发新帖本帖赏金 10.00元(功能说明)我要提问
12下一页
返回列表
一步一步完善我的设计(5):各个模块编码码
3037|25
keer_zu|  楼主 | 2016-6-8 11:34 | 只看该作者
AddTask.h
#ifndef __ADD_TASK_H__
#define __ADD_TASK_H__
#include <stdio.h>
#include <iostream>
#include <string>
#include <vector>
#include "json/json.h"
#include "InterfaceApi.h"
#include "Disptacher.h"
#include "Log4cxxWrapper.h"
#include "Task.h"
using namespace std;
class CommandDb;
class AddTask
        AddTask *next; // 1. "next" pointer in the base class
protected:
        vector<string> m_commandNames;
        TaskDb *m_taskDb;
        Disptacher *m_disptacher;
        CommandDb* m_commandDb;
public:
        AddTask();
        bool IsThisTaskType(const string cmdName)
                vector<string>::iterator it;
                for (it = m_commandNames.begin(); it != m_commandNames.end(); ++ it){
                        if(cmdName == *it)
                                return true;
                return false;
        virtual void GetInfo() = 0;
        virtual bool TaskSubmit(Task* task) = 0;
        void setNext(AddTask *n)
                next = n;
        void add(AddTask *n)
                if (next)
                        next->add(n);
                else
                        next = n;
        virtual void AddSpacificTask(Json::Value& value,AppServerSession *appServerSion)
                if(next != NULL)
                        next->AddSpacificTask(value,appServerSion);
                else {   // this command does not exist;
                        printf("error");
                        // TODO: log
        Task* BuildBasicTask(Json::Value& value);
        bool DoAppResponse(string commandName,AppServerSession *session,Task* task);
class AddVideoTask : public AddTask
        AddVideoTask();
public:
        virtual void GetInfo(){}
        virtual bool TaskSubmit(Task*);
        static AddVideoTask& GetInstance();
        virtual void AddSpacificTask(Json::Value& value,AppServerSession *appServerSion);
class AddDocTask : public AddTask
        AddDocTask();
public:
        static AddDocTask& GetInstance();
class AddDpptTask : public AddTask
        AddDpptTask();
public:
        static AddDpptTask& GetInstance();
class AddNoUseTsTask : public AddTask
        AddNoUseTsTask();
public:
        static AddNoUseTsTask& GetInstance();
#endif
打赏榜单
21ic小喇叭 打赏了 10.00 元 2016-06-12
理由:分享打赏
keer_zu|  楼主 | 2016-6-8 11:35 | 只看该作者
AddTask.cpp
#include "AddTask.h"
#include "TsManager.h"
#include "CommandDb.h"
#include "error.h"
using namespace cdy;
//extern CommandDb GCommandDb;
extern TaskDocumentDb GTaskDocumentDb;
extern TaskVideoDb GTaskVideoDb;
extern TaskDpptDb GTaskDpptDb;
extern TaskNoUseTsDb GTaskNoUseTsDb;
//==========================  AddTask ===========================
AddTask::AddTask()
        next = NULL;
        m_commandDb = &CommandDb::GetInstance();//&GCommandDb;
Task* AddTask::BuildBasicTask(Json::Value& value)
        Task *task;
        task = m_taskDb->GetTask();
        if(!value["priority"].isNull() && value["priority"].isIntegral()){
                task->SetPriority(value["priority"].asInt());
        } else {
                // TODO: LOG
                return NULL;
        if(!value["id"].isNull() && value["id"].isString()){
                task->SetTaskId(value["id"].asString());
        } else {
                // TODO: LOG
                return NULL;
        task->Init();
        task->SetCmdValue(value);
        task->SetDisptacher(m_disptacher);
        task->SetCommand(m_commandDb->GetCommand(value["command"].asString()));
        if(!value["host"].isNull() && value["host"].isString()){
                task->m_appTargetIp = value["host"].asString();
        } else {
                // TODO: log
                return NULL;
        if(!value["port"].isNull() && value["port"].isIntegral()){
                task->m_appTargetPort = value["port"].asInt();
        } else {
                //dsLog.Log(FALSE,LOGGER_ERROR,"Error message from application client. No port. :%s, [%s][%s][%d]\n",strRecv.c_str(),__FILE__,__PRETTY_FUNCTION__,__LINE__);
                return NULL;
        return task;
bool AddTask::DoAppResponse(string commandName,AppServerSession *session,Task* task)
        string msg;
        Command *cmd;
        Json::Value valueAppRes;
        LoggerWrapper dsLog= LoggerWrapper::GetInstance();
        cmd = m_commandDb->GetCommand(commandName);
        if(!cmd)
                return false;
        if(m_disptacher->DuplicateTaskCheck(task->GetTaskId())){
                cmd->BuildAppResponse(valueAppRes,0,"");
        } else {
                cmd->BuildAppResponse(valueAppRes,RET_E_REPEATED_TS_TRANS_TASK,"App task message id is repeated!");
                msg = valueAppRes.toStyledString() + '\0';
                session->SendMessage(msg);
                dsLog.Log(true,LOGGER_ERROR,"%s:%s:%d   App task message id is repeated!\n",__FILE__,__PRETTY_FUNCTION__,__LINE__);
                return false;
        return true;
//========================  AddVideoTask =========================
AddVideoTask& AddVideoTask::GetInstance()
        static  AddVideoTask instance_;
        return instance_;
AddVideoTask::AddVideoTask()
        m_commandDb->GetCommandNameInSpecificTaskType(VideoTask,m_commandNames);
        m_taskDb = &GTaskVideoDb;
        m_disptacher = &VideoDisptacher::GetInstance();//&GVideoDisptacher;
void AddVideoTask::AddSpacificTask(Json::Value& value,AppServerSession *appServerSion)
        Task* task;
        if(IsThisTaskType(value["command"].asString())) {
                task = BuildBasicTask(value);
                if(!task)
                        return;
                if(!DoAppResponse(value["command"].asString(),appServerSion,task))
                        return;
                if(!TaskSubmit(task)){
                return;
        } else {
                AddTask::AddSpacificTask(value,appServerSion);
bool AddVideoTask::TaskSubmit(Task* task)
        return m_disptacher->Submit(task);
//=========================  AddDocTask ==========================
AddDocTask& AddDocTask::GetInstance()
        static  AddDocTask instance_;
        return instance_;
AddDocTask::AddDocTask()
        m_commandDb->GetCommandNameInSpecificTaskType(DocTask,m_commandNames);
        m_taskDb = &GTaskDocumentDb;
        m_disptacher = &DocDisptacher::GetInstance();//GDocDisptacher;
void AddDocTask::AddSpacificTask(Json::Value& value,AppServerSession *appServerSion)
        Task* task;
                if(!task)
                        return;
                TaskDocument* td = dynamic_cast<TaskDocument*>(task);
                if(!value["docServerType"].isNull()){
                        if(value["docServerType"].isString() &&
                                (value["docServerType"].asString() == "LINUX" ||
                                value["docServerType"].asString() == "WPS" ||
                                value["docServerType"].asString() == "OFFICE" )
                                td->SetIsSpecific(true);
                        else
                                td->SetIsSpecific(false);
                } else {
                        return;
                return;
        } else {
bool AddDocTask::TaskSubmit(Task* task)
//========================  AddDpptTask ==========================
AddDpptTask& AddDpptTask::GetInstance()
        static  AddDpptTask instance_;
        return instance_;
AddDpptTask::AddDpptTask()
        m_commandDb->GetCommandNameInSpecificTaskType(DpptTask,m_commandNames);
