发新帖本帖赏金 30.00元(功能说明)我要提问
返回列表
[活动]
G32A1465测评——03DEMO测试
1586|2
3201144384|  楼主 | 2025-1-14 18:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
前几章都已经知道了keil的调试流程和芯片的基本参数了,那么这一次就可以直接来编写一些测试的DEMO小程序,那就直接在官方例程上面来实现吧
选择官方的CAN_ClassicFrames例程,打开里面可以知道通过两个按键来发送CAN,分别是扩展帧和标准帧格式,那么这也就是经典的CAN2.0B。
那我直接给工程做一些小小的改动,首先要有自己的思路,板子供电,切换5V给MCU,连接CANH 和CANL到CAN工具上,CAN的两端最好都要加上终端电阻120欧,测试50ms循环发送CAN报文,并且根据收到指定报文的信号来决定亮什么颜色的灯。
思路有了之后,就开始实践,1.时钟初始化,2.引脚初始化。3.can 外设初始化 。(发送邮箱,接收邮箱,将过滤ID,安装中断服务函数,调用接收函数)4.CAN中断里面编写接收处理
代码如下:
* @file        main.c
* @brief       Main program
* @version     V1.0.0
* @date        2024-03-20
* @attention
*  Copyright (C) 2024 Geehy Semiconductor
*  You may not use this file except in compliance with the
*  GEEHY COPYRIGHT NOTICE (GEEHY SOFTWARE PACKAGE LICENSE).
*  The program is only for reference, which is distributed in the hope
*  that it will be useful and instructional for customers to develop
*  their software. Unless required by applicable law or agreed to in
*  writing, the program is distributed on an "AS IS" BASIS, WITHOUT
*  ANY WARRANTY OR CONDITIONS OF ANY KIND, either express or implied.
*  See the GEEHY SOFTWARE PACKAGE LICENSE for the governing permissions
*  and limitations under the License.
/* Includes */
#include "user_config.h"
#include "board.h"
/** @addtogroup G32A1465_Examples
/** @addtogroup CAN_ClassicFrames
/** @defgroup CAN_ClassicFrames_Macros Macros
/* CAN instance */
#define CAN0_INSTANCE       (0U)
/* MB0 is used to receive standard CAN frames */
#define RX_MB_0             (0U)
/* MB1 is used to receive extended CAN frames */
#define RX_MB_1             (1U)
/* The MB used to transmit CAN frames */
#define TX_MB               (2U)
/* CAN message IDs */
#define RX_CAN_MESSAGE_ID   (0x303U)
#define TX_CAN_MESSAGE_ID_1 (0x404U)
#define TX_CAN_MESSAGE_ID_2 (0x505U)
        CAN_MSG_BUF_T rxFrame0;
        CAN_MSG_BUF_T rxFrame1;
        uint8_t payload[8] = {0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77, 0x88};
        CAN_DATA_INFO_T txDataInfo = {
        .msgIdType  = CAN_ID_STANDARD,  /* Standard CAN ID */
        .dataLen    = sizeof(payload),      /* Payload size */
        .fdEnable   = false,
        .isRemote   = false
/**@} end of group CAN_ClassicFrames_Macros*/
/** @defgroup CAN_ClassicFrames_Variables Variables
/* Indicate MB0 receive is completed */
volatile bool g_mb0ReceiveCompleted = false;
/* Indicate MB1 receive is completed */
volatile bool g_mb1ReceiveCompleted = false;
/**@} end of group CAN_ClassicFrames_Variables*/
/** @defgroup CAN_ClassicFrames_Functions Functions
* @brief This function is called when a CAN event occurred
void CanEventCallback(
    uint8_t instance,
    CAN_EVENT_TYPE_T eventType,
    uint32_t mbIndex,
    CAN_STATE_T *driverState)
    /* A frame was received in the configured Rx MB */
    if (eventType == CAN_EVENT_RX_COMPLETE)
        /* Set the receive complete flags */
        if (mbIndex == RX_MB_0)
                                                CAN_ReceiveNonBlocking(CAN0_INSTANCE, RX_MB_0, &rxFrame0);
                                                g_mb0ReceiveCompleted  = 1;
        if (mbIndex == RX_MB_1)
                                                CAN_ReceiveNonBlocking(CAN0_INSTANCE, RX_MB_1, &rxFrame1);
* @brief This function is called when the KEY1 button is pressed
void Key1Handler(void)
    /* Send standard CAN frame */
    uint8_t payload[6] = {0x30, 0x31, 0x32, 0x33, 0x34, 0x35};
        .fdEnable   = false,
        .isRemote   = false
    CAN_SendNonBlocking(CAN0_INSTANCE, TX_MB, &txDataInfo, TX_CAN_MESSAGE_ID_1, payload);
* @brief This function is called when the KEY2 button is pressed
void Key2Handler(void)
    /* Send extended CAN frame */
    uint8_t payload[7] = {0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36};
