yidong1981的笔记 https://bbsx.21ic.com/?86463 [收藏] [复制] [RSS]
日志
ucos移植到了TI6414(1)!!!
已有 1473 次阅读2006-7-18 18:42
ucos_test.rar今天终于将ucos移植到了TI6414上了。
这里TI6414采用小端方式,6414的堆栈是从高地址往低地址方向的。
首先要声明一下,任务一定要是一下两种格式的一种:
void YourTask (void *pdata)
     for (;;) {
          /* 用户代码 */
         //调用μC/OS-Ⅱ的服务例程之一:
        OSMboxPend();
        OSQPend();
        OSSemPend();
        OSTaskDel(OS_PRIO_SELF);
        OSTaskSuspend(OS_PRIO_SELF);
        OSTimeDly();
        OSTimeDlyHMSM();
       /* 用户代码 */
      /* 用户代码 */
OS_CPU.H的移植:
*                                               uC/OS-II
*                                        The Real-Time Kernel
*                         (c) Copyright 1992-2002, Jean J. Labrosse, Weston, FL
*                                          All Rights Reserved
*                                     TI C6711 DSP Specific code
*                                          Little Endian Mode
*                                      Code Composer Studio V3.1
* File         : OS_CPU.H
#ifdef  OS_CPU_GLOBALS
#define OS_CPU_EXT
#else
#define OS_CPU_EXT  extern
#endif
*                                              DATA TYPES
*                                         (Compiler Specific)
typedef unsigned char  BOOLEAN;
typedef unsigned char  INT8U;                    /* Unsigned  8 bit quantity                           */
typedef signed   char  INT8S;                    /* Signed    8 bit quantity                           */
typedef unsigned short INT16U;                   /* Unsigned 16 bit quantity                           */
typedef signed   short INT16S;                   /* Signed   16 bit quantity                           */
typedef unsigned int   INT32U;                   /* Unsigned 32 bit quantity                           */
typedef signed   int   INT32S;                   /* Signed   32 bit quantity                           */
typedef float          FP32;                     /* Single precision floating point                    */
typedef double         FP64;                     /* Double precision floating point                    */
typedef unsigned int   OS_STK;                   /* Each stack entry is 32-bit wide in C6711DSP        */
#define BYTE           INT8S                     /* Define data types for backward compatibility ...   */
#define UBYTE          INT8U                     /* ... to uC/OS V1.xx.  Not actually needed for ...   */
#define WORD           INT16S                    /* ... uC/OS-II.                                      */
#define UWORD          INT16U
#define LONG           INT32S
#define ULONG          INT32U
*            Interrupter~!
*          With TI CCS Library of C6x DSP
extern cregister volatile unsigned int CSR ;
void Disable_int(void); //function for disable interrupt
void Enable_int(void); //function for enable interrupt
#define  OS_ENTER_CRITICAL()  Disable_int() //CSR &= 0xfffe;asm(" nop 4"); /* Disable interrupts*/
#define  OS_EXIT_CRITICAL()   Enable_int() //CSR |= 0x0001;asm(" nop 4"); /* Enable  interrupts*/
*                             TI C6414 DSP Miscellaneous
#define  OS_STK_GROWTH        1                       /* Stack grows from HIGH to LOW memory */
#define  OS_TASK_SW()         OSCtxSw()
/*$PAGE*/
*                        Some Definitions for operation of stack
typedef int REGISTERS;     /* Define the REGISTERS type - 32bit */
/ THE SP MUST BE ALIGNED ON AN 8-BYTE BOUNDARY.  (Ref. Datasheet of C6711 DSP )
/ WHICH means that the framesize has to be a multiple of 8-BYTE.
