发新帖本帖赏金 50.00元(功能说明)我要提问
返回列表
[CW32F030系列]
【CW32F030CxTx StartKit测评】5.硬件SPI驱动OLED
2661|16
此篇介绍使用硬件SPI1轮询模式来实现驱动OLED显示屏
硬件连接
GND ——  GND
VCC ——  3.3V
DO  ——  PA5
DI  ——  PA7
RES ——  PB1
DC  ——  PB0
CS  ——  PA4
软件代码
SPI1配置:
//SPI初始化
void SPI_Initial(void)
    SPI_InitTypeDef SPI_InitStructure;
    /* Enable GPIO clock for SPI_MASTER */
    RCC_AHBPeriphClk_Enable(SPI_MASTER_GPIO_CLK | RCC_SPI_CS, ENABLE);
    /* Enable SPI_MASTER Periph clock */
    RCC_APBPeriphClk_Enable2(SPI_MASTER_CLK, ENABLE);
    //SPI SCK MOSI MISO 复用
    SPI_AF_SCK;
    SPI_AF_MISO;
    SPI_AF_MOSI;
    //GPIO_CS初始化设置
    GPIO_InitStructure.Pins = PIN_SPI_CS;
    GPIO_InitStructure.Speed = GPIO_SPEED_HIGH;
    GPIO_InitStructure.IT = GPIO_IT_NONE;
    GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_Init(PORT_SPI_CS, &GPIO_InitStructure);
    SPI_CS_DISABLE;
    /* Configure SPI_MASTER pins: SCK and MOSI ---------------------------------*/
    /* Configure SCK and MOSI pins as Alternate Function Push Pull */
    GPIO_InitStructure.Pins = SPI_MASTER_PIN_SCK | SPI_MASTER_PIN_MOSI;
    GPIO_Init(SPI_MASTER_GPIO, &GPIO_InitStructure);
    /* Configure MISO pin as Input Floating  */
    GPIO_InitStructure.Pins = SPI_MASTER_PIN_MISO;
    GPIO_InitStructure.Mode = GPIO_MODE_INPUT;
    /* SPI_MASTER configuration ------------------------------------------------*/
    SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;    // 双线全双工
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                         // 主机模式
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                     // 帧数据长度为8bit
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                           // 时钟空闲电平为高
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;                          // 第2个边沿采样
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                             // 片选信号由SSI寄存器控制
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;  // 波特率为PCLK的128分频,16M/128=125000
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;                    // 最高有效位 MSB 收发在前
    SPI_InitStructure.SPI_Speed = SPI_Speed_Low;                          // 低速SPI
    SPI_Init(SPI_MASTER, &SPI_InitStructure);
    /* Enable SPI_MASTER */
    SPI_Cmd(SPI_MASTER, ENABLE);
OLED代码:
//向设备写控制命令
static void OLED_Write_CMD(unsigned char cmd)
    #ifdef HW_I2C
    unsigned char tx_buf[BUF_SIZE] = {0x00, cmd};
    I2C_MasterSendDataToSlave(CW_I2C2, tx_buf, BUF_SIZE);
    #endif
    #ifdef SW_I2C
    I2C_Start();
    I2C_Send_Byte(0x78);
    I2C_Wait_Ack();
    I2C_Send_Byte(0x00);
    I2C_Wait_Ack();
    I2C_Send_Byte(cmd);
    I2C_Wait_Ack();
    I2C_Stop();
    #endif
    #ifdef HW_SPI
    OLED_CS_LOW;
    OLED_DC_LOW;
    while (SPI_GetFlagStatus(SPI_MASTER, SPI_FLAG_TXE) == RESET);
    SPI_SendData(SPI_MASTER, cmd);
    while (SPI_GetFlagStatus(SPI_MASTER, SPI_FLAG_RXNE) == RESET);
    SPI_ReceiveData(SPI_MASTER);
    OLED_CS_HIGH;
    #endif
    #ifdef SW_SPI
    OLED_CS_LOW;
    OLED_DC_LOW;
    SPI_WriteByte(cmd);
    OLED_CS_HIGH;
    #endif
//向设备写数据
static void OLED_Write_Date(unsigned char date)
    #ifdef HW_I2C
    unsigned char tx_buf[BUF_SIZE] = {0x40, date};
    #endif
    #ifdef SW_I2C
    I2C_Start();
    I2C_Wait_Ack();
    I2C_Send_Byte(0x40);
    I2C_Wait_Ack();
    I2C_Send_Byte(date);
    I2C_Wait_Ack();
    I2C_Stop();
    #endif
    #ifdef HW_SPI
    OLED_CS_LOW;
    OLED_DC_HIGH;
    SPI_SendData(SPI_MASTER, date);
    OLED_CS_HIGH;
    #endif
    #ifdef SW_SPI
    OLED_CS_LOW;
    OLED_DC_HIGH;
    SPI_WriteByte(date);
    OLED_CS_HIGH;
    #endif
//坐标设置
