51armfpga https://bbsx.21ic.com/?923073 [收藏] [复制] [RSS]
日志
Android源码编译问题及解决办法汇总
已有 1514 次阅读2014-2-25 13:57 |个人分类:Android系统|系统分类:嵌入式系统| Android
开发环境:Ubuntu11.10
Android版本:2.2
错误一:
build/core/main.mk:73: You are attempting to build on a 32-bit system.
build/core/main.mk:74: Only 64-bit build environments are supported beyond froyo/2.2.
解决办法:
这是因为froyo/2.2默认只支持64-bit
需要进行如下修改即可,将
./external/clearsilver/cgi/Android.mk
./external/clearsilver/java-jni/Android.mk
./external/clearsilver/util/Android.mk
./external/clearsilver/cs/Android.mk
四个文件中的
LOCAL_CFLAGS += -m64
LOCAL_LDFLAGS += -m64
注释掉,或者将“64”换成“32
LOCAL_CFLAGS += -m32
LOCAL_LDFLAGS += -m32
然后,将
./build/core/main.mk 中的
ifneq (64,$(findstring 64,$(build_arch)))
改为:
ifneq (i686,$(findstring i686,$(build_arch)))
错误二:
/bin/bash: flex: command not found
解决办法:
apt-get install flex
错误三:
sh: gperf: not found
解决办法:
sudo apt-get install gperf
错误四:
external/clearsilver/cgi/cgi.c:22: fatal error: zlib.h: No such file or directory
解决办法:
sudo apt-get install zlib1g-dev
错误五:
frameworks/base/libs/utils/RefBase.cpp:483:67: error: passing const android::RefBase::weakref_implas thisargument of void android::RefBase::weakref_impl::trackMe(bool, bool)
解决办法:
编辑frameworks/base/libs/utils/Android.mk文件,修改
LOCAL_CFLAGS += -DLIBUTILS_NATIVE=1 $(TOOL_CFLAGS)
LOCAL_CFLAGS += -DLIBUTILS_NATIVE=1 $(TOOL_CFLAGS) fpermissive
错误六:
host C++: libutils <= frameworks/base/libs/utils/Asset.cpp
g++: error: fpermissive: No such file or directory
解决办法:
$ gedit frameworks/base/libs/utils/Android.mk
将下面一行
改成
注意:“-fpermissive”中的“-”为英文输入法中下的“-”,否则编译出错。
错误七:
prebuilt/linux-x86/sdl/include/SDL/SDL_syswm.h:55: fatal error: X11/Xlib.h: No such file or directory
解决办法:
apt-get install libx11-dev
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
