[树莓派资料]
树莓派原理图及板载芯片资料分享
20399|57
最近咸鱼捡漏搞了点树莓派,都有不同程度的损坏,自己在尝试维修中。。。
下面是整理的树莓派各代的原理图(官方真抠搜,都只给一部分)
rpi_SCH_Zero_1p3_reduced.pdf (119.87 KB)
rpi_SCH_ZeroW_1p1_reduced.pdf (177.23 KB)
Raspberry-Pi-R2.0-Schematics-Issue2.2_027.pdf (155.33 KB)
rpi_SCH_1aplus_1p1_reduced.pdf (65.53 KB)
rpi_SCH_1bplus_1p2_reduced.pdf (123.45 KB)
rpi_SCH_2b_1p2_reduced.pdf (139.78 KB)
rpi_SCH_3b_1p2_reduced.pdf (74.94 KB)
rpi_SCH_3bplus_1p0_reduced.pdf (74.92 KB)
rpi_SCH_4b_4p0_reduced.pdf (329.77 KB)
树莓派声卡原理图-Wolfson-Audio-C.pdf (324.99 KB)
加个彩蛋
游客,如果您要查看本帖隐藏内容请回复
通宵敲代码|  楼主 | 2021-5-19 11:20 | 只看该作者
树莓派一代B+板载芯片数据整理,其他版本很多芯片都是相同的(博通也死抠,主控没手册没公开)
RCLAMP0524P Ultra Low Capacitance TVS Arrays.pdf (627.88 KB)
PAM2306 Dual High-Efficiency PWM Step-Down DC-DC Coverter.pdf (407.09 KB)
NCP1117 1.0 A Low−Dropout PositiveFixed and AdjustableVoltage Regulators.pdf.pdf (172.57 KB)
LP2980-N Micropower 50-mA Ultra-Low-Dropout Regulator in SOT-23 Package.pdf (1.45 MB)
LAN9512 USB 2.0 Hub and 10100 Ethernet Controller .pdf (631.47 KB)
DMMT5401 MATCHED PNP SMALL SIGNAL SURFACE MOUNTTRANSISTOR.pdf (99.6 KB)
DMG2305UXQ P-CHANNEL ENHANCEMENT MODE MOSFET.pdf (425.61 KB)
BCM2835-ARM-Peripherals.pdf (1.42 MB)
APX803_3-PIN MICROPROCESSOR RESET CIRCUIT_Rev_3.3.pdf (445.89 KB)
AP2331W 0.2A SINGLE CHANNEL CURRENT-LIMITED LOAD SWITCH.PDF (456.49 KB)
通宵敲代码|  楼主 | 2021-5-19 11:22 | 只看该作者
树莓派二代三代合并整理
AP2553W6 PRECISION ADJUSTABLE CURRENT-LIMITED POWER SWITCHES.PDF (1.96 MB)
AP7115 150mA LOW DROPOUT LINEAR REGULATOR WITH SHUTDOWN.pdf (293.78 KB)
BAV99 DUAL SURFACE MOUNT SWITCHING DIODE.PDF (80.7 KB)
BCM857BS PNP matched double transistor.pdf (46.2 KB)
BCM43143KMLGT Single-Chip IEEE 802.11bgn MAC PHY Radio with USB&SDIO Host Interf.pdf (1.55 MB)
BCM43438 Single-Chip Wifi BT and FM Receiver.pdf (1.31 MB)
DLP11SN900HL2L Datasheet.pdf (163.62 KB)
DMG1012T N-CHANNEL ENHANCEMENT MODE MOSFET.pdf (441.49 KB)
EDB8132B4PB-8D-F-R-Micron Embedded LPDDR2 SDRAM.pdf (1.87 MB)
ESD5384 5-Line HDMI Control Line__ESD Protection.pdf (284.31 KB)
FXL6408UMX Fully Configurable 8-Bit I2C Controlled GPIO Expander.pdf (805.84 KB)
LAN9514 USB 2.0 Hub and 10&100 Ethernet Controller.pdf (646.05 KB)
LAN9514 USB 2.0 Hub and 10_100__Ethernet Controller.pdf (881.36 KB)
MF1812 PTC Resettable Fuses.pdf (313.98 KB)
MMBT3904T 60V NPN SMALL SIGNAL TRANSISTOR IN SOT523.pdf (261.03 KB)
NC7WZ16 TinyLogic®UHS Dual Buffer.pdf (430.9 KB)
NCP6343 Synchronous Buck Converter Step Down 3.0A.pdf (950.45 KB)
NCP6343-3A Processor-Memory Supply with Dynamic Voltage Scaling.pdf (149.95 KB)
RT8088A 2.7MHz 3A Step-Down Converter with I2__C Interface.pdf (246.45 KB)
RT9741 100mΩ, 1.5A_0.7A High-Side Power Switches.pdf (230.79 KB)
NCP130BMX120TCG 300mA Very Low Dropout Bias Rail CMOS Voltage Regulator.pdf (157.29 KB)
树莓派四代好多芯片都没标注,手上暂时也没有板子,先上传几个
BAT54XV2.pdf (57.46 KB)
SMBJ5.0A.pdf (304.83 KB)
BCM2711-ARM Peripherals.pdf (1.26 MB)
2232736362| | 2021-6-10 11:44 | 只看该作者
感谢,尝试修修看
54212脑白金| | 2021-7-12 08:55 | 只看该作者
yoyue| | 2021-8-6 22:21 | 只看该作者
收集了这么多,辛苦了
于言| | 2021-8-8 22:46 | 只看该作者
谢谢分享
cynizy| | 2021-8-17 00:04 | 只看该作者
感谢大神分享
mj8abcd| | 2021-9-19 16:15 | 只看该作者
谢谢分享
369122197| | 2021-9-25 10:39 | 只看该作者
hao hao
mario813| | 2021-10-20 14:48 | 只看该作者
好东西谢谢
493326732| | 2021-11-3 17:11 | 只看该作者
66666666666666
superbanma| | 2021-11-4 11:45 | 只看该作者
不错不错,感谢分享!
dcbabcd| | 2021-11-13 18:35 | 只看该作者
大佬tql,想请问一下CPU右下角那个电阻阻值多少
493326732| | 2021-11-26 20:34 | 只看该作者
牛  厉害 感谢分享
493326732| | 2021-12-19 18:59 | 只看该作者
你好  请问有没有 树莓派4b 的完整图纸
675414668| | 2021-12-23 22:50 | 只看该作者
牛啊
通宵敲代码|  楼主 | 2021-12-25 09:52 | 只看该作者
没有,官方放出来的图纸都不全
我愿永远失忆| | 2021-12-30 14:48 | 只看该作者
谢谢分享
个人签名:年轻不是资本,奋斗才是良策!
303