static void OLED_Set_Pos(unsigned char x, unsigned char y)
    OLED_Write_CMD(0xB0 + y);
    OLED_Write_CMD(((x & 0xF0) >> 4) | 0x10);
    OLED_Write_CMD(x & 0x0F);
//开启OLED显示
static void OLED_Display_On(void)
    OLED_Write_CMD(0x8D); //SET DCDC命令
    OLED_Write_CMD(0x14); //DCDC ON
    OLED_Write_CMD(0xAF); //DISPLAY ON
//关闭OLED显示
static void OLED_Display_Off(void)
    OLED_Write_CMD(0x10); //DCDC OFF
    OLED_Write_CMD(0xAE); //DISPLAY OFF
//OLED清屏
void OLED_Clear(void)
    unsigned char cnt, count;
    for(cnt = 0; cnt < 8; cnt++)
        OLED_Write_CMD(0xB0 + cnt);
        OLED_Write_CMD(0x00);
        for(count = 0; count < 128; count++)
            OLED_Write_Date(0x00);
//OLED清行
void OLED_Clear_Row(unsigned char n)
    unsigned char count;
    OLED_Write_CMD(0xB0 + n);
//OLED填满屏幕
void OLED_Fill(void)
        OLED_Write_CMD(0xB0 + cnt); //设置页地址(0~7)
        OLED_Write_CMD(0x00); //设置显示位置—列低地址
        OLED_Write_CMD(0x10); //设置显示位置—列高地址
            OLED_Write_Date(0x01);
//指定位置显示一个字符
//x:0~127
//y:0~63
//chr:字符
//mode:0,反白显示;1,正常显示
//size:选择字体 16/12
void OLED_ShowChar(unsigned char x, unsigned char y, unsigned char chr, unsigned char size)
    unsigned char offset = 0, cnt = 0;
    offset = chr - ' '; //计算偏移量
    if(x > 128 - 1)
        x = 0;
        y = y + 2;
    if(size == 16)
        OLED_Set_Pos(x, y);
            OLED_Write_Date(F8x16[offset * 16 + cnt]);
        OLED_Set_Pos(x, y + 1);
            OLED_Write_Date(F8x16[offset * 16 + cnt + 8]);
    else
        OLED_Set_Pos(x, y);
        for(cnt = 0; cnt < 6; cnt++)
            OLED_Write_Date(F6x8[offset][cnt]);
unsigned int oled_pow(unsigned char m, unsigned char n)
    unsigned int result = 1;
    while(n--)
        result *= m;
    return result;
//指定位置显示一个数字
//x,y:起点坐标
//num:数值(0~4294967295)
//len:数字的位数
//size:字体大小
//mode:模式        0,填充模式;1,叠加模式
void OLED_ShowNum(unsigned char x, unsigned char y, unsigned int num, unsigned char len, unsigned char size)
    unsigned char cnt, temp;
    unsigned char show = 0;
    for(cnt = 0; cnt < len; cnt++)
        temp = (num / oled_pow(10, len - cnt - 1)) % 10;
        if(show == 0 && cnt < (len - 1))
            if(temp == 0)
                OLED_ShowChar(x + (size / 2) * cnt, y, ' ', size);
                continue;
            else
                show = 1;
        OLED_ShowChar(x + (size / 2) * cnt, y, temp + '0', size);
//指定位置显示字符串
void OLED_ShowString(unsigned char x, unsigned char y, unsigned char *chr, unsigned char size)
    unsigned char cnt = 0;
    while(chr[cnt] != '\0')
        OLED_ShowChar(x, y, chr[cnt], size);
        x += 8;
        if(x > 120)
            x = 0;
            y += 2;
        cnt++;
//显示汉字
void OLED_ShowCHinese(unsigned char x, unsigned char y, unsigned char no)
    unsigned char cnt, addr = 0;
    OLED_Set_Pos(x, y);
    for(cnt = 0; cnt < 16; cnt++)
        OLED_Write_Date(Hzk[2 * no][cnt]);
        addr++;
        OLED_Write_Date(Hzk[2 * no + 1][cnt]);
        addr++;
//显示图片
        @brief                        显示图片
        @param                        x0:起始列地址
                                        y0:起始页地址
                                        x1:终止列地址
                                        y1:终止页地址
                                        BMP[]:存放图片代码的数组
        @retval                        无
void OLED_DrawBMP(unsigned char x0, unsigned char y0, unsigned char x1, unsigned char y1, unsigned char BMP[])
    unsigned int j = 0; //定义变量
    unsigned char x, y; //定义变量
    if(y1 % 8 == 0)
        y = y1 / 8; //判断终止页是否为8的整数倍
    else
        y = y1 / 8 + 1;
    for(y = y0; y < y1; y++) //从起始页开始,画到终止页
