[DemoCode下载]
CM1003使用I2C/UART实现ISP
459|8
dongnanxibei|  楼主 | 2025-5-26 17:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ISP.rar (155.15 KB)
dongnanxibei|  楼主 | 2025-5-26 17:38 | 只看该作者
/* SPDX-License-Identifier: Apache-2.0        */
/* Copyright(c) 2024 Nuvoton Technology Corp. All rights reserved.                                         */
#include "numicro_8051.h"
#include "isp_uart0.h"
#if defined __C51__
xdata uint16_t start_address,u16_addr;
#elif defined __ICC8051__
__xdata uint16_t start_address,u16_addr;
#elif defined __SDCC__
#endif
uint8_t  vo8temp;
uint16_t vo16temp;
uint32_t vo32temp;
  * [url=home.php?mod=space&uid=247401]@brief[/url]     UART interrupt subroutine.
  * @param[in] None.
  * [url=home.php?mod=space&uid=266161]@return[/url]    None.
#if defined __C51__
void Serial_ISR(void) interrupt 4
#pragma vector=0x23
__interrupt void UART0_ISR(void)
void Serial_ISR(void) __interrupt (4)
#endif
    uint8_t  votemp;
    if (RI == 1)
        votemp = SBUF;
        uart_rcvbuf[bufhead++] =  votemp;
        clr_SCON_RI;                                         // Clear RI (Receive Interrupt).
    if (TI == 1)
        clr_SCON_TI;                                         // Clear TI (Transmit Interrupt).
    if (bufhead == 1)
        g_timer1Over = 0;
        g_timer1Counter = 90; //for check uart timeout using
    if (bufhead == 64)
        bUartDataReady = TRUE;
        g_timer1Counter = 0;
        g_timer1Over = 0;
        bufhead = 0;
  * @brief     Timer0 interrupt subroutine.
  * @param[in] None.
  * @return    None.
#if defined __C51__
void Timer0_ISR(void) interrupt 1
#pragma vector=0x0B
__interrupt void Timer0_ISR(void)
void Timer0_ISR(void) __interrupt (1)
#endif
    if (g_timer0Counter)
        g_timer0Counter--;
        if (!g_timer0Counter)
            g_timer0Over = 1;
    if (g_timer1Counter)
        g_timer1Counter--;
        if (!g_timer1Counter)
            g_timer1Over = 1;
  * @brief     Main loop.
  * @param[in] None.
  * @return    None.
void main (void)
    set_CHPCON_IAPEN;
    MODIFY_HIRC_24();
#ifdef  isp_with_wdt
    TA=0x55;TA=0xAA;WDCON=0x07;
#endif
//uart initial for ISP programmer GUI, always use 115200 baudrate
  UART0_ini_115200_24MHz();
  TM0_ini();
  g_timer0Over=0;
  g_timer0Counter=Timer0Out_Counter;
  g_programflag=0;
while(1)
        if(bUartDataReady == TRUE)
          EA=0; //DISABLE ALL INTERRUPT
          if(g_programflag==1)
            for(count=8;count<64;count++)
              IAPCN = BYTE_PROGRAM_AP;          //program byte
              IAPAL = flash_address&0xff;
              IAPAH = (flash_address>>8)&0xff;
              IAPFD=uart_rcvbuf[count];
#ifdef isp_with_wdt
              set_IAPTRG_IAPGO_WDCLR;
#else
              trig_IAPGO;
#endif
              IAPCN = BYTE_READ_AP;              //program byte verify
              vo8temp = uart_rcvbuf[count];
              if(IAPFD!=vo8temp)
              while(1);
              if (CHPCON==0x43)              //if error flag set, program error stop ISP
              while(1);
              g_totalchecksum += vo8temp;
              flash_address++;
              vo16temp = AP_size;
              if(flash_address==vo16temp)
                 g_programflag=0;
                 g_timer0Over =1;
                 goto END_2;
END_2:
            Package_checksum();
            uart_txbuf[8]=g_totalchecksum&0xff;
            uart_txbuf[9]=(g_totalchecksum>>8)&0xff;
            Send_64byte_To_UART0();
          switch(uart_rcvbuf[0])
            case CMD_CONNECT:
            case CMD_SYNC_PACKNO:
              Package_checksum();
              g_timer0Counter=0; //clear timer 0 for no reset
              g_timer0Over=0;
              break;
            case CMD_GET_FWVER:
              Package_checksum();
              uart_txbuf[8]=FW_VERSION;
              break;
            case CMD_RUN_APROM:
              goto _APROM;
              break;
            //please for ISP programmer GUI, ID always use following rule to transmit.
            case CMD_GET_DEVICEID:
              READ_ID();
              Package_checksum();
              uart_txbuf[8]=DID_lowB;
              uart_txbuf[9]=DID_highB;
              uart_txbuf[10]=PID_lowB;
              uart_txbuf[11]=PID_highB;
              break;
            case CMD_ERASE_ALL:
              set_IAPUEN_APUEN;
              IAPFD = 0xFF;          //Erase must set IAPFD = 0xFF
              IAPCN = PAGE_ERASE_AP;
              for(flash_address=0x0000;flash_address<APROM_SIZE/PAGE_SIZE;flash_address++)
                IAPAL = LOBYTE(flash_address*PAGE_SIZE);
                IAPAH = HIBYTE(flash_address*PAGE_SIZE);
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              Package_checksum();
              break;
            case CMD_READ_CONFIG:
              READ_CONFIG();
              Package_checksum();
              uart_txbuf[8]=CONF0;
              uart_txbuf[9]=CONF1;
              uart_txbuf[10]=CONF2;
              uart_txbuf[11]=0xff;
              uart_txbuf[12]=CONF4;
              uart_txbuf[13]=0xff;
              uart_txbuf[14]=0xff;
              uart_txbuf[15]=0xff;
            break;
            case CMD_UPDATE_CONFIG:
              recv_CONF0 = uart_rcvbuf[8];
              recv_CONF1 = uart_rcvbuf[9];
              recv_CONF2 = uart_rcvbuf[10];
              recv_CONF4 = uart_rcvbuf[12];
              set_IAPUEN_CFUEN;                  /*Erase CONFIG */
              IAPCN = PAGE_ERASE_CONFIG;
              IAPAL = 0x00;
              IAPAH = 0x00;
              IAPFD = 0xFF;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              IAPCN = BYTE_PROGRAM_CONFIG;        /*Program CONFIG*/
              IAPFD = recv_CONF0;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              IAPFD = recv_CONF1;
              IAPAL = 0x01;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              IAPAL = 0x02;
              IAPFD = recv_CONF2;
  #ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              IAPAL = 0x04;
              IAPFD = recv_CONF4;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              clr_IAPUEN_CFUEN;
              READ_CONFIG();                        /*Read new CONFIG*/
              Package_checksum();
              break;
            case CMD_UPDATE_APROM:
              set_IAPUEN_APUEN;
              start_address = 0;
              start_address = uart_rcvbuf[8];
              start_address |= ((uart_rcvbuf[9]<<8)&0xFF00);
              AP_size = 0;
              AP_size = uart_rcvbuf[12];
              vo8temp = uart_rcvbuf[13];
              AP_size |= ((vo8temp<<8)&0xFF00);
              u16_addr = start_address + AP_size;
              flash_address = (start_address&0xFF00);
              while(flash_address< u16_addr)
                IAPAL = LOBYTE(flash_address);
                IAPAH = HIBYTE(flash_address);
#ifdef isp_with_wdt
#else
                trig_IAPGO;
#endif
                flash_address += PAGE_SIZE;
              g_totalchecksum = 0;
              flash_address = start_address;
              g_programflag = 1;
              for(count=16;count<64;count++)
                IAPFD = uart_rcvbuf[count];
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
                trig_IAPGO;
                if(IAPFD!=vo8temp)
                while(1);
                while(1);
                flash_address++;
                vo16temp = AP_size;
                  g_programflag=0;
                   goto END_1;
END_1:
              Package_checksum();
              break;
          bUartDataReady = FALSE;
          bufhead = 0;
          EA=1;
      /*For connect timer out   */
      if(g_timer0Over==1)
        CALL_NOP;
        goto _APROM;
      /*for uart time out or buffer error  */
       if(g_timer1Over==1)
       if((bufhead<64)&&(bufhead>0)||(bufhead>64))
             bufhead=0;
_APROM:
    MODIFY_HIRC_16();
    clr_CHPCON_IAPEN;
    TA = 0xAA; TA = 0x55; CHPCON = 0x80;                   //software reset enable boot from APROM
    /* Trap the CPU */
    while(1);
dongnanxibei|  楼主 | 2025-5-26 17:39 | 只看该作者
#include "isp_i2c.h"
//#define   isp_with_wdt   /* if enable WDT function. Uncomment this line  */
  * @brief     Main loop.
  * @param[in] None.
  * @return    None.
void main (void)
    uint8_t   vo8temp;
    uint16_t  vo16temp;
    bI2CDataReady=0;
    set_CHPCON_IAPEN;
    Init_I2C();
    TM0_ini();
    g_timer0Over=0;
    g_timer0Counter=5000;
    g_progarmflag=0;
while(1)
        //if(bUartDataReady == TRUE)
        if(bI2CDataReady == TRUE)
          EA=0; /* Disable all interrupt */
          if(g_progarmflag==1)
              IAPFD=rx_buf[count];
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              set_IAPTRG_IAPGO;
              vo8temp = rx_buf[count];
              if(IAPFD!=vo8temp)
              while(1);
              while(1);
              flash_address++;
              vo16temp = AP_size;
                g_progarmflag=0;
                                g_timer0Over =1;
                 goto END_2;
END_2:
            Package_checksum();
            tx_buf[8]=g_totalchecksum&0xff;
            tx_buf[9]=(g_totalchecksum>>8)&0xff;
            bISPDataReady = 1;
          switch(rx_buf[0])
            case CMD_CONNECT:
              Package_checksum();
              bISPDataReady = 1;
              g_timer0Over=0;
            break;
            case CMD_GET_FWVER:
              Package_checksum();
              tx_buf[8]=FW_VERSION;
              bISPDataReady = 1;
            break;
            case CMD_RUN_APROM:
              goto _APROM;
            break;
              READ_ID();
              Package_checksum();
              tx_buf[8]=DID_lowB;
              tx_buf[9]=DID_highB;
              tx_buf[10]=PID_lowB;
              tx_buf[11]=PID_highB;
              bISPDataReady = 1;
            break;
            case CMD_ERASE_ALL:
              set_CHPCON_IAPEN;
              set_IAPUEN_APUEN;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              Package_checksum();
              bISPDataReady = 1;
              break;
              READ_CONFIG();
              Package_checksum();
              tx_buf[8]=CONF0;
              tx_buf[9]=CONF1;
              tx_buf[10]=CONF2;
              tx_buf[11]=0xff;
              tx_buf[12]=CONF4;
              tx_buf[13]=0xff;
              tx_buf[14]=0xff;
              tx_buf[15]=0xff;
              bISPDataReady = 1;
            break;
              recv_CONF0 = rx_buf[8];
              recv_CONF1 = rx_buf[9];
              recv_CONF2 = rx_buf[10];
              recv_CONF4 = rx_buf[12];
/*Erase CONFIG */
              set_CHPCON_IAPEN;
              set_IAPUEN_CFUEN;
              IAPAL = 0x00;
              IAPAH = 0x00;
              IAPFD = 0xFF;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
/*Program CONFIG*/
              IAPFD = recv_CONF0;
              set_IAPTRG_IAPGO;
              IAPFD = recv_CONF1;
              IAPAL = 0x01;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              IAPAL = 0x02;
              IAPFD = recv_CONF2;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              IAPAL = 0x04;
              IAPFD = recv_CONF4;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              clr_IAPUEN_CFUEN;
/*Read new CONFIG*/
              READ_CONFIG();
              Package_checksum();
              tx_buf[8]=CONF0;
              tx_buf[9]=CONF1;
              tx_buf[10]=CONF2;
              tx_buf[11]=0xff;
              tx_buf[12]=CONF4;
              tx_buf[13]=0xff;
              tx_buf[14]=0xff;
              tx_buf[15]=0xff;
              bISPDataReady = 1;
              break;
              set_CHPCON_IAPEN;
              set_IAPUEN_APUEN;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
              g_totalchecksum=0;
              flash_address=0;
              AP_size=0;
              AP_size=rx_buf[12];
              vo8temp=rx_buf[13];
              AP_size|=(vo8temp<<8);
              g_progarmflag=1;
                clr_CHPCON_IAPFF;
#ifdef isp_with_wdt
#else
              trig_IAPGO;
#endif
                set_IAPTRG_IAPGO;
                if(IAPFD!=vo8temp)
                while(1);
                while(1);
                g_totalchecksum+=vo8temp;
                flash_address++;
                vo16temp = AP_size;
                  g_progarmflag=0;
                   goto END_1;
END_1:
              Package_checksum();
              bISPDataReady = 1;
              break;
          bI2CDataReady = FALSE;
          EA=1;
      //For connect timer out
      if(g_timer0Over==1)
       goto _APROM;
_APROM:
    EA = 0;
    clr_CHPCON_IAPEN;
    TA = 0xAA;
    TA = 0x55;
    CHPCON = 0x00;                  //set boot from AP
    TA = 0xAA;
    TA = 0x55;
    /* Trap the CPU */
    while(1);
xiaoaibjd| | 2025-5-28 09:05 | 只看该作者
单片机MCU技术交流群 679013663
彩虹捕手| | 2025-5-28 09:48 | 只看该作者
看起来你上传了一个关于CM1003使用I2C/UART实现ISP的文件,这对于需要进行嵌入式编程的开发者来说非常有用。如果有任何具体问题,欢迎随时提问。
梦境摆渡人| | 2025-5-28 16:20 | 只看该作者
感谢分享ISP的实现方法,我正需要这个资料来完成我的项目。请问这个文件包含具体的实现步骤和代码吗?
绝影孤狼| | 2025-5-28 18:03 | 只看该作者
这个ISP.rar文件包含了CM1003使用I2C/UART实现ISP的相关资料,有需要的朋友可以下载查看。
梦境摆渡人| | 2025-5-28 20:33 | 只看该作者
这个文件看起来包含了具体的实现方法和代码,对于需要通过I2C/UART实现ISP的朋友来说非常有用。
时光贩卖机| | 2025-5-28 21:05 | 只看该作者
感谢分享!请问这个ISP.rar文件包含了哪些具体内容?是代码示例还是配置文件?
