[电池电源管理]
SH367309中颖单片机专用动力电池保护板开发资料 原理图PCB代码
1380|3
tpgf|  楼主 | 2025-3-5 08:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1、简介
中颖BMS5-16 串 前端芯片,用于充电管理+电池保护+电量计量,有规格书,原理图,PCB, DEMO CODE全套开发资料 。
2、原理图和PCB
3、程序
#include "system.h"
#include "Uart.h"
#include "Main.h"
void main(void)
        Initial();                                        //Initialize the system
        while(1)
                RSTSTAT = RSTSTAT;
                  if(bAFE**)
                         bAFE** = 0;
                        AFERdFlag();
                if((ucResetFlag==0x12) && bUartSndAck**)        //Software reset occurs, and ended UART communication
                        if(!bWrFlash**)
                                EA = 0;
                                ResetAFE();                                                //Reset IC
                                ResetInit();                                        //Reset MCU
                if(bWakeup**)                                                //The charger / load, keys can wake up the system
                        bWakeup** = 0;
                        WakeUpProcess();                                //System to be awakened
                if(bBleOnOff**)                                        //按键长按5秒开启/关闭蓝牙
                        bBleOnOff** = 0;
                        BleOnorOff();
                BleDisplay();
                if(bCADC**)
                        bCADC** = 0;
                        CurProcess();                                        //Calculate the current value and determines the state of charge and discharge
                if(bCalibration**)
                        bCalibration** = 0;
                        CaliProcess();                                        //PC calibration
                if((bWrFlash**)&&(ucUpDataLimitTime == 0))
                        bWrFlash** = 0;
                        if(FlashProcess())
                                if(bUartNeedAck**)
                                        UART_SEND_ACK;
                        else
                                if(bUartNeedAck**)
                                        UART_SEND_NACK;
                        bUartNeedAck** = 0;
                if(bLEDOpen)
                        bLEDOpen = 0;
                        bLED** = 1;
                        ucLEDTimeCnt = 0;
                        LEDPowerOn();                                        //By LED displays battery capacity
                if(bEnEEPRomBK && bE2PProcess**)
                        bE2PProcess** = 0;
                        E2PRomBKProcess();
                if(bISP** && bUartSndAck**)
                        bISP** = 0;
                        ISPProcess();
                if(bTimer**)                                                //timer is 1s
                        bTimer** = 0;
                        AFECheck();                            //Check AFE Register
                        LEDPowerOff();                                        //When the LED display 4s, turn off the LED
                        BatteryInfoManage();                        //Get battery voltage and temperature information
                        RamCheckProcess();                    //Detect the xdata block data
                        GaugeManage();                                        //Calculate the battery charge and discharge capacity
                        VolProcess();                                        //Detection of battery charge and discharge cut-off voltage
                        BalProcess();                                        //Process external voltage balance
                        ProtectProcess();                                //Process battery abnormal state
            if(bEnEEPRomBK)
                            E2PRomBKCheck();                        //Detecting whether to backup EEPRom
                        ShutDownProcess();                                //Detecting whether to enter a low-power
                IntoShutDown();
原文链接:https://blog.csdn.net/qq_35654286/article/details/145109727
jf101| | 2025-3-24 08:14 | 只看该作者
非常不错的开源案例
中国龙芯CDX| | 2025-3-24 23:11 | 只看该作者
很赞的开源资料
星辰大海不退缩| | 2025-3-27 12:57 | 只看该作者
非常不错的资源学习一下