        m_taskDb = &GTaskDpptDb;
        m_disptacher = &DpptDisptacher::GetInstance();//&GDpptDisptacher;
void AddDpptTask::AddSpacificTask(Json::Value& value,AppServerSession *appServerSion)
        Task *task;
        if(IsThisTaskType(value["command"].asString())){
                if(!task)
                        return;
                        return;
                return;
        } else {
bool AddDpptTask::TaskSubmit(Task* task)
//====================== AddNoUseTsTask ===========================
AddNoUseTsTask& AddNoUseTsTask::GetInstance()
        static  AddNoUseTsTask instance_;
        return instance_;
AddNoUseTsTask::AddNoUseTsTask()
        m_commandDb->GetCommandNameInSpecificTaskType(NoTsTask,m_commandNames);
        m_taskDb = &GTaskNoUseTsDb;
void AddNoUseTsTask::AddSpacificTask(Json::Value& value,AppServerSession *appServerSion)
        Task* task;
                if(!task)
                        return;
                        return;
                return;
        } else {
bool AddNoUseTsTask::TaskSubmit(Task* task)
         Json::Value appResult;
         bool ret;
         string appResultMsg;
         SessionManager& sm = SessionManager::GetInstance();
        Command* cmd = task->GetCommand();
        if(cmd->IsProvidedResult()){
                ret = cmd->BuildAppResult(task->GetCmdValue(),appResult);
                if(!ret){
                        return false;
                appResultMsg = appResult.toStyledString();
                sm.SendAppMessage(task->m_appTargetIp,task->m_appTargetPort,appResultMsg,task);
keer_zu|  楼主 | 2016-6-8 11:36 | 只看该作者
CommandDb.h
#ifndef __COMMAND_DB_H__
#define __COMMAND_DB_H__
#include <string>
//#include "Task.h"
typedef enum{
        DocTask = 0,
        VideoTask,
        DpptTask,
        NoTsTask
}TaskType;
class Command
protected:
        string m_commandName;
        TsProperty m_tsProperty;
        bool m_isUseTs;
        TsType m_tsType;
        TaskType m_taskType;
        bool m_isProvidedResult;
        string m_tsResultName;
public:
        Command();
        virtual ~Command();
        string GetCommansName(){ return m_commandName;}
        bool IsProvidedResult(){return m_isProvidedResult;}
        TsType GetTsType(){return m_tsType;}
        TaskType GetTaskType(){return m_taskType;}
        string GetTaskResultName(){return m_tsResultName;};
        virtual bool BuildTsCmd(const Json::Value& appCmd,Json::Value& tsCmd);
        virtual bool BuildTsResponse(const Json::Value& tsResult,Json::Value& tsResponse);
        virtual bool BuildAppResult(const Json::Value& tsResult,Json::Value& appResult);
        virtual bool BuildAppResult(ErrorInfo info,Json::Value& appResult);
        virtual bool  BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail) = 0;
///////////////////////////////// specific command //////////////////////////////////////
class CommandServerStatus : public Command
public:
        CommandServerStatus()
                m_commandName = "server_status_task";
                m_isUseTs = false;
                m_taskType = NoTsTask;
                m_isProvidedResult = true;
        ~CommandServerStatus();
        virtual bool  BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail);
        virtual bool BuildAppResult(const Json::Value& appCmd,Json::Value& appResult);
class CommandVideoMessage : public Command
public:
        CommandVideoMessage()
                m_commandName = "video_message_task";
                m_isUseTs = true;
                m_tsType = TS_VIDEO;
                m_tsProperty = TS_LIGHT;
                m_taskType = VideoTask;
                m_tsResultName = "Message";
        ~CommandVideoMessage(){}
class CommandVideoTrans : public Command
public:
        CommandVideoTrans()
                m_commandName = "video_trans_task";
                m_isUseTs = true;
                m_tsProperty = TS_HEAVY;
                m_tsResultName = "Transfer";
        ~CommandVideoTrans(){}
class CommandPrintScreen : public Command
public:
        CommandPrintScreen()
                m_commandName = "print_screen_task";
                m_isUseTs = true;
                m_tsResultName = "CapVideo";
        ~CommandPrintScreen(){}
class CommandVideoCut : public Command
public:
        CommandVideoCut()
                m_commandName = "video_cut_task";
                m_isUseTs = true;
                m_tsResultName = "VideoCut";
class CommandVideoMerge : public Command
public:
        CommandVideoMerge()
                m_commandName = "video_merge_task";
                m_isUseTs = true;
                m_tsResultName = "VideoMerge";
class CommandDocTrans : public Command
public:
        CommandDocTrans()
                m_commandName = "doc_trans_task";
                m_isUseTs = true;
                m_taskType = DocTask;
        static bool GetServerTypes(vector<string>& CommandNames)
                CommandNames.push_back("DOC_WPS");
                CommandNames.push_back("DOC_OFFICE");
                CommandNames.push_back("DOC_LINUX");
class CommandDynamicPptTrans : public Command
public:
        CommandDynamicPptTrans()
                m_commandName = "dynamic_ppt_trans_task";
                m_isUseTs = true;
                m_tsType = TS_DYNAMIC_PPT;
                m_taskType = DpptTask;
        static void GetServerTypes(vector<string>& CommandNames)
                CommandNames.push_back("DYNAMIC_PPT");
class CommandTaskProgress : public Command
public:
        CommandTaskProgress()
                m_commandName = "task_progress_request";
                m_isUseTs = false;
/////////////////////////////////  CommandDb  ///////////////////////////////////////
class CommandDb
        CommandDb();
public:
        static CommandDb& GetInstance()
                static CommandDb instance_;
                return instance_;
        ~CommandDb();
        bool AddCommand(Command* cmd);
        bool GetCommandNameInSpecificTaskType(TaskType taskType,vector<string>& CommandNames);
        bool GetResultNameInSpecificTaskType(TaskType taskType,vector<string>& CommandNames);
        Command* GetCommand(string cmdName);
private:
        map<string,Command*> m_commands;
#endif
keer_zu|  楼主 | 2016-6-8 11:37 | 只看该作者
CommandDb.cpp
CommandServerStatus GCmdServerStatus;
CommandVideoMessage GCmdVideoMessage;
CommandVideoTrans GCmdVideoTrans;
CommandPrintScreen GCmdPrintScreen;
CommandVideoMerge GCmdVideoMerge;
CommandDocTrans GCmdDocTrans;
CommandDynamicPptTrans GCmdDynamicPptTrans;
//CommandDb GCommandDb;
////////////////////////////////////// Command //////////////////////////////////////////
Command::Command()
Command::~Command()
bool Command::BuildTsCmd(const Json::Value& appCmd,Json::Value& tsCmd)
        return true;
bool Command::BuildTsResponse(const Json::Value& tsResult,Json::Value& tsResponse)
        return true;
bool Command::BuildAppResult(ErrorInfo info,Json::Value& appResult)
        return true;
bool Command::BuildAppResult(const Json::Value& tsResult,Json::Value& appResult)
//////////////////////////////////// CommandServerStatus ///////////////////////////////////////////
//CommandServerStatus::CommandServerStatus()
CommandServerStatus::~CommandServerStatus()
bool  CommandServerStatus::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
bool CommandServerStatus::BuildAppResult(const Json::Value& appCmd,Json::Value& appResult)
        return true;
////////////////////////////////////// CommandVideoMessage //////////////////////////////////////