        OLED_Set_Pos(x0, y); //在页的起始列开始画
        for(x = x0; x < x1; x++) //画x1 - x0 列
            OLED_Write_Date(BMP[j++]); //画图片的点
//显示动图
        @brief                        显示动图
        @param                        x0:起始列地址
                                y0:起始页地址
                                x1:终止列地址
                                y1:终止页地址
                                k: 帧个数
                                m: 单帧数组大小
                                BMP[][m]:存放动图代码的数组
        @retval                        无
void OLED_DrawGIF(unsigned char x0, unsigned char y0, unsigned char x1, unsigned char y1, unsigned char k, int m, const unsigned char GIF[][m])
    unsigned char x, y, i; //定义变量
    if(y1 % 8 == 0)
    else
        y = y1 / 8 + 1;
    for (i = 0; i < k; i++) //从第一帧开始画
        j = 0;
                OLED_Write_Date(GIF[i][j++]); //画图片的点
        //Delay_Ms(80);
#if defined SW_SPI || defined HW_SPI
//SPI驱动方式DC、RES引脚初始化
void OLED_SPI_GPIO_Init(void)
    //根据GPIO组初始化GPIO时钟
    RCC_AHBPeriphClk_Enable( RCC_OLED_DC | RCC_OLED_RES, ENABLE);
    //GPIO_DC初始化设置
    GPIO_InitStructure.Pins = PIN_OLED_DC;
    GPIO_Init(PORT_OLED_DC, &GPIO_InitStructure);
    //GPIO_RES初始化设置
    GPIO_InitStructure.Pins = PIN_OLED_RES;
    GPIO_Init(PORT_OLED_RES, &GPIO_InitStructure);
    OLED_RES_LOW;
    Delay_Ms(200);
    OLED_RES_HIGH;
#endif
//OLED初始化
void OLED_Init(void)
    #ifdef SW_I2C
    I2C_Init();
    #endif
    #ifdef HW_I2C
    I2C_Init();
    #endif
    #ifdef SW_SPI
    SPI_Initial();
    OLED_SPI_GPIO_Init();
    #endif
    #ifdef HW_SPI
    SPI_Initial();
    #endif
    Delay_Ms(200);
    OLED_Write_CMD(0xAE); //display off
    OLED_Write_CMD(0x00); //set low column address
    OLED_Write_CMD(0x10); //set high column address
    OLED_Write_CMD(0x40); //set start line address
    OLED_Write_CMD(0xB0); //set page address
    OLED_Write_CMD(0x81); //contract control
    OLED_Write_CMD(0xFF); //128
    OLED_Write_CMD(0xA1); //set segment remap
    OLED_Write_CMD(0xA6); //normal / reverse
    OLED_Write_CMD(0xA8); //set multiplex ratio(1 to 64)
    OLED_Write_CMD(0x3F); //1/32 duty
    OLED_Write_CMD(0xC8); //Com scan direction
    OLED_Write_CMD(0xD3); //set display offset
    OLED_Write_CMD(0xD5); //set osc division
    OLED_Write_CMD(0x80); //
    OLED_Write_CMD(0xD8); //set area color mode off
    OLED_Write_CMD(0x05); //
    OLED_Write_CMD(0xD9); //Set Pre-Charge Period
    OLED_Write_CMD(0xF1); //
    OLED_Write_CMD(0xDA); //set com pin configuartion
    OLED_Write_CMD(0x12); //
    OLED_Write_CMD(0xDB); //set Vcomh
    OLED_Write_CMD(0x30); //
    OLED_Write_CMD(0x8D); //set charge pump enable
    OLED_Write_CMD(0xAF); //turn on oled panel
运行测试
测试代码
CW32F030CxTx_HW_SPI_OLED.zip (261.26 KB)
打赏榜单
21ic小管家 打赏了 50.00 元 2022-08-10
理由:贡献奖
weifeng90| | 2022-8-8 08:43 | 只看该作者
GIF动图显示不完整
zhouminjie|  楼主 | 2022-8-8 16:37 | 只看该作者
拍视频时候没有拍完整
quickman| | 2022-9-5 16:04 | 只看该作者
可以使用dma驱动吗
quickman| | 2022-9-8 08:16 | 只看该作者
硬件SPI直接驱动不?
robertesth| | 2022-9-8 08:41 | 只看该作者
单片机驱动oled简单吗
fengm| | 2022-9-8 09:54 | 只看该作者
求SPI接法
hearstnorman323| | 2022-9-8 11:07 | 只看该作者
怎么提高刷屏速度
macpherson| | 2022-9-8 12:59 | 只看该作者
驱动oled 不管是SPI还是IIC为啥都是模拟的
qiufengsd| | 2022-9-8 14:10 | 只看该作者
驱动的OLED屏?
pentruman| | 2022-9-8 16:53 | 只看该作者
spi总线驱动是不是很流畅?
chenci2013| | 2022-9-10 19:16 | 只看该作者
SPI接口要写中断吗
isseed| | 2022-9-10 20:16 | 只看该作者
SPI驱动怎么用?
louliana| | 2022-9-10 21:21 | 只看该作者
oled spi方式 DC线接哪里
fengm| | 2022-9-11 12:23 | 只看该作者
ssd1306d的例程吗?
wangdezhi| | 2022-10-1 14:18 | 只看该作者
SPI驱动OLED
Bowclad| | 2022-10-4 18:59 | 只看该作者
求spi接法
发新帖 本帖赏金 50.00元(功能说明)我要提问
