IAP In-System Application Programming Demo
已有 1462 次阅读2006-11-22 10:41
|个人分类:arm|系统分类:ARM|
/* IAP In-System Application Programming Demo */
/* This file is part of the uVision/ARM development tools. */
/* Copyright (c) 2005-2006 Keil Software. All rights reserved. */
/* This software may only be used under the terms of a valid, current, */
/* end user licence from KEIL for a compatible version of KEIL software */
/* development tools. Nothing else gives you the right to use this software. */
#include <LPC21xx.H>
// Clock Frequency
#define XTAL 12000000 // Oscillator Frequency
#ifdef BYPASS_PLL
#define CPUCLK XTAL // CPU Clock without PLL
#else
#define CPUCLK (XTAL*5) // CPU Clock with PLL
#endif
#define CCLK (CPUCLK / 1000) // CPU Clock in kHz
// Phase Locked Loop (PLL) definitions
#define PLL_BASE 0xE01FC080 // PLL Base Address
#define PLLCON_OFS 0x00 // PLL Control Offset
#define PLLSTAT_OFS 0x08 // PLL Status Offset
#define PLLFEED_OFS 0x0C // PLL Feed Offset
#define PLLCON_PLLE 0x01 // PLL Enable
#define PLLCON_PLLD 0x00 // PLL Disable
#define PLLCON_PLLC 0x03 // PLL Connect
#define PLLSTAT_PLOCK 0x0400 // PLL Lock Status
struct iap_in {
unsigned int cmd;
unsigned int par[4];
typedef void (*IAP)(struct iap_in *in, unsigned int *result);
#define iap_entry ((IAP) 0x7FFFFFF1) // IAP Entry Point
/* Default Interrupt Function: may be called when interrupts are disabled */
void def_isr (void) __irq {
#ifdef BYPASS_PLL
* PLL Feed Sequence
void feed_pll (void) {
unsigned int adr, r1, r2;
adr = PLL_BASE;
__asm {
MOV r1, #0xAA
MOV r2, #0x55
STR r1, [adr, #PLLFEED_OFS]
STR r2, [adr, #PLLFEED_OFS]
* Switch CPU to PLL clock
void start_pll (void) {
PLLCON = PLLCON_PLLE;
feed_pll();
while ((PLLSTAT & PLLSTAT_PLOCK) == 0);
PLLCON = PLLCON_PLLC;
feed_pll();
* Switch CPU to standard XTAL
void stop_pll(void) {
PLLCON = PLLCON_PLLD;
feed_pll();
#endif
* Convert 'addr' to Sector Number
unsigned int get_secnum (unsigned int addr) {
unsigned int n;
n = ((unsigned int) addr >> 13) & 0x1F; // Pseudo Sector Number
if (n >= (0x30000 >> 13)) {
n -= 14; // High Small 8kB Sectors
else if (n >= (0x10000 >> 13)) {
n = 7 + (n >> 3); // Large 64kB Sectors
return (n); // Sector Number
* Erase Sector between 'start' and 'end'
* Return: IAP Error Code (0 when OK)
unsigned int erase (unsigned int start, unsigned int end) {
struct iap_in iap; // IAP Input Parameters
unsigned int result[16]; // IAP Results
unsigned int save_VicInt; // for saving VICIntEnable
save_VicInt = VICIntEnable; // Save Interrupt Enable Status
VICIntEnClr = 0xFFFFFFFF; // Disable all Interrupts
#ifdef BYPASS_PLL
stop_pll(); // IAP requires to run without PLL
#endif
iap.cmd = 50; // IAP Command: Prepare Sectors for Write
iap.par[0] = get_secnum (start); // Start Sector
iap.par[1] = get_secnum (end); // End Sector
iap_entry (&iap, result); // Call IAP Function
if (result[0]) goto exit; // Error occured?
iap.cmd = 52; // IAP Command: Erase Flash
iap.par[2] = CCLK; // CPU Clock
exit:
#ifdef BYPASS_PLL
start_pll(); // Start PLL
#endif
VICIntEnable = save_VicInt; // Restore Interrupt Enable Status
return (result[0]);
* Program *data to addr, number of bytes specified by size
* NOTES: size should be 512, 1024, 4096 or 8192
unsigned int program (unsigned int addr, unsigned char *data, unsigned int size) {
#ifdef BYPASS_PLL
#endif
iap.par[0] = get_secnum (addr); // Start Sector
iap.par[1] = iap.par[0]; // End Sector
iap.cmd = 51; // IAP Command: Copy RAM to Flash
iap.par[0] = addr; // Destination Address
iap.par[1] = (unsigned int) data; // Source Address
iap.par[2] = size; // Number of Bytes
iap.par[3] = CCLK; // CPU Clock
exit:
#ifdef BYPASS_PLL
#endif
return (result[0]);
unsigned char vals[512];
int main (void) {
unsigned int i;
unsigned int volatile start;
for (start = 0; start < 1000000; start++) {
; // wait for debugger connection (about 0.3 sec)
VICDefVectAddr = (unsigned int) def_isr; // for Spurious Interrupts
for (i = 0; i < sizeof (vals); i++) {
vals = (unsigned char) i;
erase (0x30000, 0x33FFF);
program (0x30000, vals, sizeof (vals));
program (0x31000, vals, sizeof (vals));
program (0x32000, vals, sizeof (vals));
erase (0x30000, 0x31FFF);
erase (0x32000, 0x33FFF);
while (1);