typedef struct
//The start address of the Task (point of the task function) -------- 4-BYTE
   void    (*Start_Address)(void *Task_Data_Pointer);
//All the General-Purpose Registers of the DSP (32 Registers) -------- 64 X 4-BYTE
   REGISTERS A0, A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, A14, A15;
   REGISTERS A16, A17, A18, A19, A20, A21, A22, A23, A24, A25, A26, A27, A28, A29, A30, A31;
   REGISTERS B0, B1, B2, B3, B4, B5, B6, B7, B8, B9, B10, B11, B12, B13, B14, B15;
   REGISTERS    B16, B17, B18, B19, B20, B21, B22, B23, B24, B25, B26, B27, B28, B29, B30, B31;
//Save all Control Registers of the DSP -------- 4 X 4-BYTE
   int
          AMR,  //Adressing_Mode_Register
          CSR,  //Control_Status_Register
          IER,  //Interrupt_Enable_Register
          IRP;  //Interrupt_Return_Pointer
//A 4-BYTE dummy, just keep the SP is aligned on an 8-BYTE boundary
   int   Dummy;
   } INIT_STACK_FRAME;
OS_CPU_A.ASM源程序:
 1、OSStartHighRdy():使就绪状态的任务开始运行的函数叫做OSStart()。在用户调用OSStart()之前,用户必须至少已经建立了自己的一个任务(
参看OSTaskCreate()和OSTaskCteateExt())。OSStartHighRdy()假设OSTCBHighRdy指向的是优先级最高的任务的任务控制块。OSStartHighRdy()就是使程序
跳入具有最高优先级的就绪任务的函数入口。
 2、OSCtxSw():任务切换函数,在有任务切换的时候调用这个函数。
 OSCtxSw原型----
 void OSCtxSw(void)
 保存处理器寄存器;
 将当前任务的堆栈指针保存到当前任务的OS_TCB中:
 OSTCBCur->OSTCBStkPtr = Stack pointer;
 调用用户定义的OSTaskSwHook();
 OSTCBCur = OSTCBHighRdy;
 OSPrioCur = OSPrioHighRdy;
 得到需要恢复的任务的堆栈指针:
 Stack pointer = OSTCBHighRdy->OSTCBStkPtr;
 将所有处理器寄存器从新任务的堆栈中恢复出来;
 执行中断返回指令;
 3、OSIntCtxSw():在中断服务程序中的任务切换;
 4、Disable_int()、Enable_int();
;                                               uC/OS-II
;                                         The Real-Time Kernel
;                          (c) Copyright 1992-2002, Jean J. Labrosse, Weston, FL
;                                          All Rights Reserved
;                                     TI C6414 DSP Specific code
;                                          Little Endian Mode
;                                      Code Composer Studio V3.1
; File         : OS_CPU_A.ASM
;                                    PUBLIC and EXTERNAL REFERENCES
FP .set A15
DP .set B14
SP .set B15
 .global $bss
_StartAddress .set 0+4 ;structrue of task/int stack
_A0  .set  4        +4
_A1  .set  8        +4
_A2  .set  12       +4
_A3  .set  16       +4
_A4  .set  20       +4
_A5  .set  24       +4
_A6  .set  28       +4
_A7  .set  32       +4
_A8  .set  36       +4
_A9  .set  40       +4
_A10 .set  44       +4
_A11 .set  48       +4
_A12 .set  52       +4
_A13 .set  56       +4
_A14 .set  60       +4
_A15 .set  64       +4
_A16  .set  68       +4
_A17  .set  72       +4
_A18  .set  76       +4
_A19  .set  80       +4
_A20  .set  84       +4
_A21  .set  88       +4
_A22  .set  92       +4
_A23  .set  96       +4
_A24  .set  100      +4
_A25  .set  104      +4
_A26 .set  108      +4
_A27 .set  112      +4
_A28 .set  116      +4
_A29 .set  120      +4
_A30 .set  124      +4
_A31 .set  128      +4
_B0  .set  132       +4
_B1  .set  136       +4
