[M4]
STM32两个定时器同时工作,有一个定时器不工作怎么办?
5940|5
huzb11|  楼主 | 2017-4-6 16:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
串口3接GPS模块,串口2接GPRS模块。单独运行串口3  GPRS程序,工作正常,单独运行串口2  GPS程序也正常,两个程序同时运行,发现GPRS运行正常,GPS数据都为0,有时按一下按键,又有数据,但是数据不能更新,不知是定时器之间配制冲突了,还是中断优先级配制的问题引起的。哪位帮我分析一下。
这是串口2配制,复制串口3,更改的:
__align(8) u8 USART2_TX_BUF[USART2_MAX_SEND_LEN];
#ifdef USART2_RX_EN
u8 USART2_RX_BUF[USART2_MAX_RECV_LEN];
u16 USART2_RX_STA=0;
void USART2_IRQHandler(void)
        u8 res;
        if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET)
        res =USART_ReceiveData(USART2);
        if((USART2_RX_STA&(1<<15))==0)
                if(USART2_RX_STA<USART2_MAX_RECV_LEN)
                        //TIM_SetCounter(TIM7,0);
      TIM_SetCounter(TIM5,0);
                        if(USART2_RX_STA==0)
                                //TIM_Cmd(TIM7, ENABLE);
                        TIM_Cmd(TIM5, ENABLE);
                        USART2_RX_BUF[USART2_RX_STA++]=res;
                }else
                        USART2_RX_STA|=1<<15;
#endif
//3õê¼»ˉIO ′®¿ú2
//bound:2¨ìØÂê
void usart2_init(u32 bound)
        NVIC_InitTypeDef NVIC_InitStructure;
        USART_InitTypeDef USART_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
         USART_DeInit(USART2);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_USART2);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_USART2);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        USART_InitStructure.USART_BaudRate = bound;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_Init(USART2, &USART_InitStructure);
        USART_Cmd(USART2, ENABLE);
  USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
        NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2 ;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        TIM5_Int_Init(100-1,8400-1);
        USART2_RX_STA=0;
        TIM_Cmd(TIM5, DISABLE);
//′®¿ú2,printf oˉêy
//è·±£ò»′η¢Ëíêy¾Y2»3¬1yUSART2_MAX_SEND_LEN×Ö½ú
void u2_printf(char* fmt,...)
        u16 i,j;
        va_list ap;
        va_start(ap,fmt);
        vsprintf((char*)USART2_TX_BUF,fmt,ap);
        va_end(ap);
        i=strlen((const char*)USART2_TX_BUF);
        for(j=0;j<i;j++)
          while(USART_GetFlagStatus(USART2,USART_FLAG_TC)==RESET);
                USART_SendData(USART2,(uint8_t)USART2_TX_BUF[j]);
这是串口3配制:
u16 USART3_RX_STA=0;
void USART3_IRQHandler(void)
        u8 res;
        if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET)
        res =USART_ReceiveData(USART3);
        if((USART3_RX_STA&(1<<15))==0)
                if(USART3_RX_STA<USART3_MAX_RECV_LEN)
                        TIM_SetCounter(TIM7,0);//¼ÆêyÆ÷Çå¿Õ
                        if(USART3_RX_STA==0)
                        USART3_RX_BUF[USART3_RX_STA++]=res;
                }else
                        USART3_RX_STA|=1<<15;
#endif
//3õê¼»ˉIO ′®¿ú3
//bound:2¨ìØÂê
void usart3_init(u32 bound)
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
        USART_DeInit(USART3);  //¸′λ′®¿ú3
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource11,GPIO_AF_USART3);
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource10,GPIO_AF_USART3);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_10;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        USART_Init(USART3, &USART_InitStructure); //3õê¼»ˉ′®¿ú3
        USART_Cmd(USART3, ENABLE);
  USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
        NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
        TIM7_Int_Init(1000-1,8400-1);
        USART3_RX_STA=0;
        TIM_Cmd(TIM7, DISABLE);
//′®¿ú3,printf oˉêy
//è·±£ò»′η¢Ëíêy¾Y2»3¬1yUSART3_MAX_SEND_LEN×Ö½ú
void u3_printf(char* fmt,...)
        u16 i,j;
        va_list ap;
        va_start(ap,fmt);
        vsprintf((char*)USART3_TX_BUF,fmt,ap);
        va_end(ap);
        i=strlen((const char*)USART3_TX_BUF);//′Ë′η¢Ëíêy¾YμÄ3¤¶è
        for(j=0;j<i;j++)//Ñ-»··¢Ëíêy¾Y
          while(USART_GetFlagStatus(USART3,USART_FLAG_TC)==RESET);  //μè′yéÏ′Î′«êäíê3é
                USART_SendData(USART3,(uint8_t)USART3_TX_BUF[j]);          //·¢Ëíêy¾Yμ½′®¿ú3
以下是定时器7与定时器5的代码,原来两个模块接的都是定时器7,我把TIM7,直接变成TIM5,分开运行都正常。合并成一个工程后,发现调用函数,两个一起,只能运行一个模块。我注释任意一个函数,留下一个函数,都能正常运行。请哪位帮我指点指点,究竟哪儿出了问题?感谢!
