白沙的香烟盒 https://bbsx.21ic.com/?77381 [收藏] [复制] [RSS] MCU,ARM,程序,应用手记
日志
有关MSP430F2132之DCO校正参数丢失的麻烦
已有 1433 次阅读2013-3-13 14:46 |个人分类:随笔杂谈|系统分类:单片机
今日由于工作需要,经常背着笔记本,拿着仿真器以及BSL编程器来回奔波。
巧的是赶上了一款MSP430F2132 当采用BSL编程的时候,发现内部DCO校正参数
丢失,很麻烦。于是上网发现了以为朋友写的一个程序,借鉴过来添加到工程
里面,完全解决了DCO丢失的问题。特此感谢这位朋友!
另外也为了减少重量自己做了一个转接板,把JTAG+BSL统一到一个小板子上,
携带也方便多了,以后只需要带一个仿真器就可以了!
下面先给大家一个DCO的校正程序,然后是我自己画的小板子!
#include <msp430x21x2.h>
#define DELTA_1M 245
#define DELTA_8M 1954
#define DELTA_12M 2930
#define DELTA_16M 3906
char *pInfoFlash_A;
char AdjBCSCTL1_1M;
char AdjpDCOCTL_1M;
char AdjBCSCTL1_8M;
char AdjpDCOCTL_8M;
char AdjBCSCTL1_12M;
char AdjpDCOCTL_12M;
char AdjBCSCTL1_16M;
char AdjpDCOCTL_16M;
char tmpBCSCTL1;
char tmpDCOCTL;
void softwareDelay(unsigned int time)
    while(--time);
void timeAdelay(unsigned int time)
    TACTL = TASSEL_1 + MC_2 + TACLR;   // SMCLK, cont-mode, clear
    while(time)
         while(!(TACTL &TAIFG));
         TACTL &= ~TAIFG;
         time--;
    TACTL = 0;
void Set_DCO (unsigned int delta, char *pBcsctl1_, char *pDcoct_) // Set DCO to selected frequency
    unsigned int Compare, Oldcapture = 0;
    BCSCTL1 |= DIVA_3;                // ACLK= LFXT1CLK/8
    BCSCTL3 |= XCAP_3;
    CCTL2 = CM_1 + CCIS_1 + CAP;      // CAP, ACLK
    TACTL = TASSEL_2 + MC_2 + TACLR;  // SMCLK, cont-mode, clear
     while (1)
          while (!(CCIFG & CCTL2));        // Wait until capture occured
          CCTL2 &= ~CCIFG;                 // Capture occured, clear flag
          Compare = CCR2;                  // Get current captured SMCLK
          Compare = Compare - Oldcapture;  // SMCLK difference
          Oldcapture = CCR2;               // Save current captured SMCLK
          if (delta == Compare) break;     // If equal, leave "while(1)"
          else if (delta < Compare)        // DCO is too fast, slow it down
              DCOCTL--;
              if (DCOCTL == 0xFF)
                 if (!(BCSCTL1 == (XT2OFF + DIVA_3)))
                 BCSCTL1--;                       // Did DCO roll under?, Sel lower RSEL
         else
            DCOCTL++;
            if (DCOCTL == 0x00)
               if (!(BCSCTL1 == (XT2OFF + DIVA_3 + 0x0F)))
               BCSCTL1++;                     // Did DCO roll over? Sel higher RSEL
         softwareDelay(20);
     CCTL2 = 0;                        // Stop CCR2
     TACTL = 0;                        // Stop Timer_A
     *pBcsctl1_ = BCSCTL1 & (~DIVA_3);
     *pDcoct_ = DCOCTL;
void SetDcoConn(void)
     WDTCTL = WDTPW + WDTHOLD; // Stop WDT
     _DINT();
     tmpBCSCTL1 = BCSCTL1;
     tmpDCOCTL = DCOCTL;
     Set_DCO(DELTA_1M, &AdjBCSCTL1_1M, &AdjpDCOCTL_1M);
     Set_DCO(DELTA_8M, &AdjBCSCTL1_8M, &AdjpDCOCTL_8M);
     Set_DCO(DELTA_12M, &AdjBCSCTL1_12M, &AdjpDCOCTL_12M);
     Set_DCO(DELTA_16M, &AdjBCSCTL1_16M, &AdjpDCOCTL_16M);
     BCSCTL1 = tmpBCSCTL1;
     DCOCTL = tmpDCOCTL;
     FCTL2 = FWKEY + FSSEL0 + FN1; // MCLK/3 for Flash Timing Generator
     FCTL1 = FWKEY + ERASE;        // Set Erase bit, allow interrupts
     if(FCTL3 & LOCKA)
          FCTL3 = FWKEY + LOCKA;      // Clear LOCK & LOCKA bits
     pInfoFlash_A = (char *) 0x10C0; // Initialize Flash pointer
     *pInfoFlash_A = 0;              // Dummy write to erase Flash segment A
     FCTL1 = FWKEY + WRT;            // Set WRT bit for write operation
     pInfoFlash_A = (char *) CALDCO_16MHZ_; // Initialize Flash pointer
     *pInfoFlash_A++ = AdjpDCOCTL_16M;
     *pInfoFlash_A++ = AdjBCSCTL1_16M;
     *pInfoFlash_A++ = AdjpDCOCTL_12M;
     *pInfoFlash_A++ = AdjBCSCTL1_12M;
     *pInfoFlash_A++ = AdjpDCOCTL_8M;
     *pInfoFlash_A++ = AdjBCSCTL1_8M;
     *pInfoFlash_A++ = AdjpDCOCTL_1M;
     *pInfoFlash_A = AdjBCSCTL1_1M;
     FCTL1 = FWKEY;                   // Clear WRT bit
     FCTL3 = FWKEY + LOCKA + LOCK;    // Set LOCK & LOCKA bit // Set LOCK bit
协助软件:
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
