Cheribat的个人空间 https://bbsx.21ic.com/?707615 [收藏] [复制] [RSS]
日志
关于STM32F030的RTC电源问题
已有 2149 次阅读2014-12-2 15:49 |个人分类:技术支持|系统分类:ARM| STM32F0, RTC
Resolution Summary:
SOLUTION PROPOSED BY SUPPORTER - 1/12/2014  06:08:28 :
Dear XX,
It is true that STM32F030 RTC power supply is connect with VDD, do not have separate power, so if you connect battery to VDD, parts of digital circuit will use this battery power, and need to fine tune your code to get min power consumption to prolong the BAT energy.
Otherwise, use extern RTC chip, or change to another STM32 MCU with separate BAT supply.
Thanks for your inquiry.
Regards
Description:
在看datasheet时注意到,stm32f030没有VBAT引脚,这样的话,RTC时钟电源该如何提供?芯片的VDD是否是连通的?若将电池与1脚VDD相连,在主电断开后是否会由电池给整个芯片供电导致电池电量迅速耗尽?
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
