lxpkaka的笔记 https://bbsx.21ic.com/?565798 [收藏] [复制] [RSS]
日志
cpsr与cpsr_c的区别
已有 980 次阅读2011-5-4 05:43 |系统分类:ARM| cpsr
CPSR有4个8位区域:标志域(F)、状态域(S)、扩展域(X)、控制域(C)
MSR - Load specified fields of the CPSR or SPSR with an immediate constant, or from the contents of a general-purpose register.
Syntax:
MSR{cond} <psr>_<fields>, #immed_8r MSR{cond} <psr>_<fields>, Rm where: cond is an optional condition code. <psr> is either CPSR or SPSR. <fields> specifies the field or fields to be moved. <fields> can be one or more of:
c control field mask byte (PSR[7:0]) x extension field mask byte (PSR[15:8]) s status field mask byte (PSR[23:16) f flags field mask byte (PSR[31:24]). immed_8r is an expression evaluating to a numeric constant. The constant must correspond to an 8-bit pattern rotated by an even number of bits within a 32-bit word. Rm is the source register.
C 控制域屏蔽字节(psr[7:0])
X 扩展域屏蔽字节(psr[15:8])
S 状态域屏蔽字节(psr[23:16])
F 标志域屏蔽字节(psr[31:24])
常用于MRS或MSR指令,用于psr中的值转移到寄存器或把寄存器的内容加载到psr中.
如:
MSR CPSR_c,#0xd3
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