_B2  .set  140       +4
_B3  .set  144       +4
_B4  .set  148       +4
_B5  .set  152       +4
_B6  .set  156       +4
_B7  .set  160       +4
_B8  .set  164      +4
_B9  .set  168      +4
_B10 .set  172      +4
_B11 .set  176      +4
_B12 .set  180      +4
_B13 .set  184      +4
_B14 .set  188      +4
_B15 .set  192      +4
_B16  .set  196       +4
_B17  .set  200       +4
_B18  .set  204       +4
_B19  .set  208       +4
_B20  .set  212       +4
_B21  .set  216       +4
_B22  .set  220       +4
_B23  .set  224       +4
_B24  .set  228      +4
_B25  .set  232      +4
_B26 .set  236      +4
_B27 .set  240      +4
_B28 .set  244      +4
_B29 .set  248      +4
_B30 .set  252      +4
_B31 .set  256      +4
_AMR .set  260      +4
_CSR .set  264      +4
_IER .set  268      +4
_IRP .set  272      +4
_Framesize .set 276 +4
    .global _OSStartHighRdy
 .global _OSCtxSw
 .global _OSIntCtxSw
    .global _Disable_int ;
 .global _Enable_int ;
 .global _OSTaskSwHook  ; extern function & var from other objects
    .global _OSTCBHighRdy
 .global _OSTCBCur
 .global _OSPrioCur
 .global _OSPrioHighRdy
 .global _OSRunning
; /*$PAGE*/
;                                          START MULTITASKING
;                                       void OSStartHighRdy(void)
; Note : OSStartHighRdy() MUST:
;           a) Call OSTaskSwHook() then,
;           b) Set OSRunning to TRUE,
;           c) Switch to the highest priority task:获取该任务的堆栈指针;LDW registers;B B3;
_OSStartHighRdy:
 CALL _OSTaskSwHook
 NOP  3
 MVKL Back_Point,B3
 MVKH Back_Point,B3
Back_Point: ;return here from _OSTaskSwHook
 ;OSRunning = TRUE
 MVK 1,B1
     STB B1,*+DP(_OSRunning)
 ; StackPointer = OSTCBHighRdy->OSTCBStkPtr
 LDW *+DP(_OSTCBHighRdy),B4
     nop    4
     LDW    *B4,SP
     nop    4
     ;pop current task's context from stack
 LDW *+SP(_StartAddress),B3  ;  b3 start address
 LDW *+SP(_AMR),B10          ;   B10 = AMR
    LDW *+SP(_CSR),B9           ;   B9  = CSR
     LDW *+SP(_IER),B8           ;   B8  = IER
     mvk     0,B13
     mvc B13,IER
     LDW *+SP(_A0),A0  ;
     LDW *+SP(_A1),A1  ;
     LDW *+SP(_A2),A2  ;
     LDW *+SP(_A3),A3  ;
     LDW *+SP(_A4),A4  ;
     LDW *+SP(_A5),A5  ;
     LDW *+SP(_A6),A6  ;
     LDW *+SP(_A7),A7  ;
     LDW *+SP(_A8),A8  ;
     LDW *+SP(_A9),A9  ;
     LDW *+SP(_A10),A10 ;
    LDW *+SP(_A11),A11 ;
     LDW *+SP(_A12),A12 ;
     LDW *+SP(_A13),A13 ;
     LDW *+SP(_A14),A14 ;
     LDW *+SP(_A15),A15 ;
     LDW *+SP(_A16),A16  ;
     LDW *+SP(_A17),A17  ;
     LDW *+SP(_A18),A18  ;
     LDW *+SP(_A19),A19 ;
     LDW *+SP(_A20),A20  ;
     LDW *+SP(_A21),A21  ;
     LDW *+SP(_A22),A22  ;
     LDW *+SP(_A23),A23  ;
     LDW *+SP(_A24),A24  ;
     LDW *+SP(_A25),A25  ;
     LDW *+SP(_A26),A26 ;
     LDW *+SP(_A27),A27 ;
     LDW *+SP(_A28),A28 ;
     LDW *+SP(_A29),A29 ;
     LDW *+SP(_A30),A30 ;
     LDW *+SP(_A31),A31 ;
     LDW *+SP(_B0),B0  ;
     LDW *+SP(_B1),B1  ;
     LDW *+SP(_B2),B2  ;
     LDW *+SP(_B4),B4  ;
     LDW *+SP(_B5),B5  ;
     LDW *+SP(_B6),B6  ;
