[资料分享]
ADS1115驱动程序--msp430f149
14053|3
xyz549040622|  楼主 | 2019-12-21 15:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* ADS1115.h
*  Created on: 2012-7-30
*      Author: Piao
#ifndef ADS1115_H_
#define ADS1115_H_
/**********ADDR宏定义***************/
#define ADDRESS_0  0x90   //ADDR PIN ->GND
#define ADDRESS_1  0x92   //ADDR PIN ->VDD
#define ADDRESS_2  0x94   //ADDR PIN ->SDA
#define ADDRESS_3  0x96   //ADDR PIN ->SCL
/************POINTER REGISTER*****************/
#define Pointer_0  0x00   //Convertion register
#define Pointer_1  0x01   //Config register
#define Pointer_2  0x02   //Lo_thresh register
#define Pointer_3  0x03   //Hi_thresh register
/************CONFIG REGISTER*****************/
#define OS_0   0x0000
#define OS_1   0x8000
#define MUX_0  0x0000  //AINp=AIN0, AINn=AIN1
#define MUX_1  0x1000  //AINp=AIN0, AINn=AIN3
#define MUX_2  0x2000  //AINp=AIN1, AINn=AIN3
#define MUX_3  0x3000  //AINp=AIN2, AINn=AIN3
#define MUX_4  0x4000  //AINp=AIN0, AINn=GND
#define MUX_5  0x5000  //AINp=AIN1, AINn=GND
#define MUX_6  0x6000  //AINp=AIN2, AINn=GND
#define MUX_7  0x7000  //AINp=AIN3, AINn=GND
#define PGA_0  0x0000   //FS=6.144V
#define PGA_1  0x0200   //FS=4.096V
#define PGA_2  0x0400  //FS=2.048V
#define PGA_3  0x0600  //FS=1.024V
#define PGA_4  0x0800  //FS=0.512V
#define PGA_5  0x0A00  //FS=0.256V
#define PGA_6  0x0C00  //FS=0.256V
#define PGA_7  0x0E00  //FS=0.256V
#define MODE_0 0x0000
#define MODE_1 0x0100
#define DR_0   0x0000   //Data Rate = 8
#define DR_1   0x0020   //Data Rate = 16
#define DR_2   0x0040   //Data Rate = 32
#define DR_3   0x0060   //Data Rate = 64
#define DR_4   0x0080   //Data Rate = 128
#define DR_5   0x00A0   //Data Rate = 250
#define DR_6   0x00C0   //Data Rate = 475
#define DR_7   0x00E0   //Data Rate = 860
#define COMP_MODE_0  0x0000
#define COMP_MODE_1  0x0010
#define COMP_POL_0   0x0000
#define COMP_POL_1   0x0008
#define COMP_LAT_0   0x0000
#define COMP_LAT_1   0x0040
#define COMP_QUE_0   0x0000
#define COMP_QUE_1   0x0001
#define COMP_QUE_2   0x0002
#define COMP_QUE_3   0x0003
void Delay(void);
void Delay_1ms(void);
void Start(void);
void Stop(void);
void ACK(void);
void NACK(void);
unsigned char Check(void);
void Write_1_Byte(unsigned char DataByte);
unsigned char Write_N_Byte(unsigned char *writebuffer,unsigned char n);
unsigned char Read_1_Byte(void);
void Read_N_Byte(unsigned int *readbuff,unsigned char n);
void InitADS1115(void);
void WriteWord(void);
void ReadWord(void);
void ADS1115(void);
void ShowInt(long int x);
#endif /* ADS1115_H_ */
#include <MSP430F149.h>
#include "ADS1115.h"
*   ADDR---> GND
*   VDD ---> 3.3V
*   SCL ---> P2.6
*   SDA ---> P2.7
*   AINp=AIN0, AINn=GND
/***************引脚定义*****************/
#define SCL              0x40
#define SDA              0x80
#define SCL_SEL          P2SEL &= ~SCL
#define SCL_DDR_OUT           P2DIR |= SCL
#define SCL_OUT          P2OUT
#define SCL_H             SCL_OUT |= SCL
#define SCL_L                  SCL_OUT &= ~SCL
#define SDA_SEL          P2SEL &= ~SDA
#define SDA_DDR_OUT            P2DIR |= SDA
#define SDA_DDR_IN       P2DIR &=  ~SDA
#define SDA_OUT          P2OUT
#define SDA_IN           P2IN
#define SDA_H             SDA_OUT |= SDA
#define SDA_L                   SDA_OUT &= ~SDA
#define TRUE   1
#define FALSE  0
/*************ADDR Initial********************/
#define ADDRESS    ADDRESS_0   //ADDR PIN ->GND
#define ADDRESS_W  ADDRESS |0x00  //写地址
#define ADDRESS_R  ADDRESS|0x01    //读地址
/*************Config Initial*********************/
#define OS         OS_1
#define MUX        MUX_4      //AINp=AIN0, AINn=GND
#define PGA        PGA_0      //FS=6.144V
#define DR         DR_7       //Data Rate = 860
#define COMP_QUE   COMP_QUE_3
unsigned int Config;
unsigned char Writebuff[4],Readbuff[3];
unsigned int Result[2];
int D_ADS; //转换的数字量
float VIN_DAS; //输入的电压值
unsigned char  t_DAS;
int  Format[5]={0};  //转换的数字量转换成十进制
函数名称:delay
功    能:延时约15us的时间
参    数:无
返回值  :无
void Delay(void)
    unsigned char i;
    for(i = 0;i < 15;i++)