bool  CommandVideoMessage::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
////////////////////////////////////// CommandVideoTrans ///////////////////////////////////////
bool  CommandVideoTrans::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
///////////////////////////////////// CommandPrintScreen ///////////////////////////////////////
bool CommandPrintScreen::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
///////////////////////////////////// CommandVideoCut /////////////////////////////////////////
bool CommandVideoCut::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
///////////////////////////////////// CommandVideoMerge //////////////////////////////////////
bool CommandVideoMerge::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
//////////////////////////////////// CommandDocTrans ////////////////////////////////////////
bool CommandDocTrans::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
/////////////////////////////////// CommandDynamicPptTrans //////////////////////////////////
bool CommandDynamicPptTrans::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
///////////////////////////////// CommandTaskProgress ///////////////////////////////////////
bool CommandTaskProgress::BuildAppResponse(Json::Value& appResponse,unsigned int errorCode,string ErrorDetail)
        return true;
/////////////////////////////////////// CommandDb ////////////////////////////////////////
CommandDb::CommandDb()
        AddCommand(&GCmdServerStatus);
        AddCommand(&GCmdVideoMessage);
        AddCommand(&GCmdVideoTrans);
        AddCommand(&GCmdPrintScreen);
        AddCommand(&GCmdVideoMerge);
        AddCommand(&GCmdDocTrans);
        AddCommand(&GCmdDynamicPptTrans);
CommandDb::~CommandDb()
bool CommandDb::AddCommand(Command* cmd)
        m_commands[cmd->GetCommansName()] = cmd;
        return true;
bool CommandDb::GetCommandNameInSpecificTaskType(TaskType taskType,vector<string>& CommandNames)
        map<string,Command *>::iterator it;
        for(it=m_commands.begin();it!=m_commands.end();++it){
                if(it->second->GetTaskType() == taskType)
                        CommandNames.push_back(it->first);
        return true;
bool CommandDb::GetResultNameInSpecificTaskType(TaskType taskType,vector<string>& CommandNames)
        if(taskType == NoTsTask){
                return false;
        if(taskType == DpptTask){
                CommandDocTrans::GetServerTypes(CommandNames);
                return true;
        if(taskType == DocTask){
                CommandDynamicPptTrans::GetServerTypes(CommandNames);
                return true;
                        CommandNames.push_back(it->second->GetTaskResultName());
        return true;
Command* CommandDb::GetCommand(string cmdName)
        if(m_commands.find(cmdName) != m_commands.end()){
                return m_commands[cmdName];
        } else {
                return NULL;
keer_zu|  楼主 | 2016-6-8 11:38 | 只看该作者
#ifndef __DISPTACHER_H__
#define __DISPTACHER_H__
#include <stdio.h>
#include <iostream>
#include <string>
#include <vector>
//#include "InterfaceApi.h"
#include "TsQueue.h"
#include "TaskQueue.h"
class Disptacher {
public:
        Disptacher(){}
        bool DuplicateTaskCheck(string id)
                return !(m_taskRunQueue->CheckSameTaskId(id) || m_taskWaitQueue->CheckSameTaskId(id));
        virtual bool Submit(Task *task) = 0;
protected:
        TaskWaitQueue* m_taskWaitQueue;
        TaskRunQueue* m_taskRunQueue;
        map<string,TsQueue*>m_tsQueues;
        //vector<string> m_commandNames;
class DocDisptacher : public Disptacher
        map<int,string> m_tsPriority;
        DocDisptacher();
public:
        static DocDisptacher& GetInstance();
        virtual bool Submit(Task *task);
        bool GetDocTsPriority();
class VideoDisptacher : public Disptacher
        VideoDisptacher();
public:
        static VideoDisptacher& GetInstance();
class DpptDisptacher : public Disptacher
        DpptDisptacher();
public:
        static DpptDisptacher& GetInstance();
#endif
Disptacher.h
keer_zu|  楼主 | 2016-6-8 11:39 | 只看该作者
Disptacher.cpp
//#include "TsManager.h"
//#include "CommandDb.h"
#include "error.h"
#include <algorithm>
#include <memory>
#include "ConfigManager.h"
//using namespace std;
extern TaskWaitQueue GDocTaskWaitQueue;
extern TaskWaitQueue GVideoTaskWaitQueue;
extern TaskWaitQueue GDpptTaskWaitQueue;
extern TaskWaitQueue GNoTsTaskTaskWaitQueue;
extern TaskRunQueue GDocTaskRunQueue;
extern TaskRunQueue GVideoTaskRunQueue;
extern TaskRunQueue GDpptTaskRunQueue;
extern TaskRunQueue GNoTsTaskRunQueue;
extern TsQueue GVideoTsQueue;
extern TsQueue GDocOpenofficeTsQueue;
extern TsQueue GDocWpsTsQueue;
extern TsQueue GDocOfficeTsQueue;
extern TsQueue GDpptTsQueue;
string ToUpperString(string str)
        string tmpstr= str;
        transform(tmpstr.begin(), tmpstr.end(), tmpstr.begin(), (int (*)(int))toupper);
        return tmpstr;
string ToLowerString(string str)
        string tmpstr= str;
        transform(tmpstr.begin(), tmpstr.end(), tmpstr.begin(), (int (*)(int))tolower);
        return tmpstr;
bool CheckNoSameName(map<int,string>& mp, int count)
        for(int i=0;i<count-1;i++){
                for(int j=i+1;j<count;j++){
                        if(mp[i] == mp[j]){
                                return false;
        return true;
//////////////////////////////// Disptacher //////////////////////////////////
//////////////////////////////// DocDisptacher ///////////////////////////////
DocDisptacher::DocDisptacher()
        m_taskWaitQueue = &GDocTaskWaitQueue;
        m_taskRunQueue = &GDocTaskRunQueue;
        GetDocTsPriority();
        m_tsQueues["linux"] = &GDocOpenofficeTsQueue;
        m_tsQueues["wps"] = &GDocWpsTsQueue;
        m_tsQueues["office"] = &GDocOfficeTsQueue;
        GetDocTsPriority();
DocDisptacher& DocDisptacher::GetInstance()
        static DocDisptacher instance_;
        return instance_;
bool DocDisptacher::Submit(Task *task)
        TsQueue* tsq;
        TransServer* ts = NULL;
        int i;
        Json::Value tsCmd;
        Json::Value appResponse;
        Command* cmd;
        bool ret;
        if(task->m_triedTimes >= task->m_maxTryTimes){
                ret = cmd->BuildAppResponse(appResponse,errorCode, string ErrorDetail);
        for(i = 0;i < m_tsPriority.size();i ++){
                tsq = m_tsQueues[m_tsPriority[0]];
                ts = tsq->GetTsIdle();
                if(ts){
                        task->m_alreadyTriedTsType.push_back(i);
                        task->m_alreadyTriedTsId.push_back(ts->GetId());
                        break;
        if(ts){
                if(!cmd->BuildTsCmd(task->GetCmdValue(),tsCmd)){
                        dsLog.Log(true,LOGGER_ERROR,"build doc ts cmd error !!!!!, [%s][%s][%d]\n",__FILE__,__PRETTY_FUNCTION__,__LINE__);
                        return false;
                ts->SetTask(task);
                string tsMsg = tsCmd.toStyledString() + '\0';
                TsSession* session = ts->GetSession();
                session->SendMessage(tsMsg);
                task->m_triedTimes += 1;
                m_taskRunQueue->PushTask(task,session);
        } else {
                m_taskWaitQueue->PushTask(task);
#define MAX_DOCUMENT_SEVER_TYPE_NUM 3
bool DocDisptacher::GetDocTsPriority()
        Json::Value  value;
        std::auto_ptr<Json::Reader> pJsonParser(new Json::Reader(Json::Features::strictMode()));
        string strTsPriority = "\"TsPriority\":" + ConfigManager::GetTsPriority();