extern vu16 USART3_RX_STA;      //¶¨ê±Æ÷7ÅäoÏ′®¿ú3¿ØÖÆGPS
//¶¨ê±Æ÷7ÖD¶Ï·tÎñ3ìDò
void TIM7_IRQHandler(void)
        if (TIM_GetITStatus(TIM7, TIM_IT_Update) != RESET)//êǸüDÂÖD¶Ï
                USART3_RX_STA|=1<<15;        //±ê¼Ç½óêÕíê3é
                TIM_ClearITPendingBit(TIM7, TIM_IT_Update  );  //Çå3yTIM7¸üDÂÖD¶Ï±êÖ¾
                TIM_Cmd(TIM7, DISABLE);  //1رÕTIM7
void TIM7_Int_Init(u16 arr,u16 psc)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);//TIM7ê±Öóê1Äü
        //¶¨ê±Æ÷TIM73õê¼»ˉ
        TIM_TimeBaseStructure.TIM_Period = arr; //éèÖÃÔúÏÂò»¸ö¸üDÂê¼t×°èë»î¶ˉμÄ×Ô¶ˉÖØ×°ÔØ¼Ä′æÆ÷ÖüÆúμÄÖμ
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //éèÖÃóÃà′×÷ÎaTIMxê±ÖóÆμÂê3yêyμÄÔ¤·ÖÆμÖμ
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //éèÖÃê±Öó·Ö¸î:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIMÏòéϼÆêyÄ£ê½
        TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure); //¸ù¾YÖ¸¶¨μÄ2Îêy3õê¼»ˉTIMxμÄê±¼ä»ùêyμ¥λ
        TIM_ITConfig(TIM7,TIM_IT_Update,ENABLE ); //ê1ÄüÖ¸¶¨μÄTIM7ÖD¶Ï,ÔêDí¸üDÂÖD¶Ï
        NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0 ;//ÇàÕ¼óÅÏè¼¶0
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;                //×óóÅÏè¼¶1
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQí¨μàê1Äü
        NVIC_Init(&NVIC_InitStructure);        //¸ù¾YÖ¸¶¨μÄ2Îêy3õê¼»ˉVIC¼Ä′æÆ÷
extern vu16 USART2_RX_STA;    //        ¶¨ê±Æ÷5        ÅäoÏ′®¿ú2,¿ØÖÆGPRS
void TIM5_SetARR(u16 period)  //¶¨ê±Æ÷5
          TIM_SetCounter(TIM5,0);//¼ÆêyÆ÷Çå¿Õ
          TIM5->ARR&=0x00;       //ÏèÇåÔ¤×°ÔØÖüÆúÖμÎa0
          TIM5->ARR|= period;    //¸üDÂÔ¤×°ÔØÖüÆúÖμ
//¶¨ê±Æ÷5ÖD¶Ï·tÎñ3ìDò
void TIM5_IRQHandler(void)   //GPRS
        static u8 i=0;
        if(TIM_GetITStatus(TIM5, TIM_IT_Update) != RESET) //êǸüDÂÖD¶Ï
                TIM_ClearITPendingBit(TIM5, TIM_IT_Update  );  //Çå3yTIM5¸üDÂÖD¶Ï±êÖ¾
                if(Scan_Wtime!=0)//à¶Ñàé¨ÃèÄ£ê½
                        i++;
                        if(i==Scan_Wtime)
                                i=0;
                                Scan_Wtime = 0;
                                USART2_RX_STA|=1<<15;         //±ê¼Ç½óêÕíê3é
                                TIM_Cmd(TIM5, DISABLE);  //1رն¨ê±Æ÷5
                                TIM5_SetARR(100-1);      //ÖØDÂéèÖÃÎa10msÖD¶Ï
                else//·Çà¶Ñàé¨ÃèÄ£ê½
                         TIM_Cmd(TIM5, DISABLE);     //1رÕTIM5
//í¨óö¨ê±Æ÷ÖD¶Ï3õê¼»ˉ
//Õaàïê¼ÖÕÑ¡ÔñÎaAPB1μÄ2±¶£¬¶øAPB1Îa36M
//arr£o×Ô¶ˉ֨װÖμ¡£
//psc£oê±ÖóÔ¤·ÖÆμêy
void TIM5_Int_Init(u16 arr,u16 psc)
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);//TIM5ê±Öóê1Äü
        //¶¨ê±Æ÷TIM73õê¼»ˉ
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//TIMÏòéϼÆêyÄ£ê½
        TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure);            //¸ù¾YÖ¸¶¨μÄ2Îêy3õê¼»ˉTIMxμÄê±¼ä»ùêyμ¥λ
        TIM_ITConfig(TIM5,TIM_IT_Update,ENABLE );                  //ê1ÄüÖ¸¶¨μÄTIM5ÖD¶Ï,ÔêDí¸üDÂÖD¶Ï
        NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn;
        //NVIC_InitStructure.NVIC_IRQChannel = TIM6_DAC_IRQn  ;
        //NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0 ;   //ÇàÕ¼óÅÏè¼¶0
        //NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;                   //×óóÅÏè¼¶1
woshiftt| | 2017-6-24 12:46 | 只看该作者
中断向量配置的都是一样的,肯定有问题。
airwill| | 2017-12-17 21:16 | 只看该作者
中断中, 不要随便地关闭定时器
caijie001| | 2017-12-24 10:33 | 只看该作者
1楼说的有道理
奔跑的小咪| | 2019-3-27 15:57 | 只看该作者
请问楼主解决问题了吗?我最近也遇到了一模一样的问题啊。楼主方便的话可以分享下怎么解决吗