     LDW *+SP(_B7),B7  ;
        LDW *+SP(_B11),B11  ;
     LDW *+SP(_B12),B12  ;
     LDW *+SP(_B13),B13 ;
     LDW *+SP(_B14),B14  ;
        LDW *+SP(_B16),B16  ;
     LDW *+SP(_B17),B17  ;
     LDW *+SP(_B18),B18  ;
     LDW *+SP(_B19),B19  ;
     LDW *+SP(_B20),B20  ;
     LDW *+SP(_B21),B21  ;
     LDW *+SP(_B22),B22  ;
     LDW *+SP(_B23),B23  ;
     LDW *+SP(_B24),B24  ;
     LDW *+SP(_B25),B25 ;
     LDW *+SP(_B26),B26  ;
 LDW *+SP(_B27),B27  ;
     LDW *+SP(_B28),B28  ;
     LDW *+SP(_B29),B29 ;
     LDW *+SP(_B30),B30  ;
     LDW *+SP(_B31),B31  ;
 or 3,b9,B9 ; Set GIE
 mvc B9,CSR ; set csr if IRP did not put a GIE
 mvc B10,AMR ; Restore AMR
 LDW *+SP(_B9),B9  ;
 LDW *+SP(_B10),B10  ;
     LDW *+SP(_B3),B3  ;
 LDW *+SP(_B8),B8  ;
     LDW *+SP(_B15),B15  ;
     B b3             ;
 mvc B8,IER         ;
 nop     5
; /*$PAGE*/
;                                PERFORM A CONTEXT SWITCH (From task level)
;                                           void OSCtxSw(void)
; .align 32
_OSCtxSw:
    addk (-_Framesize),SP   ; Push one Frame
    STW        B3,*+SP(_StartAddress)  ;  b3 start address
    STW        B0,*+SP(_B0)  ;
||  mvc      AMR,B0
    STW        B0,*+SP(_AMR)  ;
||  mvc      CSR,B0
    STW        B0,*+SP(_CSR)  ;
||  mvc      IER,B0
    STW        B0,*+SP(_IER)  ;
||  mvc      IRP,B0
    STW        B0,*+SP(_IRP)  ;
    STW        A0,*+SP(_A0)  ;
||  MV      SP,A0                   ; A0 = SP
    STW        A1,*+SP(_A1)  ;
||  addk    (_Framesize),A0     ; Correct SP for POP of TCB
    STW        A0,*+SP(_B15) ;  Save correct SP
    STW        A2,*+SP(_A2)  ;
    STW        A3,*+SP(_A3)  ;
    STW        A4,*+SP(_A4)  ;
    STW        A5,*+SP(_A5)  ;
    STW        A6,*+SP(_A6)  ;
    STW        A7,*+SP(_A7)  ;
    STW        A8,*+SP(_A8)  ;
    STW        A9,*+SP(_A9)  ;
    STW        A10,*+SP(_A10) ;
    STW        A11,*+SP(_A11) ;
    STW        A12,*+SP(_A12)  ;
    STW        A13,*+SP(_A13)  ;
    STW        A14,*+SP(_A14)  ;
    STW        A15,*+SP(_A15)  ;
    STW        A16,*+SP(_A16)  ;
    STW        A17,*+SP(_A17)  ;
    STW        A18,*+SP(_A18)  ;
    STW        A19,*+SP(_A19)  ;
    STW        A20,*+SP(_A20)  ;
    STW        A21,*+SP(_A21)  ;
    STW        A22,*+SP(_A22)  ;
    STW        A23,*+SP(_A23)  ;
    STW        A24,*+SP(_A24) ;
    STW        A25,*+SP(_A25) ;
    STW        A26,*+SP(_A26)  ;
    STW        A27,*+SP(_A27)  ;
    STW        A28,*+SP(_A28)  ;
    STW        A29,*+SP(_A29)  ;
    STW        A30,*+SP(_A30)  ;
    STW        A31,*+SP(_A31)  ;
    LDW        *+DP(_OSTCBCur),B0     ; B0 = OSTCBCur
    STW        B1,*+SP(_B1)  ;
    STW        B2,*+SP(_B2)  ;
    STW        B3,*+SP(_B3)  ;  Save for cosmetical reasons
    STW        B4,*+SP(_B4)  ;
    STW        B5,*+SP(_B5)  ;
    STW        B6,*+SP(_B6)  ;
    STW        SP,*B0                  ; previous OSTCBCur->OSTCBStkPtr = SP ;
    STW        B7 ,*+SP(_B7 ) ;
    STW        B8 ,*+SP(_B8 ) ;
    STW        B9 ,*+SP(_B9 ) ;
    STW        B10,*+SP(_B10)  ;