        string strWholeJson = "{"+strTsPriority+"}";
        //string strPriorityArray[MAX_DOCUMENT_SEVER_TYPE_NUM];
        map<string,TsQueue*> tsQueue;
        if(pJsonParser->parse(strWholeJson,value)){
                const Json::Value TsPriority = value["TsPriority"];
                if((!value["TsPriority"].isNull()) && (value["TsPriority"].isArray()) && (MAX_DOCUMENT_SEVER_TYPE_NUM == TsPriority.size()) ){
                        for (unsigned int i = 0; i < TsPriority.size(); i++){
                                if(TsPriority[i].isString()){
                                        if(( "LINUX" == ToUpperString(TsPriority[i].asString()))||( "OFFICE" == ToUpperString(TsPriority[i].asString()))||( "WPS" == ToUpperString(TsPriority[i].asString()))){
                                                m_tsPriority[i] = TsPriority[i].asString();
                                        } else {
                                                dsLog.Log(true,LOGGER_ERROR,"error config file. Invalid TsPriority format  . :%s , [%s][%s][%d]\n",strTsPriority.c_str(),__FILE__,__PRETTY_FUNCTION__,__LINE__);
                                                return false;
                                } else {
                                        return false;
                        if(!CheckNoSameName(m_tsPriority,MAX_DOCUMENT_SEVER_TYPE_NUM)){
                                return false;
                } else{
                        return false;
        } else{
                return false;
        return true;
///////////////////////////////// VideoDisptacher /////////////////////////////
VideoDisptacher::VideoDisptacher()
        m_taskWaitQueue = &GVideoTaskWaitQueue;
        m_taskRunQueue = &GVideoTaskRunQueue;
        m_tsQueues["Video1"] = &GVideoTsQueue;
VideoDisptacher& VideoDisptacher::GetInstance()
        static VideoDisptacher instance_;
        return instance_;
bool VideoDisptacher::Submit(Task *task)
        TsQueue* tsq;
        Json::Value tsCmd;
        tsq = m_tsQueues["Video1"];
        if(ts){
                        return false;
        } else {
//////////////////////////////// DpptDisptacher ///////////////////////////////
DpptDisptacher::DpptDisptacher()
        m_taskWaitQueue = &GDpptTaskWaitQueue;
        m_taskRunQueue = &GDpptTaskRunQueue;
        m_tsQueues["Dppt1"] = &GDpptTsQueue;
DpptDisptacher& DpptDisptacher::GetInstance()
        static DpptDisptacher instance_;
        return instance_;
bool DpptDisptacher::Submit(Task *task)
        TsQueue* tsq;
        Json::Value tsCmd;
        tsq = m_tsQueues["Dppt1"];
        if(ts){
                        return false;
        } else {
keer_zu|  楼主 | 2016-6-8 11:40 | 只看该作者
Message.h
#ifndef __MESSAGE_H__
#define __MESSAGE_H__
#include "TaskResult.h"
//#include "TsInterface.h"
typedef enum{
        TsRegistMsg = 0,
        TsResultMsg,
        TsUpdateMsg,
        TsLinkResponse
}TsMsgType;
class Message
public:
        Message(){}
        virtual ~Message(){}
class AppMessage : public Message
public:
class TsMessage : public Message
protected:
        string m_type;
        TsMsgType m_tsMsgType;
        string m_serverType;
public:
        virtual ~TsMessage(){}
        TsMessage(){}
        TsMsgType GetTsMsgType(){return m_tsMsgType;}
        string GetServerType(){return m_serverType;}
class TsResultMessage : public TsMessage
public:
        TsResultMessage(string serverType)
                m_type = "TransResult";
                m_tsMsgType = TsUpdateMsg;
                m_serverType = serverType;
public:
        //string m_serverType;
class TsRegistMessage : public TsMessage
public:
        TsRegistMessage(string serverType)
                m_type = "SvrRegister";
                m_tsMsgType = TsRegistMsg;
        bool BuildResponse(int errCode,const string& errorDetial,string& response);
class TsUpdateMessage : public TsMessage
public:
        TsUpdateMessage(string serverType)
                m_type = "TaskProgress";
class TsMessageDb
        TsMessageDb();
public:
        static TsMessageDb& GetInstance()
                static TsMessageDb instance_;
                return instance_;
        bool AddMessage(TsMessage *msg);
        bool GetServerTypeInSpecificType(TsMsgType msgType,vector<string>& tsMessages);
        TsMessage* GetMessage(TsMsgType msgType,string serverType);
private:
        vector<TsMessage *> m_tsMessages;
class TsMessageHandle
        TsMessageHandle* next;
public:
        TsMessageHandle(){}
        bool IsThisMsg(string type)
                if(type == m_type)
                        return true;
                else
                        return false;
        void setNext(TsMessageHandle *n)
                next = n;
        void add(TsMessageHandle *n)
                if (next)
                        next->add(n);
                else
                        next = n;
        virtual void SpacificHandle(Json::Value& value,TsSession* tsSession)
                if(next != NULL)
                        next->SpacificHandle(value,tsSession);
                        printf("error");
                        // TODO: log
protected:
        string m_type;
class TsRegistMessageHandle : public TsMessageHandle
        ITsRegister* m_register;
        TsRegistMessageHandle(ITsRegister* reg)
                m_register = reg;
public:
        virtual void SpacificHandle(Json::Value& value,TsSession* tsSession);
        static TsRegistMessageHandle& GetInstance(ITsRegister* reg)
                static  TsRegistMessageHandle instance_(reg);
                return instance_;
class TsResultMessageHandle : public TsMessageHandle
        //ITaskResult* m_taskResult;
        TsResultMessageHandle(/*ITaskResult* tr*/)
                //m_taskResult = tr;
                m_taskResult = &DocTaskResult::GetInstance();
                VideoTaskResult &videoTaskResult = VideoTaskResult::GetInstance();
                DpptTaskResult &dpptTaskResult = DpptTaskResult::GetInstance();
                m_taskResult->add(&videoTaskResult);
                m_taskResult->add(&dpptTaskResult);
public:
        static TsResultMessageHandle& GetInstance()
                static  TsResultMessageHandle instance_;
                return instance_;
class TsUpdateMessageHandle : public TsMessageHandle
        ITsUpdateInfo* m_updataInfo;
        TsUpdateMessageHandle(ITsUpdateInfo* ui):m_updataInfo(ui)
                {m_type = "TaskProgress";}
public:
        static TsUpdateMessageHandle& GetInstance(ITsUpdateInfo* ui)
                static  TsUpdateMessageHandle instance_(ui);
                return instance_;
class MessageAnalyzer
public:
class TsMessageAnalyzer : public MessageAnalyzer,public ITsNewFrame
        TsMessageAnalyzer();
        //TaskResult* m_taskResult;
        TsMessageHandle* m_messageHandle;
public:
        ~TsMessageAnalyzer();
        static TsMessageAnalyzer& GetInstance();
        virtual void OnNewFrame(TsSession* tsServerSion,const string frame);
class AppMessageAnalyzer : public MessageAnalyzer,public IAppNewFrame
        AppMessageAnalyzer();
        AddTask* m_addTask;
public:
        ~AppMessageAnalyzer();
        static AppMessageAnalyzer& GetInstance();
        virtual void OnNewFrame(AppServerSession *appServerSion,string frame);
class testITsRegister : public ITsRegister
public:
        virtual void OnRegister(Json::Value& value,TsSession *session){}
#endif
keer_zu|  楼主 | 2016-6-8 11:41 | 只看该作者
Message.cpp
#include "Message.h"
#include <memory>.