      _NOP();
/******************延时1ms的时间*********************/
        unsigned char i;
        for(i = 150;i > 0;i--)          _NOP();
函数名称:Start
功    能:完成IIC的起始条件操作
参    数:无
返回值  :无
void Start(void)
        SCL_H;
        SDA_H;
        Delay();
        SDA_L;
        Delay();
        SCL_L;
        Delay();
函数名称:Stop
功    能:完成IIC的终止条件操作
参    数:无
返回值  :无
void Stop(void)
        SDA_L;
        Delay();
        SCL_H;
        Delay();
        SDA_H;
        Delay();
函数名称:ACK
功    能:完成IIC的主机应答操作
参    数:无
返回值  :无
void ACK(void)
        SDA_L;
        _NOP(); _NOP();
        SCL_H;
        Delay();
        SCL_L;
        _NOP(); _NOP();
        SDA_H;
        Delay();
函数名称:NACK
功    能:完成IIC的主机无应答操作
参    数:无
返回值  :无
void NACK(void)
        SDA_H;
        _NOP(); _NOP();
        SCL_H;
        Delay();
        SCL_L;
        _NOP(); _NOP();
        SDA_L;
        Delay();
/**********检查应答信号函数******************/
/*如果返回值为1则证明有应答信号,反之没有*/
函数名称:Check
功    能:检查从机的应答操作
参    数:无
返回值  :从机是否有应答:1--有,0--无
    unsigned char slaveack;
    SDA_H;
    _NOP(); _NOP();
    SCL_H;
    _NOP(); _NOP();
    SDA_DDR_IN;
    _NOP(); _NOP();
    slaveack = SDA_IN&SDA;   //读入SDA数值
    SCL_L;
    Delay();
    SDA_DDR_OUT;
    if(slaveack)    return FALSE;
    else            return TRUE;
/***************Write a Byte****************/
        int i;
        for(i=0;i<8;i++)
                if(DataByte&0x80)  //if((DataByte<<i)&0x80)
                  SDA_H;
                else
                  SDA_L;
        Delay();
        SCL_H;
        Delay();
        SCL_L;
        Delay();
        DataByte <<= 1;
        SDA_H;
        _NOP();
/***************Write N Byte****************/
        int i;
        for(i=0;i<n;i++)
                Write_1_Byte(*writebuffer);
                if(Check())
                        writebuffer ++;
                else
                        Stop();
                    return FALSE;
        Stop();
        return TRUE;
/***************Read a Byte****************/
    unsigned char data=0,FLAG, i;
    for(i=0;i<8;i++)
        SDA_H;
        Delay();
        SCL_H;
        SDA_DDR_IN; //端口为输入
        Delay();
        FLAG=SDA_IN& SDA;
        data <<= 1;
        if( FLAG)
           data |= 0x01;
        SDA_DDR_OUT;
        SCL_L;
        Delay();
    return data;
/***************Read N Byte****************/
void Read_N_Byte(unsigned int*readbuff,unsigned char n)
        unsigned char i;
        for(i=0;i<n;i++)
                readbuff[i]=Read_1_Byte();
                if(i==n-1)
                        NACK();  //不连续读字节
                else
                        ACK(); //连续读字节
        Stop();
/*****************初始化******************/
    SCL_SEL;
    SDA_SEL;
    SCL_DDR_OUT;
    SDA_DDR_OUT;
    SDA_H;
    Config = OS+MUX+PGA+DR+COMP_QUE;
    Writebuff[0]=ADDRESS_W;
    Writebuff[1]=Pointer_1;
    Writebuff[2]=Config/256;
    Writebuff[3]=Config%256;
    Readbuff[0]=ADDRESS_W;
    Readbuff[1]=Pointer_0;
    Readbuff[2]=ADDRESS_R;
/***************Write a Word***********************/
     int t;
     Start();   //写入4个字节
     do
          t=Write_N_Byte(Writebuff,4);
     }while(t==0);
/***************Read Word***********************/
void ReadWord(void)
    int t;
    Start();  //写入2个字节
    do
      t=Write_N_Byte(Readbuff,2);
    }while(t==0);
    Start();   //写入2个字节
    do
      t=Write_N_Byte(&Readbuff[2],1);
    }while(t==0);
    Read_N_Byte(Result,2);  //读出2个字节
/***************ADS1115********************/
void ADS1115(void)
    InitADS1115();
    WriteWord();
    Delay_1ms();
    ReadWord();
    D_ADS=Result[0]*256+Result[1];  //转换的数字量
    t_DAS=0;
    ShowInt(D_ADS);    //转换的数字量转换成十进制
    VIN_DAS=6.144*D_ADS/32768;  //输入的电压值
//用递归方法将正整数x转换为10进制格式
        if(x)
          Format[t_DAS]= x%10;
          t_DAS  ++;
          ShowInt(x/10);
ads1115驱动程序(msp430f149).doc (40.5 KB)
ayl439| | 2024-2-20 22:31 | 只看该作者
谢谢楼主分享
个人签名:qq群: 嵌入式系统arm初学者 224636155←← +→→点击-->小 i 精品课全集,21ic公开课~~←←→→点击-->小 i 精品课全集,给你全方位的技能策划~~←←
2841
