脚(假设使用PA4)
    gpioConfig.pin = GPIO_PIN_4;
    gpioConfig.mode = GPIO_MODE_OUT;
    GPIO_SetBit(GPIOA, GPIO_PIN_4); // 初始高电平(不选中)
                /* config PIN_6  MISO*/
    gpioConfig.pin = GPIO_PIN_6;
     /* SPI RESET*/
    SPI_Reset(SPI1);
    SPI_ConfigStructInit(&spiConfig);
    /* SPI configuration*/
    /* Set Clock polarity is Low, but Slave is High*/
    spiConfig.polarity = SPI_CLKPOL_LOW;
    /* select master mode*/
    spiConfig.mode = SPI_MODE_MASTER;
    /* SPI Clock Phase is 1EDGE, but Slave is 1EDGE*/
    spiConfig.phase = SPI_CLKPHA_1EDGE;
    /* Enable Software slave control */
    spiConfig.slaveSelect = SPI_SSC_ENABLE;
    /* Set SPI BaudRate divider*/
    spiConfig.baudrateDiv = SPI_BAUDRATE_DIV_256;
    /* SPI data length*/
    spiConfig.length = SPI_DATA_LENGTH_8B;
    /* Set internal slave*/
    SPI_EnableInternalSlave(SPI1);
    SPI_Config(SPI1, &spiConfig);
    SPI_ConfigFIFOThreshold(SPI1, SPI_RXFIFO_QUARTER);
    SPI_Enable(SPI1);
2、片选控制
// 片选控制
static void FLASH_CS_Low(void) {
    GPIO_ClearBit(GPIOA, GPIO_PIN_4);
static void FLASH_CS_High(void) {
3、发送单字节
// SPI发送接收单字节
static uint8_t SPI_TransmitReceiveByte(uint8_t data)
    while(SPI_ReadStatusFlag(SPI1, SPI_FLAG_TXBE) == RESET);
    SPI_TxData8(SPI1, data);
    while(SPI_ReadStatusFlag(SPI1, SPI_FLAG_RXBNE) == RESET);
    return SPI_RxData8(SPI1);
4、写使能
static void FLASH_WriteEnable(void)
    FLASH_CS_Low();
    SPI_TransmitReceiveByte(0x06); // 写使能命令
    FLASH_CS_High();
5、读取数据
void FLASH_ReadData(uint32_t addr, uint8_t *pData, uint32_t size)
    FLASH_CS_Low();
    SPI_TransmitReceiveByte(0x03); // 读数据命令
    // 发送地址(24位)
    SPI_TransmitReceiveByte((addr >> 16) & 0xFF);
    SPI_TransmitReceiveByte((addr >> 8) & 0xFF);
    SPI_TransmitReceiveByte(addr & 0xFF);
    // 读取数据
    while(size--) {
        *pData++ = SPI_TransmitReceiveByte(0xFF);
    FLASH_CS_High();
6、页编程(写入数据,通常256字节一页)
void FLASH_PageProgram(uint32_t addr, uint8_t *pData, uint32_t size)
    FLASH_WriteEnable();
    FLASH_WaitForReady();
    FLASH_CS_Low();
    SPI_TransmitReceiveByte(0x02); // 页编程命令
    // 发送地址
    // 写入数据
    while(size--) {
        SPI_TransmitReceiveByte(*pData++);
    FLASH_CS_High();
    FLASH_WaitForReady(); // 等待写入完成
7、扇区擦除(通常4KB)
void FLASH_SectorErase(uint32_t addr)
    FLASH_CS_Low();
    SPI_TransmitReceiveByte(0x20); // 扇区擦除命令
    // 发送地址
    FLASH_CS_High();
    FLASH_WaitForReady(); // 等待擦除完成
8、等待FLASH就绪
static void FLASH_WaitForReady(void)
    uint8_t status;
    FLASH_CS_Low();
    SPI_TransmitReceiveByte(0x05); // 读状态寄存器命令
    do {
        status = SPI_TransmitReceiveByte(0xFF);
    } while(status & 0x01); // 检查BUSY位
    FLASH_CS_High();
9、读取FLASH ID (用于测试通信)
uint32_t FLASH_ReadID(void)
    uint32_t id = 0;
    FLASH_CS_Low();
    SPI_TransmitReceiveByte(0x9F); // 读ID命令
    id |= (SPI_TransmitReceiveByte(0xFF) << 16);
    id |= (SPI_TransmitReceiveByte(0xFF) << 8);
    id |= SPI_TransmitReceiveByte(0xFF);
    FLASH_CS_High();
    return id;
10、flash测试程序
void flash_test(void)
    uint8_t readBuffer[256];
    uint8_t writeBuffer[256];
    uint32_t flashID;
  // 读取FLASH ID
    flashID = FLASH_ReadID();
    printf("FLASH ID: 0x%06lX\n", (unsigned long)flashID);
// 准备测试数据
    for(int i = 0; i < 256; i++) {
        writeBuffer[i] = i;
    // 擦除扇区(假设擦除地址0x000000)
    FLASH_SectorErase(0x000000);
    // 写入数据
    FLASH_PageProgram(0x000000, writeBuffer, 256);
    // 读取验证
    FLASH_ReadData(0x000000, readBuffer, 256);
                        printf("0x%02X ",readBuffer[i] );
11、main函数
int main(void)
                APM_TINY_COMInit(COM1);
                // 初始化
    SPI_InitForFlash();
                printf("Flash demo program start\r\n");
                flash_test();
    while (1)
12、运行
可以看到已经读取到FLASH ID,并且读写测试输出符合预期
FrostShimmer| | 2025-7-3 19:36 | 只看该作者
楼主真棒!
好棒的技术分享
话说楼主的焊功厉害,焊完了,器件周围还是这么干净
pacer81| | 2025-7-4 05:18 | 只看该作者
这款产品SPI最高速率是18MHz,不知道有没有达到?另外18MHz是不是有点低了
Gfan| | 2025-7-4 10:00 | 只看该作者
主要还是看应用,APM32E030R所属的入门级、低成本Cortex-M0+微控制器领域,18MHz的SPI速率处于一个中等甚至偏上的水平。许多同类产品的SPI速率在几MHz到十几MHz之间。而且18MHz的SPI速率对于E030的目标应用领域(工业控制、消费电子、物联网节点等)来说并不算低,甚至可以说是一个不错的性能指标。它在性能和成本之间取得了很好的平衡。只有在与高端MCU或对数据传输率有极端要求的特定应用对比时,这个速率才会显得“低”的。
Gfan 2025-7-4 11:26 回复TA
@pacer81 :对的~这款开发板目前也在开放免费申请活动噢,有兴趣可以了解一下 https://bbs.21ic.com/icview-3461474-1-1.html
pacer81 2025-7-4 11:06 回复TA
明白了,性价比看起来不错,和主频应该也有些关系
天鹅绒之夜| | 2025-7-4 20:50 | 只看该作者
18MHz的SPI速率相当于4分频主频。
如果不使用DMA,是不是也跑不出来这个速率啊!
银河漫步| | 2025-7-5 20:49 | 只看该作者
SPI在使用的时候只支持8位模式吗?
