[资料分享]
RA4M2+GPIO操作
337|0
king86|  楼主 | 2025-6-1 00:56 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
RA4M2 GPIO操作指南
硬件准备
RA4M2开发板
LED灯(接于P400)
原理图:
生成代码
static void Task_LedRunning(void *pvParameters)
    (void)pvParameters;
    for (;;)
       R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_HIGH);
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_LOW);
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_02, BSP_IO_LEVEL_LOW);
        /* Delay for 200ms */
        vTaskDelay(pdMS_TO_TICKS(200));
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_04, BSP_IO_LEVEL_LOW);
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_04_PIN_05, BSP_IO_LEVEL_HIGH);
        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_02, BSP_IO_LEVEL_HIGH);
点亮结果:
