[综合信息]
国民技术RTC备份寄存器RTC_BKP
103|1
根据手册资料知道RTC_BKP的地址,代码如下
#include "main.h"
#include "usart.h"
void USART2_Configuration(void)
        USART_InitType USART_InitStructure;
        GPIO_InitType GPIO_InitStructure;
    GPIO_InitStruct(&GPIO_InitStructure);
        RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
    RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_USART2, ENABLE);
        GPIO_InitStructure.Pin            = GPIO_PIN_4;
    GPIO_InitStructure.GPIO_Mode      = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Alternate = GPIO_AF4_USART2;
    GPIO_InitPeripheral(GPIOB, &GPIO_InitStructure);
    GPIO_InitStructure.Pin            = GPIO_PIN_5;
    GPIO_InitStructure.GPIO_Pull      = GPIO_Pull_Up;
        USART_StructInit(&USART_InitStructure);
    USART_InitStructure.BaudRate            = 115200;
    USART_InitStructure.WordLength          = USART_WL_8B;
    USART_InitStructure.StopBits            = USART_STPB_1;
    USART_InitStructure.Parity              = USART_PE_NO;
    USART_InitStructure.HardwareFlowControl = USART_HFCTRL_NONE;
    USART_InitStructure.Mode                = USART_MODE_RX | USART_MODE_TX;
    USART_Init(USART2, &USART_InitStructure);
    USART_Enable(USART2, ENABLE);
int fputc(int ch, FILE* f)
    USART_SendData(USART2, (uint8_t)ch);
    while (USART_GetFlagStatus(USART2, USART_FLAG_TXDE) == RESET);
    return (ch);
#include "n32l40x.h"
#include "n32l40x_rtc.h"
#include "User_RTCBKP_Config.h"
uint16_t BKP_Datas[BACKUP_REGISTER_SIZE]={BKP_DAT1, BKP_DAT2, BKP_DAT3, BKP_DAT4, BKP_DAT5, \
                                          BKP_DAT6, BKP_DAT7, BKP_DAT8, BKP_DAT9, BKP_DAT10,\
                                          BKP_DAT11,BKP_DAT12,BKP_DAT13,BKP_DAT14,BKP_DAT15,\
                                          BKP_DAT16,BKP_DAT17,BKP_DAT18,BKP_DAT19,BKP_DAT20};
uint32_t Read_Backup_Datas[BACKUP_REGISTER_SIZE]={0x00};
void User_RTCBKP_Init(void)
    RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_PWR, ENABLE);
    /* Allow access to RTC */
    PWR_BackupAccessEnable(ENABLE);
    RCC_EnableRtcClk(DISABLE);
    /* Enable the LSE OSC32_IN PC14
       LSI is turned off here to ensure that only one clock is turned on */
    RCC_EnableLsi(DISABLE);
    RCC_ConfigLse(RCC_LSE_ENABLE,0x28);
    while (RCC_GetFlagStatus(RCC_LDCTRL_FLAG_LSERD) == RESET){}
    RCC_ConfigRtcClk(RCC_RTCCLK_SRC_LSE);
    /* Enable the RTC Clock */
    RCC_EnableRtcClk(ENABLE);
    RTC_WaitForSynchro();
void BKP_WriteBkpData(uint32_t BKP_DAT, uint32_t Data)
    __IO uint32_t tmp = 0;
    /* Check the parameters */
    assert_param(IS_BKP_DAT(BKP_DAT));
    tmp = (uint32_t)&RTC->BKP1R;
    tmp += BKP_DAT;
    *(__IO uint32_t*)tmp = Data;
uint32_t BKP_ReadBkpData(uint32_t BKP_DAT)
    uint32_t value = 0;
    tmp += BKP_DAT;
    value = (*(__IO uint32_t*)tmp);
    return value;
#ifndef __USER_RTCBKP_CONFIG_H__
#define __USER_RTCBKP_CONFIG_H__
#define  BKP_DAT1     ((uint16_t)0x0000)
#define  BKP_DAT2     ((uint16_t)0x0004)
#define  BKP_DAT3     ((uint16_t)0x0008)
#define  BKP_DAT4     ((uint16_t)0x000C)
#define  BKP_DAT5     ((uint16_t)0x0010)
#define  BKP_DAT6     ((uint16_t)0x0014)
#define  BKP_DAT7     ((uint16_t)0x0018)
#define  BKP_DAT8     ((uint16_t)0x001C)
#define  BKP_DAT9     ((uint16_t)0x0020)
#define  BKP_DAT10    ((uint16_t)0x0024)
#define  BKP_DAT11    ((uint16_t)0x0028)
#define  BKP_DAT12    ((uint16_t)0x002C)
#define  BKP_DAT13    ((uint16_t)0x0030)
#define  BKP_DAT14    ((uint16_t)0x0034)
#define  BKP_DAT15    ((uint16_t)0x0038)
#define  BKP_DAT16    ((uint16_t)0x003C)
#define  BKP_DAT17    ((uint16_t)0x0040)
#define  BKP_DAT18    ((uint16_t)0x0044)
#define  BKP_DAT19    ((uint16_t)0x0048)
#define  BKP_DAT20    ((uint16_t)0x004C)
#define  IS_BKP_DAT(DAT)        \
             (((DAT) == BKP_DAT1)  || ((DAT) == BKP_DAT2)  || ((DAT) == BKP_DAT3)  || ((DAT) == BKP_DAT4)   \
           || ((DAT) == BKP_DAT5)  || ((DAT) == BKP_DAT6)  || ((DAT) == BKP_DAT7)  || ((DAT) == BKP_DAT8)   \
           || ((DAT) == BKP_DAT9)  || ((DAT) == BKP_DAT10) || ((DAT) == BKP_DAT11) || ((DAT) == BKP_DAT12)  \
           || ((DAT) == BKP_DAT13) || ((DAT) == BKP_DAT14) || ((DAT) == BKP_DAT15) || ((DAT) == BKP_DAT16)  \
           || ((DAT) == BKP_DAT17) || ((DAT) == BKP_DAT18) || ((DAT) == BKP_DAT19) || ((DAT) == BKP_DAT20) )
#define  BACKUP_REGISTER_SIZE        20
extern uint16_t BKP_Datas[BACKUP_REGISTER_SIZE];
extern uint32_t Read_Backup_Datas[BACKUP_REGISTER_SIZE];
extern void BKP_WriteBkpData(uint32_t BKP_DAT, uint32_t Data);
extern uint32_t BKP_ReadBkpData(uint32_t BKP_DAT);
extern void User_RTCBKP_Init(void);
#endif /* __USER_RTCBKP_CONFIG_H__ */
#include "main.h"
#include "usart.h"
#include "n32l40x_flash.h"
#ifdef USE_FULL_ASSERT
void assert_failed(const uint8_t* expr, const uint8_t* file, uint32_t line)
    while (1)
#endif
#define USE_USART
int main(void)
        int i = 0;
        #ifdef USE_USART
        USART2_Configuration();
        #endif
        User_RTCBKP_Init();
        for(i=0;i<BACKUP_REGISTER_SIZE;i++)
                Read_Backup_Datas=BKP_ReadBkpData(BKP_Datas);
                printf("BKP_DAT%u=%d\r\n",i+1,(unsigned int)Read_Backup_Datas);
                BKP_WriteBkpData(BKP_Datas, i);
串口打印如下:
第一次上电
BKP_DAT1=0
BKP_DAT2=0
BKP_DAT3=0
BKP_DAT4=0
BKP_DAT5=0
BKP_DAT6=0
BKP_DAT7=0
BKP_DAT8=0
BKP_DAT9=0
BKP_DAT10=0
BKP_DAT11=0
BKP_DAT12=0
BKP_DAT13=0
BKP_DAT14=0
BKP_DAT15=0
BKP_DAT16=0
BKP_DAT17=0
BKP_DAT18=0
BKP_DAT19=0
BKP_DAT20=0
NRST脚复位
BKP_DAT1=0
BKP_DAT2=1
BKP_DAT3=2
BKP_DAT4=3
BKP_DAT5=4
BKP_DAT6=5
BKP_DAT7=6
BKP_DAT8=7
BKP_DAT9=8
BKP_DAT10=9
BKP_DAT11=10
BKP_DAT12=11
BKP_DAT13=12
BKP_DAT14=13
BKP_DAT15=14
BKP_DAT16=15
BKP_DAT17=16
BKP_DAT18=17
BKP_DAT19=18
BKP_DAT20=19
原文链接:https://blog.csdn.net/dailin2012/article/details/129725497
地瓜patch| | 2025-3-31 21:30 | 只看该作者
整理成文档最合适