TsResultMessage  tsDpptResult("DYNAMIC_PPT");
TsResultMessage  tsDocWindowsResult("DOC_WINDOWS");
TsResultMessage  tsDocResult("DOC");
TsResultMessage  tsDocWpsResult("DOC_WPS");
TsResultMessage  tsTransferResult("Transfer");
TsResultMessage  tsVideoCutResult("VideoCut");
TsResultMessage  tsVideoMergeResult("VideoMerge");
TsResultMessage  tsCapVideoResult("CapVideo");
TsResultMessage  tsMessageResult("Message");
TsRegistMessage  tsRegistMessage("");
//TsLinkResponseMessage tsLinkResponseMessage("");
TsUpdateMessage tsUpdateMessage("");
//////////////////////////////// TsRegistMessage /////////////////////////////////////////
bool TsRegistMessage::BuildResponse(int errCode,const string& errorDetial,string& response)
        return true;
TsMessageDb::TsMessageDb()
        AddMessage(&tsDpptResult);
        AddMessage(&tsDocWindowsResult);
        AddMessage(&tsDocResult);
        AddMessage(&tsDocWpsResult);
        AddMessage(&tsTransferResult);
        AddMessage(&tsVideoCutResult);
        AddMessage(&tsVideoMergeResult);
        AddMessage(&tsCapVideoResult);
        AddMessage(&tsMessageResult);
        AddMessage(&tsRegistMessage);
//        AddMessage(&tsLinkResponseMessage);
        AddMessage(&tsUpdateMessage);
bool TsMessageDb::AddMessage(TsMessage * msg)
        m_tsMessages.push_back(msg);
        return true;
bool TsMessageDb::GetServerTypeInSpecificType(TsMsgType msgType, vector < string > & tsMessages)
        vector<TsMessage *>::iterator t ;
        for(t=m_tsMessages.begin(); t!=m_tsMessages.end(); t++){
                if((*t)->GetTsMsgType() == msgType)
                        tsMessages.push_back((*t)->GetServerType());
        return true;
TsMessage* TsMessageDb::GetMessage(TsMsgType msgType, string serverType)
        TsMessage* message = NULL;
                if((*t)->GetTsMsgType() == msgType && (*t)->GetServerType() == serverType){
                        message = *t;
                        break;
        return message;
//////////////////////////////// TsRegistMessageHandle /////////////////////////////
void TsRegistMessageHandle::SpacificHandle(Json::Value& value,TsSession* tsSession)
        if(IsThisMsg(value["type"].asString())){
                if(m_register != NULL){
                        m_register->OnRegister(value, tsSession);
        } else {
                TsMessageHandle::SpacificHandle(value,tsSession);
//////////////////////////////// TsResultMessageHandle /////////////////////////////////
void TsResultMessageHandle::SpacificHandle(Json::Value& value,TsSession* tsSession)
                if((!value["servertype"].isNull()) &&  (value["servertype"].isString())){
                        m_taskResult->SpacificTaskResult(value,tsSession);
                } else {
        } else {
////////////////////////////// TsUpdateMessageHandle //////////////////////////////////
void TsUpdateMessageHandle::SpacificHandle(Json::Value& value,TsSession* tsSession)
                if(m_updataInfo!= NULL){
                        m_updataInfo->OnUpdateInfo(value, tsSession);
        } else {
////////////////////////////////  TsMessageAnalyzer  ///////////////////////////////
//class TsRegister;
TsRegister testITR;
TsMessageAnalyzer::TsMessageAnalyzer()
        m_messageHandle = &TsRegistMessageHandle::GetInstance(&testITR);
        TsResultMessageHandle& resultHandle = TsResultMessageHandle::GetInstance();
        TsUpdateMessageHandle& updateHandle = TsUpdateMessageHandle::GetInstance(NULL);
        m_messageHandle->add(&resultHandle);
        m_messageHandle->add(&updateHandle);
TsMessageAnalyzer::~TsMessageAnalyzer()
TsMessageAnalyzer& TsMessageAnalyzer::GetInstance()
        static  TsMessageAnalyzer instance_;
        return instance_;
void  TsMessageAnalyzer::OnNewFrame(TsSession* tsServerSion,const string frame)
        Json::Value  value;
        if(tsServerSion == NULL){
                return;
        if(pJsonParser->parse(frame,value)){
                if((!value["type"].isNull()) &&  (value["type"].isString())){
                        m_messageHandle->SpacificHandle( value, tsServerSion);
                } else {
////////////////////////////////  AppMessageAnalyzer  //////////////////////////////
AppMessageAnalyzer::AppMessageAnalyzer()
        m_addTask = &AddDocTask::GetInstance();
        AddVideoTask &addVideoTask = AddVideoTask::GetInstance();
        AddDpptTask &addDpptTask = AddDpptTask::GetInstance();
        AddNoUseTsTask &addNoUseTsTask = AddNoUseTsTask::GetInstance();
        m_addTask->add(&addVideoTask);
        m_addTask->add(&addDpptTask);
        m_addTask->add(&addNoUseTsTask);
AppMessageAnalyzer::~AppMessageAnalyzer()
AppMessageAnalyzer& AppMessageAnalyzer::GetInstance()
        static  AppMessageAnalyzer instance_;
        return instance_;
void AppMessageAnalyzer::OnNewFrame(AppServerSession *appServerSion,string frame)
        Json::Value  value;
        if(appServerSion == NULL){
                return;
                if((!value["command"].isNull()) &&  (value["command"].isString())){
                        m_addTask->AddSpacificTask(value,appServerSion);
Task.h
#ifndef __TASK_H__
#define __TASK_H__
#include <string>
#include <list>
#include <vector>
class Command;
class TransServer;
class Disptacher;
class TsSession;
typedef enum
        TASK_HEAVY = 0,
        TASK_LIGHT = 1
}TaskProperty;
typedef struct
}ErrorInfo;
class Task
private:
protected:
        string m_taskId;
        bool m_isUseTs;
        unsigned int m_taskPriority;
        Json::Value m_cmdValue;
        Command* m_command;
        TransServer* m_transServer;
        Disptacher* m_disptacher;
        int m_progress;
public:
        vector<int> m_alreadyTriedTsType;
        vector<string> m_alreadyTriedTsId;
        int m_triedTimes;
        string m_appTargetIp;
        unsigned int m_appTargetPort;
        int m_maxTryTimes;
        TsSession* m_tsSession;
public:
        virtual ~Task(){}
        Task()
                m_command = NULL;
                m_transServer = NULL;
        void Init()
                m_triedTimes = 0;
        void Release()
                m_alreadyTriedTsType.clear();
                vector<int>(m_alreadyTriedTsType).swap(m_alreadyTriedTsType);
                m_alreadyTriedTsId.clear();
                vector<string>(m_alreadyTriedTsId).swap(m_alreadyTriedTsId);
        unsigned int GetPriority()
                return m_taskPriority;
        void SetDisptacher(Disptacher* disp)
                m_disptacher = disp;
        void SetProgress(int progress)
                m_progress = progress;
        int GetProgress()
                return m_progress;
        void SetPriority(unsigned int priority)
                m_taskPriority = priority;
        string GetTaskId()
                return m_taskId;
        void SetTaskId(string id)
                m_taskId = id;
        void SetCmdValue(Json::Value& value)
                m_cmdValue = value;
        Json::Value& GetCmdValue()
                return m_cmdValue;
        Command* GetCommand()
                return m_command;
        void SetCommand(Command* cmd)
                m_command = cmd;
        bool IsExceedMaxTryTimes()
                return (this->m_triedTimes >= this->m_maxTryTimes);
        void ResultReport(Json::Value& value);
class TaskDocument : public Task
public:
        TaskDocument();
        TaskDocument(string taskId,unsigned int priority){m_taskId = taskId;m_taskPriority = priority;}
        void SetIsSpecific(bool is){m_isSpecificTsType = is;}
        bool GetIsSpecific(){return m_isSpecificTsType;}
private:
        bool m_isSpecificTsType;
class TaskVideo : public Task
public:
        TaskVideo();
        TaskVideo(string taskId,unsigned int priority){m_taskId = taskId;m_taskPriority = priority;}
class TaskDppt : public Task
public:
        TaskDppt();
        TaskDppt(string taskId,unsigned int priority){m_taskId = taskId;m_taskPriority = priority;}
class TaskNoUseTs : public Task
public:
        TaskNoUseTs(){}
        TaskNoUseTs(string taskId,unsigned int priority){m_taskId = taskId;m_taskPriority = priority;}
class TaskCmp
public:
        bool operator()(Task* a,Task* b)
                if(a->GetPriority() < b->GetPriority())
                        return true;
                else if(a->GetPriority() == b->GetPriority())
                        return a > b;
                else
                        return false;
class TaskDb
public:
        virtual Task* GetTask() = 0;
        void GiveBackTask(Task *task)
                task->Release();
                m_taskBuf.push_back(task);
protected:
        list<Task*> m_taskBuf;
class TaskVideoDb : public TaskDb
public:
                if(!m_taskBuf.empty())
                        return m_taskBuf.front();
                else
                        return new TaskVideo;
class TaskDocumentDb : public TaskDb
public:
                else
                        return new TaskDocument;
class TaskDpptDb : public TaskDb
public:
                else
                        return new TaskDppt;
class TaskNoUseTsDb : public TaskDb
public:
                else
                        return new TaskNoUseTs;
#endif
keer_zu|  楼主 | 2016-6-8 11:42 | 只看该作者
Task.cpp
#include "Task.h"
/////////////////////////// Task /////////////////////////////
void Task::ResultReport(Json::Value& value)
        string result;
        Command* cmd;
        bool ret;
        cmd = this->GetCommand();
        ret = cmd->BuildAppResult(value,appResult);
        if(ret){
                result = appResult.toStyledString();
                SessionManager::GetInstance().SendAppMessage(this->m_appTargetIp,this->m_appTargetPort,result,this);
        } else {
///////////////////////// TaskDocument ///////////////////////
TaskDocument::TaskDocument()
        m_maxTryTimes = 3;
///////////////////////// TaskVideo ///////////////////////
TaskVideo::TaskVideo()
        m_maxTryTimes = 3;
///////////////////////// TaskDppt ///////////////////////
TaskDppt::TaskDppt()
        m_maxTryTimes = 3;
keer_zu|  楼主 | 2016-6-8 11:44 | 只看该作者
TaskQueue.h
#ifndef __TASK_QUEUE_H__
#define __TASK_QUEUE_H__
#include <queue>
#include <list>
#include "Task.h"
typedef priority_queue<Task*,vector<Task*>,TaskCmp> TaskPriorityQueue;
class TaskWaitQueue
public:
        Task* PopTask();
        Task* GetTaskInSpecId(string taskId);
        bool PushTask(Task *task);
        bool CheckSameTaskId(string TaskId);
private:
        TaskPriorityQueue m_queue;
class TaskRunQueue
public:
        bool PushTask(Task *task,TsSession *session);
        Task* GetTaskInSession(TsSession* session);
        bool DelTask(string taskId);
private:
        list<Task *> m_taskList;
#endif
TaskQueue.cpp
#include <vector>
#include <iostream>
Task* TaskWaitQueue::PopTask()
        Task* task;
        if(m_queue.empty())
                return NULL;
        task = m_queue.top( );
        m_queue.pop();
        return task;
Task* TaskWaitQueue::GetTaskInSpecId(string taskId)
        int i;
        vector<Task *> *vtor = (vector<Task *> *)&m_queue;
        for( int i = 0 ; i < vtor->size(); i++ ){
                if(((Task *)(vtor->operator [](i)))->GetTaskId() == taskId)
                        return (Task *)(vtor->operator [](i));
        return NULL;
bool TaskWaitQueue::PushTask(Task* task)
        task->m_tsSession = NULL;
         m_queue.push(task);
         return true;
bool TaskWaitQueue::CheckSameTaskId(string id)
        int i;
                if(((Task *)(vtor->operator [](i)))->GetTaskId() == id)
                        return true;
        return false;
////////////////////////// TaskRunQueue //////////////////////////////////
bool TaskRunQueue::PushTask(Task* task,TsSession* session)
        task->m_tsSession = session;
        m_taskList.push_back(task);
        return true;
Task* TaskRunQueue::GetTaskInSpecId(string taskId)
        list<Task *>::iterator it;
        for(it = m_taskList.begin();it != m_taskList.end();it ++){
                if((*it)->GetTaskId() == taskId){
                        return (Task *)(*it);
        return NULL;
Task* TaskRunQueue::GetTaskInSession(TsSession* session)
                if((*it)->m_tsSession == session){
        return NULL;
bool TaskRunQueue::DelTask(string taskId)
        bool ret = false;
                        (*it)->m_tsSession = NULL;
                        m_taskList.erase(it);
                        ret = true;
        return ret;
bool TaskRunQueue::CheckSameTaskId(string taskId)
        bool ret = false;
                        ret = true;
        return ret;
keer_zu|  楼主 | 2016-6-8 11:48 | 只看该作者
TaskResult.h
#ifndef __TASK_RESULT_H__
#define __TASK_RESULT_H__
#include <iostream>
#include <string>
#include <vector>
class CommandDb;
class TaskResult// : public ITaskResult
        TaskResult *next; // 1. "next" pointer in the base class
protected:
        vector<string> m_resultNames;
        TaskDb *m_taskDb;
public:
        TaskResult();
        bool IsThisTaskType(const string resultName)
                for (it = m_resultNames.begin(); it != m_resultNames.end(); ++ it){
                        if(resultName == *it)
                                return true;
                return false;
        void setNext(TaskResult *n)
                next = n;
        void add(TaskResult *n)
                if (next)
                        next->add(n);
                else
                        next = n;
        virtual void SpacificTaskResult(Json::Value& value,TsSession* tsServerSion)
                if(next != NULL)
                        next->SpacificTaskResult(value,tsServerSion);
                        printf("error");
                        // TODO: log
        void DoTaskRresult(Json::Value& value,TsSession* session)
                Task* task;
                string errorcode;
                task = m_taskRunQueue->GetTaskInSession(session);
                if(!task){
                        // TODO: log
                        return;
                errorcode = value["errorcode"].asString();
                if(atoi(errorcode.c_str()) != 0){
                        if(task->IsExceedMaxTryTimes()){
                                // TODO: log
                                task->ResultReport(value);
                                m_taskRunQueue->DelTask(task->GetTaskId());
                                m_taskDb->GiveBackTask(task);
                        } else {
                        return;
                return;
class VideoTaskResult : public TaskResult
        VideoTaskResult();
public:
        static VideoTaskResult& GetInstance();
        virtual void SpacificTaskResult(Json::Value& value,TsSession* tsServerSion);
class DocTaskResult : public TaskResult
        DocTaskResult();
public:
        static DocTaskResult& GetInstance();
class DpptTaskResult : public TaskResult
        DpptTaskResult();
public:
        static DpptTaskResult& GetInstance();
#endif
keer_zu|  楼主 | 2016-6-8 11:49 | 只看该作者
TaskResult.cpp
////////////////////////////////////// TaskResult /////////////////////////////////////////
TaskResult::TaskResult()
        next = NULL;
//////////////////////////////////// VideoTaskResult //////////////////////////////////////
VideoTaskResult& VideoTaskResult::GetInstance()
        static  VideoTaskResult instance_;
        return instance_;
VideoTaskResult::VideoTaskResult()
        m_commandDb->GetResultNameInSpecificTaskType(VideoTask,m_resultNames);
void VideoTaskResult::SpacificTaskResult(Json::Value& value,TsSession* session)
        if(IsThisTaskType(value["servertype"].asString())) {
                cout << "---  video result!" << endl;
                DoTaskRresult(value,session);
        } else {
                TaskResult::SpacificTaskResult(value,session);
//////////////////////////////////// DocTaskResult //////////////////////////////////////
