test_lib.s
3457|0
laojun001|  楼主 | 2025-2-27 21:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TEST, he, mt, ID, 8M, or
* (C) Copyright 2005
* Wolfgang Denk, DENX Software Engineering, wd@denx.de.
* SPDX-License-Identifier:        GPL-2.0+
#include <config.h>
#include <ppc_asm.tmpl>
#include <ppc_defs.h>
#include <asm/cache.h>
#include <asm/mmu.h>
#include "test_burst.h"
        .text
*        void mmu_init(void);
*        This function turns the MMU on
*        Three 8 MByte regions are mapped 1:1, uncached
*        - SDRAM lower 8 MByte
*        - SDRAM higher 8 MByte
*        - IMMR
        .global mmu_init
mmu_init:
        tlbia                        /* Invalidate all TLB entries */
        li        r8, 0
        mtspr        MI_CTR, r8        /* Set instruction control to zero */
        lis        r8, MD_RESETVAL@h
        mtspr        MD_CTR, r8        /* Set data TLB control */
        /* Now map the lower 8 Meg into the TLBs.  For this quick hack,
         * we can load the instruction and data TLB registers with the
         * same values.
        li        r8, MI_EVALID                /* Create EPN for address 0 */
        mtspr        MI_EPN, r8
        mtspr        MD_EPN, r8
        li        r8, MI_PS8MEG                /* Set 8M byte page */
        ori        r8, r8, MI_SVALID        /* Make it valid */
        mtspr        MI_TWC, r8
        mtspr        MD_TWC, r8
        li        r8, MI_BOOTINIT|0x2        /* Create RPN for address 0 */
        mtspr        MI_RPN, r8                /* Store TLB entry */
        mtspr        MD_RPN, r8
        lis        r8, MI_Kp@h                /* Set the protection mode */
        mtspr        MI_AP, r8
        mtspr        MD_AP, r8
        /* Now map the higher 8 Meg into the TLBs.  For this quick hack,
         * same values.
        lwz        r9,20(r2)                /* gd->ram_size */
        addis        r9,r9,-0x80
        mr        r8, r9                        /* Higher 8 Meg in SDRAM */
        ori        r8, r8, MI_EVALID        /* Mark page valid */
        mtspr        MI_EPN, r8
        mtspr        MD_EPN, r8
        mtspr        MI_TWC, r8
        mtspr        MD_TWC, r8
        mr        r8, r9
        ori        r8, r8, MI_BOOTINIT|0x2
        mtspr        MD_RPN, r8
        mtspr        MI_AP, r8
        mtspr        MD_AP, r8
        /* Map another 8 MByte at the IMMR to get the processor
         * internal registers (among other things).
        mfspr        r9, 638                        /* Get current IMMR */
        andis.        r9, r9, 0xff80                /* Get 8Mbyte boundary */
        mr        r8, r9                        /* Create vaddr for TLB */
        ori        r8, r8, MD_EVALID        /* Mark it valid */
        mtspr        MD_EPN, r8
        li        r8, MD_PS8MEG                /* Set 8M byte page */
        ori        r8, r8, MD_SVALID        /* Make it valid */
        mtspr        MD_TWC, r8
        mr        r8, r9                        /* Create paddr for TLB */
        ori        r8, r8, MI_BOOTINIT|0x2 /* Inhibit cache -- Cort */
        mtspr        MD_RPN, r8
        /* We now have the lower and higher 8 Meg mapped into TLB entries,
         * and the caches ready to work.
        mfmsr        r0
        ori        r0,r0,MSR_DR|MSR_IR
        mtspr        SRR1,r0
        mflr        r0
        mtspr        SRR0,r0
        SYNC
        rfi        /* enables MMU */
*        void caches_init(void);
        .globl        caches_init
caches_init:
        sync
        mfspr        r3, IC_CST                /* Clear error bits */
        mfspr        r3, DC_CST
        lis        r3, IDC_UNALL@h                /* Unlock all */
        mtspr        IC_CST, r3
        mtspr        DC_CST, r3
        lis        r3, IDC_INVALL@h        /* Invalidate all */
        mtspr        IC_CST, r3
        mtspr        DC_CST, r3
        lis        r3, IDC_ENABLE@h        /* Enable all */
        mtspr        IC_CST, r3
        mtspr        DC_CST, r3
        blr
*        void flush_dcache_range(unsigned long start, unsigned long stop);
        .global flush_dcache_range
flush_dcache_range:
        li        r5,CACHE_LINE_SIZE-1
        andc        r3,r3,r5
        subf        r4,r3,r4
        add        r4,r4,r5
        srwi.        r4,r4,LG_CACHE_LINE_SIZE
        beqlr
        mtctr        r4
1:        dcbf        0,r3
        addi        r3,r3,CACHE_LINE_SIZE
        bdnz        1b
        sync                                /* wait for dcbf's to get to ram */
        blr
*        void disable_interrupts(void);
        .global disable_interrupts
disable_interrupts:
        mfmsr        r0
        rlwinm        r0,r0,0,17,15
        mtmsr        r0
        blr