        .msgIdType  = CAN_ID_EXTENDED,  /* Extended CAN ID */
        .fdEnable   = false,
        .isRemote   = false
    CAN_SendNonBlocking(CAN0_INSTANCE, TX_MB, &txDataInfo, TX_CAN_MESSAGE_ID_2, payload);
* @brief   Main function
* @param   None
* @retval  Exit code
int main(void)
    bool exit = false;
    CAN_STATE_T canState;
    CAN_TIME_SEGMENT_T canBitrate;
    /* Initialize clock */
    CLOCK_SYS_Init(&g_clockConfig);
    /* Initialize pins */
    PINS_Init(NUM_OF_CONFIGURED_PINS0, g_pinsConfig);
    /* Initialize LEDs */
    LED_Init();
//    LED_On(LED_GREEN);
    /* Initialize buttons */
    BTN_Init();
    BTN_InstallKey1Handler(Key1Handler);
    BTN_InstallKey2Handler(Key2Handler);
    /* Initialize the CAN controller, bitrate is 250K */
    CAN_Init(CAN0_INSTANCE, &canState, &g_canConfig);
    /* Get the current CAN bitrate */
    CAN_GetBitrate(CAN0_INSTANCE, &canBitrate);
    /* Configure Tx MB */
    CAN_DATA_INFO_T txMbInfo = {
        .dataLen    = 8,        /* Used only to initialize the MB, will be updated when send data */
        .fdEnable   = false,    /* Disable CAN FD */
        .isRemote   = false
    CAN_ConfigureTxMb(CAN0_INSTANCE, TX_MB, &txMbInfo, 0);
    /* Use individual Rx masking for the MBs */
    CAN_SetRxMaskType(CAN0_INSTANCE, CAN_RX_MASK_INDIVIDUAL);
    /* Configure Rx MB0, it will receive standard frames with ID 1 */
    CAN_DATA_INFO_T rxMb0Info = {
        .dataLen    = 8,        /* Max data length for classic CAN is 8 bytes */
        .isRemote   = false
    CAN_ConfigureRxMb(CAN0_INSTANCE, RX_MB_0, &rxMb0Info, RX_CAN_MESSAGE_ID);
    CAN_SetRxIndividualMask(CAN0_INSTANCE, CAN_ID_STANDARD, RX_MB_0, 0x0);
    /* Configure Rx MB1, it will receive extended frames with ID 1 */
    CAN_DATA_INFO_T rxMb1Info = {
        .isRemote   = false
    CAN_ConfigureRxMb(CAN0_INSTANCE, RX_MB_1, &rxMb1Info, RX_CAN_MESSAGE_ID);
    CAN_SetRxIndividualMask(CAN0_INSTANCE, CAN_ID_EXTENDED, RX_MB_1, 0xFFFFFFFF);
    /* Set the CAN event callback handler */
    CAN_InstallEventCallback(CAN0_INSTANCE, &CanEventCallback, NULL);
    /* Receive CAN frames from MB0 and MB1 */
    while (!exit)
                        OSIF_TimeDelay(50);
                        if(g_mb0ReceiveCompleted == 1)
                                if(rxFrame0.data[0] == 0)
                                                LED_On(LED_RED);
                                                LED_Off(LED_GREEN);
                                                LED_Off(LED_BLUE);
                                else if(rxFrame0.data[0] == 1)
                                                LED_On(LED_GREEN);
                                                LED_Off(LED_RED);
                                                LED_Off(LED_BLUE);
                                else if(rxFrame0.data[0] == 2)
                                                LED_On(LED_BLUE);
                                                LED_Off(LED_RED);
                                                LED_Off(LED_GREEN);
                                else
                                        LED_Off(LED_RED);
                                        LED_Off(LED_BLUE);
                                        LED_Off(LED_GREEN);
    CAN_DeInit(CAN0_INSTANCE);
    LED_On(LED_RED);
    return 0;
/**@} end of group CAN_ClassicFrames_Functions */
/**@} end of group CAN_ClassicFrames */
/**@} end of group Examples */
这样我就实现了收到报文ID303的第一位数据变化灯的颜色了,实测也是没有问题。
不过最后其实有一点想说的,不知道极海有没有可以像s32dsV2.2 开发工具那样,直接对需要的外设和引脚进行图形化配置,最后直接生成出相应的代码。如果有的话,那么可以节省很大一部分时间来减少开发的工作量。
在此也感谢极海能够提供这一次的测评机会,后面我也会把自己遇到的一些问题分享给大家。希望大家多多交流!
打赏榜单
21ic小管家 打赏了 30.00 元 2025-01-21
理由:优质评测
LightCatcher| | 2025-1-16 16:07 | 只看该作者
确实需要开发一款图形化的工具。
低语之树| | 2025-1-21 10:07 | 只看该作者
没用过can通信,学习一下
发新帖 本帖赏金 30.00元(功能说明)我要提问