DocTaskResult& DocTaskResult::GetInstance()
        static  DocTaskResult instance_;
        return instance_;
DocTaskResult::DocTaskResult()
        m_commandDb->GetResultNameInSpecificTaskType(DocTask,m_resultNames);
void DocTaskResult::SpacificTaskResult(Json::Value& value,TsSession* session)
        Task* task;
                cout << "---  Doc result!" << endl;
        } else {
//////////////////////////////////// DpptTaskResult //////////////////////////////////////
DpptTaskResult& DpptTaskResult::GetInstance()
        static  DpptTaskResult instance_;
        return instance_;
DpptTaskResult::DpptTaskResult()
        m_commandDb->GetResultNameInSpecificTaskType(DpptTask,m_resultNames);
void DpptTaskResult::SpacificTaskResult(Json::Value& value,TsSession* session)
        Task* task;
                cout << "---  Dppt result!" << endl;
        } else {
keer_zu|  楼主 | 2016-6-8 11:51 | 只看该作者
TransServer.h
#ifndef __TRANS_SERVER_H__
#define __TRANS_SERVER_H__
#include <string>
#include <list>
#include "Task.h"
class TsSession;
typedef enum{
        TsIdle = 0,
        TsRunning
}TsState;
typedef enum{
        DocTrans = 0,
        VideoTrans,
        DpptTrans
}ServerType;
typedef enum{
        OpenofficeDocTrans = 0,
        WpsDocTrans,
        OfficeDocTrans
}DocTransType;
class TransServer
public:
        virtual ~TransServer(){}
        TransServer(){m_tsState = TsIdle;}
        string GetId()
                return m_tsId;
        void SetId(string& id)
                m_tsId = id;
        ServerType GetServerType()
        TsState GetState()
                return m_tsState;
        void SetState(TsState state)
                m_tsState = state;
        void SetSession(TsSession* session)
                m_session = session;
        TsSession* GetSession()
                return m_session;
        void Release()
                m_task = NULL;
                m_session = NULL;
        void SetTask(Task* task)
                m_task = task;
        Task* GetTask()
                return m_task;
private:
        string m_tsId;
protected:
        TsSession* m_session;
        ServerType m_serverType;
        TsState m_tsState;
        Task* m_task;
class DocTransServer : public TransServer
public:
        DocTransServer(){}
        DocTransServer(string& id,DocTransType type)
                SetId(id);
                m_serverType = DocTrans;
                m_docTransType = type;
private:
        DocTransType m_docTransType;
class VideoTransServer : public TransServer
public:
        VideoTransServer(){}
        VideoTransServer(string& id)
                SetId(id);
                m_serverType = VideoTrans;
class DpptTransServer : public TransServer
public:
        DpptTransServer(){}
        DpptTransServer(string& id)
                SetId(id);
                m_serverType = DpptTrans;
class TransServerDb
public:
        virtual TransServer* GetTransServer() = 0;
        void GiveBackTransServer(TransServer *ts)
                ts->Release();
                m_transServerBuf.push_back(ts);
protected:
        list<TransServer*> m_transServerBuf;
class DocTransServerDb : public TransServerDb
        DocTransServerDb(){}
public:
        static DocTransServerDb& GetInstance()
                static DocTransServerDb instance_;
                return instance_;
                if(!m_transServerBuf.empty())
                        return m_transServerBuf.front();
                else
                        return new DocTransServer;
class VideoTransServerDb : public TransServerDb
        VideoTransServerDb(){}
public:
        static VideoTransServerDb& GetInstance()
                static VideoTransServerDb instance_;
                return instance_;
                else
                        return new VideoTransServer;
class DpptTransServerDb : public TransServerDb
        DpptTransServerDb(){}
public:
        static DpptTransServerDb& GetInstance()
                static DpptTransServerDb instance_;
                return instance_;
                else
                        return new DpptTransServer;
#endif
TransServer.cpp
#include "TransServer.h"
keer_zu|  楼主 | 2016-6-8 11:53 | 只看该作者
TsManager.h
#ifndef __TS_MANAGER_H__
#define __TS_MANAGER_H__
typedef enum
        TS_DOCUMENT_LINUX = 0,
        TS_DOCUMENT_OFFICE = 1,
        TS_DOCUMENT_WPS = 2,
        TS_VIDEO = 3,
        TS_DYNAMIC_PPT =4
} TsType;
typedef enum
        TS_HEAVY = 0,
        TS_LIGHT = 1
}TsProperty;
class AddTransServer;
class TsRegister : public ITsRegister
        AddTransServer *m_addTransServer;
public:
        TsRegister();
        virtual void OnRegister(Json::Value& value,TsSession *session);
        AddTransServer *next;
protected:
        TsQueue *m_tsQueue;
public:
        AddTransServer();
        void AddTsTransaction(Json::Value& value,TsSession*);
        void setNext(AddTransServer *n)
                next = n;
        void add(AddTransServer *n)
                if (next)
                        next->add(n);
                else
                        next = n;
        virtual void AddSpacificTransServer(Json::Value& value,TsSession*session)
                if(next != NULL)
                        next->AddSpacificTransServer(value,session);
                        printf("error");
                        // TODO: log
class AddDocTransServer : public AddTransServer
public:
        AddDocTransServer();
        //static AddDocTransServer& GetInstance();
        virtual void AddSpacificTransServer(Json::Value& value,TsSession*TsSession);
class AddOpenofficeTransServer : public AddDocTransServer
        AddOpenofficeTransServer();
public:
        static AddOpenofficeTransServer& GetInstance();
class AddWpsTransServer : public AddDocTransServer
        AddWpsTransServer();
public:
        static AddWpsTransServer& GetInstance();
class AddOfficeTransServer : public AddDocTransServer
        AddOfficeTransServer();
public:
        static AddOfficeTransServer& GetInstance();
class AddVideoTransServer : public AddTransServer
        AddVideoTransServer();
public:
        static AddVideoTransServer& GetInstance();
class AddDpptTransServer : public AddTransServer
        AddDpptTransServer();
public:
        static AddDpptTransServer& GetInstance();
class TsLeaveHandler;
class TransServerLeave : public ITsServerLeave
        TransServerLeave();
        TsLeaveHandler* m_tsLeaveHandler;
public:
        static TransServerLeave& GetInstance();
        virtual void OnServerLeave(TsSession &session);
        TsLeaveHandler* next;
protected:
        TsQueue* m_tsQueue;
        TransServerDb* m_tsDb;
public:
        TransServer* FindSession(TsSession* session);
        void setNext(TsLeaveHandler *n)
                next = n;
        void add(TsLeaveHandler *n)
                if (next)
                        next->add(n);
                else
                        next = n;
        virtual void SpacificTsLeave(TsSession* TsSession)
                if(next != NULL)
                        next->SpacificTsLeave(TsSession);
                        printf("error");
                        // TODO: log
        void ProcessTsAndTask(TransServer *ts)
                Task* task;
                m_tsQueue->DelTs(ts);
                ts->SetState(TsIdle);
                ts->SetSession(NULL);
                ts->Release();
                m_tsDb->GiveBackTransServer(ts);
                task = ts->GetTask();
class TsDocLeaveHandler : public TsLeaveHandler
public:
        TsDocLeaveHandler()
class TsOpenofficeLeaveHandler : public TsDocLeaveHandler
        TsOpenofficeLeaveHandler();
public:
        static TsOpenofficeLeaveHandler& GetInstance();
        virtual void SpacificTsLeave(TsSession* session);
class TsWpsLeaveHandler : public TsDocLeaveHandler
        TsWpsLeaveHandler();
public:
        static TsWpsLeaveHandler& GetInstance();
