[代码反篡改]
C51反篡改源码下载(菜农独创双向CRC初值碰撞反篡改)
2399|0
hotpower|  楼主 | 2023-10-26 13:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
#include <stdio.h>
#include <REG52.H>
#ifdef MONITOR51
char code reserve [3] _at_ 0x23;
#endif
typedef unsigned char uint8_t;
typedef unsigned int uint16_t;
typedef unsigned long uint32_t;
code uint32_t CRC32Array[8] = {//菜农HotPower@163.com
//全局数组,在Flash里
        0x55555555,//头数据,为注册机提供搜索位置,改写即篡改非零
        0xAAAAAAAA,//头数据,为注册机提供搜索位置,改写即篡改非零
        0x22345678,//头数据,为注册机提供搜索位置,改写即篡改非零
        0x20231025,//多项式可以是随机数,例如今天是2023.10.25
        0,//Flash基地址
        0x0FE3,//HEX长度
        0x2430A72A,//CRC32初值1,正向验证
        0x4EBAAEC5 //CRC32初值2,反向验证
uint32_t CRC32Val(uint32_t input, uint32_t poly, uint32_t init, uint32_t xorout)
        uint32_t ch;
        int i;
        input ^= init;
        if ((poly & 1) > 0)
                for (i = 0; i < 32; i++)
                        ch = input & 0x80000000;
                        input <<= 1;
                        if (ch > 0)
                                input ^= poly;
        else
                        ch = input & 1;
                        input >>= 1;
                        if (ch > 0)
                                input ^= poly | 0x80000000;
        if ((poly & 0x80000001) == 0)
                input ^= poly ^ 0x80000001;
        input ^= xorout;
        return input;
uint32_t CRC32Valx(uint32_t output, uint32_t poly, uint32_t init, uint32_t xorout)
        int i;
        output ^= xorout;
                output ^= poly ^ 0x80000001;
        if ((poly & 1) > 0)
                        if ((output & 1) > 0)
                                output ^= poly;
                                output >>= 1;
                                output |= 0x80000000;
                        else
                                output >>= 1;
        else
                        if ((output & 0x80000000) > 0)
                                output ^= poly;
                                output <<= 1;
                                output |= 1;
                        else
                                output <<= 1;
        output ^= init;
        return output;
void SetCRC32Init(uint32_t* init1, uint32_t* init2)
        uint16_t len = (CRC32Array[5] - ((int)(&CRC32Array[6]) & 3)) / 4;
        uint32_t CRC32Init;
        uint32_t crc32;
        uint32_t crcpoly = CRC32Array[3];
        int pos1 = (int)(&CRC32Array[6] - (uint16_t)CRC32Array[4]) / 4;
        int pos2 = (int)(&CRC32Array[7] - (uint16_t)CRC32Array[4]) / 4;
        int i;
        unsigned long volatile code *Flash = (unsigned long volatile code *)((int)(&CRC32Array[6]) & 3);
        CRC32Init = 0;
        for(i = len - 1;i >= 0;i--)
                crc32 = Flash[(uint16_t)CRC32Array[4] + i];
                if(!(i == pos1 || i == pos2))
                        CRC32Init = CRC32Valx(CRC32Init, crcpoly, crc32, 0);
                else
                        *init1 = CRC32Init;
        *init1 = CRC32Init;
        CRC32Init = 0;
        for(i = 0;i < len;i++)
                if(!(i == pos2))
                else
                        *init2 = CRC32Init;
        *init2 = CRC32Init;
uint32_t GetCRC32Init12()
        uint32_t CRC32Init;
        uint32_t crc32;
        int i;
        CRC32Init = CRC32Array[6];
                        CRC32Init = CRC32Val(crc32, crcpoly, CRC32Init, 0);
        CRC32Init ^= CRC32Array[7];
                if(!(i == pos2))
        return CRC32Init;
uint32_t GetCRC32Init1()
        uint32_t CRC32Init;
        uint32_t crc32;
        int i;
        return CRC32Init;
uint32_t GetCRC32Init2()
        uint32_t CRC32Init;
        uint32_t crc32;
        int i;
        CRC32Init = CRC32Array[7];
                if(!(i == pos2))
        return CRC32Init;
void main(void)
        uint32_t init1 = 0;//填入CRC32Array[6]的CRC32初值1
        uint32_t init2;//填入CRC32Array[7]的CRC32初值2
        volatile uint32_t init12;
#ifndef MONITOR51
    SCON  = 0x50;
    TMOD |= 0x20;
    TH1   = 221;
    TR1   = 1;
    TI    = 1;
#endif
        SetCRC32Init(&init1, &init2);//结果填入CRC32初值1(第1次),CRC32初值2(第2次),需要编译运行两次!!!
        init12 = GetCRC32Init12();//被篡改非零!!!可以篡改CRC32Array[0],CRC32Array[1],CRC32Array[2]
        init1 = GetCRC32Init1();//被篡改非零!!!可以篡改CRC32Array[0],CRC32Array[1],CRC32Array[2]
        init2 = GetCRC32Init2();//被篡改非零!!!可以篡改CRC32Array[0],CRC32Array[1],CRC32Array[2]
        printf("init12 = 0x%08LX\n", init12);
        printf("init1 = 0x%08LX\n", init1);
        printf("init2 = 0x%08LX\n", init2);
  while (1) {
    printf ("Hello World\n");   /* Print "Hello World" */
DataCheck.rar
35.96 KB
个人签名:[url=http://www.21ic.com/tools/HotWC3_V1.23.html]
1460
