gmy800101的笔记 https://bbsx.21ic.com/?392771 [收藏] [复制] [RSS]
日志
新鲜出炉的蓝牙模块调试流程之AT指令
已有 2298 次阅读2009-11-5 09:09 |系统分类:通信网络
就是怎么操作,流程,刚学的,特总结如下,对没有调试过BT,无从下手的新手们提供点素材。我也是现学现卖,原来没碰过,突然让调,就一头雾水,幸亏是个模块,只用AT指令就能搞定。
AT command deion
AT+BTIN  查找BT
AT+BTK=”8888” is the pair code 配对密码
ATS102?
ATS102=$0180   will allow A2DP and AVRCP   禁止SPP,使能A2DP AVRCP
AT+BTC?
001F00
AT+BTN?
“LAIRD BTMMP 000151”
AT&F0 设置UART波特率
ATS512=4  连接并查找
ATS0=1  自动应答
ATZ  硬件复位
AT+BTN  读模块的名字
PIN
AT+BTT
0005C9000000 读对方BT的地址
ATI4
0016A4000161 读自己的BT地址
AT+APD 0005C9000000 to control your phone A2DP
CONNECT 0005C9000000,110D
AT+AVD 0005C9000000 to control your phone  AVRCP
CONNECT 0005C9000000,110E
AT+AVC44    play
AT+AVC45    stop
AT+AVC46    pause
AT+AVC4B    last song
AT+AVC4C    next song
AT+BTN=”GMY”  设置缺省连接name
ATI4    BT设备地址
Phone ->A2DP -> module #1 -> Speaker(J7)
Flow:
at&F* reset all setting on the module
atz will reboot the module
ats102=$0180 allows A2DP, and AVRCP
at+btk="8888" - is the pair code
aT+BTT will save the pairing setting
ATI4?
0016A4000161
At+btt?
0005C9000000
AT+APD0005C9000000     A2DP connect your phone
AT+AVD0005C9000000    AVRCPremote control
AT+AVC44    play
AT+AVC45    stop
AT+AVC46    pause
AT+AVC4B    last song
AT+AVC4C    next song
Audio in(J4) -> module #2 ----- A2DP -> module #1 -> Speaker(J7)
Flow:
Source, audio in:
AT
AT&F*
ATZ
ATS300=2     source
ATS102=$0180
ATS301=2   as AVRCP target
ATS512=4
AT&W
ATZ
ATI4
0016A4000151
Sink speaker:
AT+APD0016A4000151
AT+AVD0016A4000151  there is one bug on the firmware, so ACRVP might not work
Another example:
Flow:
Source, audio in:
ATI3
AT&F*
ATZ
ATS300=2
ATS301=2
AT+BTK=”8888”
ATS512=4
AT&W
ATZ
AT+BTP
ATI4
0016A4000025
Sink speaker:
AT+APD0016A4000025
AT+AVD0016A4000025
AT+AVC44   play the song
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