class TsOfficeLeaveHandler : public TsDocLeaveHandler
        TsOfficeLeaveHandler();
public:
        static TsOfficeLeaveHandler& GetInstance();
class TsVideoLeaveHandler : public TsLeaveHandler
        TsVideoLeaveHandler();
public:
        static TsVideoLeaveHandler& GetInstance();
class TsDpptLeaveHandler : public TsLeaveHandler
        TsDpptLeaveHandler();
public:
        static TsDpptLeaveHandler& GetInstance();
#endif
TsManager.cpp
/////////////////////// TsRegister ////////////////////
TsRegister::TsRegister()
        m_addTransServer = &AddOpenofficeTransServer::GetInstance();
        m_addTransServer->add(&AddWpsTransServer::GetInstance());
        m_addTransServer->add(&AddOfficeTransServer::GetInstance());
        m_addTransServer->add(&AddVideoTransServer::GetInstance());
        m_addTransServer->add(&AddDpptTransServer::GetInstance());
void TsRegister::OnRegister(Json::Value& value,TsSession *session)
        m_addTransServer->AddSpacificTransServer(value,session);
////////////////////// AddTransServer /////////////////////
AddTransServer::AddTransServer()
void AddTransServer::AddTsTransaction(Json::Value & value, TsSession* session)
        TsRegistMessage* regMessage;
        TsMessage* message;
        int errorCode;
        string errorDetail;
        string msg;
        message = TsMessageDb::GetInstance().GetMessage(TsRegistMsg,m_serverType);
        if(!message){
                // TODO:log
                return;
        if(regMessage = dynamic_cast<TsRegistMessage *>(message)){
        } else {
                // TODO:log
                return;
        if(m_tsQueue->CheckSameTs(value["id"].asString())){
                errorCode = 1;  // TODO:
                errorDetail = "Repeat ts id!";
                regMessage->BuildResponse(errorCode,errorDetail,msg);
        } else {
                TransServer* ts = VideoTransServerDb::GetInstance().GetTransServer();
                m_tsQueue->PushTs(ts);
                errorCode = 0;
                errorDetail = "";
///////////////////// AddDocTransServer //////////////////
AddDocTransServer::AddDocTransServer()
void AddDocTransServer::AddSpacificTransServer(Json::Value& value,TsSession*session)
///////////////////AddOpenofficeTransServer /////////////////
AddOpenofficeTransServer::AddOpenofficeTransServer()
        m_tsQueue = &GDocOfficeTsQueue;
        m_serverType = "DOC";
AddOpenofficeTransServer& AddOpenofficeTransServer::GetInstance()
        static  AddOpenofficeTransServer instance_;
        return instance_;
void AddOpenofficeTransServer::AddSpacificTransServer(Json::Value& value,TsSession*session)
        if(value["servertype"] == m_serverType){
                AddTsTransaction(value,session);
        } else {
                AddTransServer::AddSpacificTransServer(value,session);
///////////////////AddWpsTransServer /////////////////
AddWpsTransServer::AddWpsTransServer()
        m_tsQueue = &GDocWpsTsQueue;
        m_serverType = "DOC_WPS";
AddWpsTransServer& AddWpsTransServer::GetInstance()
        static  AddWpsTransServer instance_;
        return instance_;
void AddWpsTransServer::AddSpacificTransServer(Json::Value& value,TsSession*session)
        } else {
///////////////////AddOfficeTransServer /////////////////
AddOfficeTransServer::AddOfficeTransServer()
        m_serverType = "DOC_WINDOWS";
AddOfficeTransServer& AddOfficeTransServer::GetInstance()
        static  AddOfficeTransServer instance_;
        return instance_;
void AddOfficeTransServer::AddSpacificTransServer(Json::Value& value,TsSession*session)
        } else {
//////////////////// AddVideoTransServer ///////////////////
AddVideoTransServer::AddVideoTransServer()
        m_tsQueue = &GVideoTsQueue;
        m_serverType = "VIDEO";
AddVideoTransServer& AddVideoTransServer::GetInstance()
        static  AddVideoTransServer instance_;
        return instance_;
void AddVideoTransServer::AddSpacificTransServer(Json::Value& value,TsSession* session)
        if(value["servertype"].asString() == m_serverType){
        } else {
////////////////////// AddDpptTransServer //////////////////
AddDpptTransServer::AddDpptTransServer()
        m_tsQueue = &GDpptTsQueue;
        m_serverType = "DYNAMIC_PPT";
AddDpptTransServer& AddDpptTransServer::GetInstance()
        static  AddDpptTransServer instance_;
        return instance_;
void AddDpptTransServer::AddSpacificTransServer(Json::Value& value,TsSession*session)
        } else {
///////////////////// TsServerLeave  ////////////////////////////
TransServerLeave::TransServerLeave()
        m_tsLeaveHandler = &TsVideoLeaveHandler::GetInstance();
        m_tsLeaveHandler->add(&TsOpenofficeLeaveHandler::GetInstance());
        m_tsLeaveHandler->add(&TsOfficeLeaveHandler::GetInstance());
        m_tsLeaveHandler->add(&TsWpsLeaveHandler::GetInstance());
        m_tsLeaveHandler->add(&TsDpptLeaveHandler::GetInstance());
TransServerLeave& TransServerLeave::GetInstance()
        static  TransServerLeave instance_;
        return instance_;
void TransServerLeave::OnServerLeave(TsSession &session)
//////////////////////////////// TsLeaveHandler //////////////////////////////
TransServer* TsLeaveHandler::FindSession(TsSession* session)
        return m_tsQueue->GetTransServer(session);
////////////////////////// TsOpenofficeLeaveHandler ///////////////////////////
TsOpenofficeLeaveHandler::TsOpenofficeLeaveHandler()
        m_tsQueue = &GDocOpenofficeTsQueue;
        m_tsDb = &DocTransServerDb::GetInstance();
TsOpenofficeLeaveHandler& TsOpenofficeLeaveHandler::GetInstance()
        static TsOpenofficeLeaveHandler instance_;
        return instance_;
void TsOpenofficeLeaveHandler::SpacificTsLeave(TsSession* session)
        TransServer* ts;
        ts = FindSession(session);
        if(ts != NULL){
                ProcessTsAndTask(ts);
        } else {
                TsLeaveHandler::SpacificTsLeave(session);
////////////////////////// TsOfficeLeaveHandler ///////////////////////////
TsOfficeLeaveHandler::TsOfficeLeaveHandler()
TsOfficeLeaveHandler& TsOfficeLeaveHandler::GetInstance()
        static TsOfficeLeaveHandler instance_;
        return instance_;
void TsOfficeLeaveHandler::SpacificTsLeave(TsSession* session)
        TransServer* ts;
        if(ts = FindSession(session)){
        } else {
////////////////////////// TsWpsLeaveHandler ///////////////////////////
TsWpsLeaveHandler::TsWpsLeaveHandler()
TsWpsLeaveHandler& TsWpsLeaveHandler::GetInstance()
        static TsWpsLeaveHandler instance_;
        return instance_;
void TsWpsLeaveHandler::SpacificTsLeave(TsSession* session)
        TransServer* ts;
        } else {
/////////////////////////// TsVideoLeaveHandler //////////////////////////////
TsVideoLeaveHandler::TsVideoLeaveHandler()
        m_tsDb = &VideoTransServerDb::GetInstance();
TsVideoLeaveHandler& TsVideoLeaveHandler::GetInstance()
        static TsVideoLeaveHandler instance_;
        return instance_;
void TsVideoLeaveHandler::SpacificTsLeave(TsSession* session)
        TransServer* ts;
        } else {
/////////////////////////// TsDpptLeaveHandler ////////////////////////////////
TsDpptLeaveHandler::TsDpptLeaveHandler()
        m_tsDb = &DpptTransServerDb::GetInstance();
TsDpptLeaveHandler& TsDpptLeaveHandler::GetInstance()
        static TsDpptLeaveHandler instance_;
        return instance_;
void TsDpptLeaveHandler::SpacificTsLeave(TsSession* session)
        TransServer* ts;
        } else {
keer_zu|  楼主 | 2016-6-8 11:54 | 只看该作者
TsQueue.h
#ifndef __TS_QUEUE_H__
#define __TS_QUEUE_H__
#include <list>
class TsQueue
public:
        bool PushTs(TransServer* ts);
        TransServer* GetTsInSpecId(string tsId);
        bool DelTs(string tsId);
        bool DelTs(TransServer *ts);
        bool CheckSameTs(string tsId);
        TransServer* GetTsIdle();
        TransServer* GetTransServer(TsSession* session);
private:
        list<TransServer *> m_tsList;
#endif
发新帖 本帖赏金 10.00元(功能说明)我要提问
1466
