DSP的SCI的使用-FIFO
已有 1694 次阅读2015-6-18 11:04
|系统分类:兴趣爱好
以下是对TI官方例程的SCI的理解:
void main(void) {
Uint16 SendChar; //定义为要发送的变量
// Step 1. Initialize System Control:
// PLL, WatchDog, enable Peripheral Clocks
// This example function is found in the DSP2833x_SysCtrl.c file.
InitSysCtrl(); //系统时钟初始化
// Step 2. Initialize GPIO:
// This example function is found in the DSP2833x_Gpio.c file and
// illustrates how to set the GPIO to it's default state.
// InitGpio(); Skipped for this example
// For this example, only init the pins for the SCI-A port.
// This function is found in the DSP2833x_Sci.c file.
InitScibGpio(); //对SCIB的GPIO进行初始化,SCIB的GPIO口对应MUX,GPIO18和GPIO19进行配置
// Step 3. Clear all interrupts and initialize PIE vector table:
// Disable CPU interrupts
DINT; //关闭CPU各中断
// Initialize PIE control registers to their default state.
// The default state is all PIE interrupts disabled and flags
// are cleared.
// This function is found in the DSP2833x_PieCtrl.c file.
InitPieCtrl(); //PIE中断级初始化
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000; //清除各种中断标志
// Initialize the PIE vector table with pointers to the shell Interrupt
// Service Routines (ISR).
// This will populate the entire table, even if the interrupt
// is not used in this example. This is useful for debug purposes.
// The shell ISR routines are found in DSP2833x_DefaultIsr.c.
// This function is found in DSP2833x_PieVect.c.
InitPieVectTable(); //中断舍量表初始化
// Step 4. Initialize all the Device Peripherals:
// This function is found in DSP2833x_InitPeripherals.c
// InitPeripherals(); // Not required for this example
// Step 5. User specific code:
LoopCount = 0;
ErrorCount = 0;
Scib_fifo_init(); // 初始化SCI FIFO
Scib_echoback_init();
for (;;) {
#if SCIB //如果SCIB=1则执行如下语句
while (ScibRegs.SCIFFRX.bit.RXFFST == 0); // SCIFFRX寄存器,8~12位为RXFFST,RXFFST=00000,接收FIFO为空,00001接收FIFO有一个字,以此类
//推; 等待有数据的时候开始往下执行
SendChar = ScibRegs.SCIRXBUF.all; //有数据过来,总线上接收到的数据传送到SendChar中,
Scib_xmit(SendChar); //接着通过Scib_xmit函数送出接收到的数据
while (ScibRegs.SCIFFTX.bit.TXFFST != 0) ;//判断传送是否完成,等待传送完成
#elif SCIC
while(ScicRegs.SCIFFRX.bit.RXFFST == 0); // wait for RRDY/RXFFST =1 for 1 data available in FIFO
SendChar = ScicRegs.SCIRXBUF.all;
Scic_xmit(SendChar);
while(ScicRegs.SCIFFTX.bit.TXFFST != 0);
#elif SCIA
while(SciaRegs.SCIFFRX.bit.RXFFST == 0); // wait for RRDY/RXFFST =1 for 1 data available in FIFO
SendChar = SciaRegs.SCIRXBUF.all;
Scia_xmit(SendChar);
while(SciaRegs.SCIFFTX.bit.TXFFST != 0);
#endif
// Test 1,Scib DLB, 8-bit word, baud rate 0x000F, default, 1 STOP bit, no parity //8位字,波特率9600,默认设置,1个停止位,没有奇偶校验位
void Scib_echoback_init() {
// Note: Clocks were turned on to the Scib peripheral
// in the InitSysCtrl() function
ScibRegs.SCICCR.all = 0x0007; // 1 stop bit, No loopback
// No parity,8 char bits,
// async mode, idle-line protocol
ScibRegs.SCICTL1.all = 0x0003; // enable TX, RX, internal SCICLK,
// Disable RX ERR, SLEEP, TXWAKE
ScibRegs.SCICTL2.all = 0x0003;
ScibRegs.SCICTL2.bit.TXINTENA = 1;
ScibRegs.SCICTL2.bit.RXBKINTENA = 1;
#if (CPU_FRQ_150MHZ) //选择性的,当频率为150Mhz,选择如下的方式
ScibRegs.SCIHBAUD = 0x0001; // 9600 baud @LSPCLK = 37.5MHz.
ScibRegs.SCILBAUD = 0x00E7;
#endif
#if (CPU_FRQ_100MHZ)
ScibRegs.SCIHBAUD =0x0001; // 9600 baud @LSPCLK = 20MHz.
ScibRegs.SCILBAUD =0x0044;
#endif
ScibRegs.SCICTL1.all = 0x0023; // Relinquish SCI from Reset
// Transmit a character from the SCI
void Scib_xmit(int a) {
ScibRegs.SCITXBUF = a;
// Initialize the SCI FIFO
void Scib_fifo_init() {
ScibRegs.SCIFFTX.all = 0xE040;
ScibRegs.SCIFFRX.all = 0x204f;
ScibRegs.SCIFFCT.all = 0x0;
所谓的FIFO就是先进先出的意思。SCI工作在FIFO模式下一般是因为所传输的信息并不是以一个帧为单位,而是以多个帧组成的一个包为信息单位的。
比如说我的一个数据包由5个帧组成,第一个为控制字节,后四个字节共同组成一个浮点数。这时你可以设置FIFO接收中断为5个字节时产生中断。
设置以后,每接收到5个字节后才会产生一次中断,而不是每接收一次产生一次中断。这样可以大幅减小CPU的开销。而先进先出的意思就是:在中断中,
你读FIFO接收寄存器读到的数据是首先接收到的数据,再读一次的话读到的是接收到的第二个数据。而16深度的话就是最多能保存最近的16个接收数据,
如果接收数据超过16个的话会产生相应的溢出,可以软件编程对溢出进行处理。
FIFO主要是可以将需要接收或者发送的数据进行打包处理,可以设置一次要接收或者发送的数据的多少,最多16个;普通模式下,一般没接收或者发送
一个字节就需要进行判断,进入中断执行中断程序,所以通过FIFO功能可以大幅的减少CPU的使用,提高效率。(个人理解)