    STW        B11,*+SP(_B11)  ;
    STW        B12,*+SP(_B12)  ;
    STW        B13,*+SP(_B13)  ;
    STW        B14,*+SP(_B14)  ;
    STW        B16 ,*+SP(_B16 ) ;
    STW        B17 ,*+SP(_B17 ) ;
    STW        B18 ,*+SP(_B18) ;
    STW        B19,*+SP(_B19)  ;
    STW        B20,*+SP(_B20)  ;
    STW        B21,*+SP(_B21)  ;
    STW        B22,*+SP(_B22)  ;
    STW        B23,*+SP(_B23)  ;
    STW        B24,*+SP(_B24)  ;
    STW        B25,*+SP(_B25)  ;
    STW        B26,*+SP(_B26)  ;
    STW        B27,*+SP(_B27)  ;
    STW        B28,*+SP(_B28)  ;
    STW        B29,*+SP(_B29)  ;
    STW        B30,*+SP(_B30)  ;
    STW        B31,*+SP(_B31)  ;
; /*$PAGE*/
OSIntCtxSw_Here_Start:   ; form here, the same with _OSIntCtxSw
 CALL _OSTaskSwHook   ; invoke the OSTaskSwHook function
 NOP  3
 MVKL Back_Point_2,B3
 MVKH Back_Point_2,B3
Back_Point_2: ; return here from _OSTaskSwHook
 ; OSTCBCur  = OSTCBHighRdy
 ; OSPrioCur = OSPrioHighRdy
    LDB  *+DP(_OSPrioHighRdy),B5
    NOP  3
    STW     B4,*+DP(_OSTCBCur)
    STB     B5,*+DP(_OSPrioCur)
    LDW        *B4,SP
    nop    4
 LDW  *+SP(_IRP),B11          ;   B10 = AMR
;    LDW  *+SP(_IER),B8           ;   B8  = IER
    mvc  IER,B8     ; do not change IER when switch tasks
    mvk     0,B13
    mvc  B13,IER
    LDW  *+SP(_A0),A0  ;
    LDW  *+SP(_A1),A1  ;
    LDW  *+SP(_A2),A2  ;
    LDW  *+SP(_A3),A3  ;
    LDW  *+SP(_A4),A4  ;
    LDW  *+SP(_A5),A5  ;
    LDW  *+SP(_A6),A6  ;
    LDW  *+SP(_A7),A7  ;
    LDW  *+SP(_A8),A8  ;
    LDW  *+SP(_A9),A9  ;
    LDW  *+SP(_B0),B0  ;
    LDW  *+SP(_B1),B1  ;
    LDW  *+SP(_B2),B2  ;
    LDW  *+SP(_B4),B4  ;
    LDW  *+SP(_B5),B5  ;
    LDW  *+SP(_B6),B6  ;
    LDW  *+SP(_B7),B7  ;
 mvc  B11,IRP   ; Restore AMR
 LDW  *+SP(_B9),B9  ;
    LDW  *+SP(_B3),B3  ;
 LDW  *+SP(_B8),B8  ;
    B   b3             ;
 mvc   B8,IER         ;
 nop       5
; /*$PAGE*/
;                                PERFORM A CONTEXT SWITCH (From an ISR)
;                                        void OSIntCtxSw(void)
; Note(s): 1) Upon entry,
;             OSTCBCur     points to the OS_TCB of the task to suspend
;             OSTCBHighRdy points to the OS_TCB of the task to resume
;          2) The stack frame of the task to suspend
;          3) The stack frame of the task to resume
_OSIntCtxSw:
 B  OSIntCtxSw_Here_Start
 NOP  5
; /*$PAGE*/
;* FUNCTION NAME: _Disable_int                                            *
;* Notes: function for disable interrupt                                    *
;.align 32
_Disable_int: ;
  mvc CSR,B4
  and 1,B4,B0
 [!B0] CLR B4,1,1,B4
 [B0] SET B4,1,1,B4
  CLR B4,0,0,B4
  mvc B4,CSR
  B  B3
  NOP 5
; /*$PAGE*/
;* FUNCTION NAME: _Enable_int:                                             *
;* Notes: function for enable interrupt                                     *
;.align 32
_Enable_int: ;
  mvc CSR,B4
  and 2,B4,B0
 [!B0] CLR B4,0,0,B4
 [B0] SET B4,0,0,B4
   mvc B4,CSR
  B  B3
  NOP 5
.end
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
