山东电子小菜鸟的个人空间 https://bbsx.21ic.com/?1197168 [收藏] [复制] [RSS]
日志
stm8-spi-lis3dh
已有 1652 次阅读2017-8-23 23:21 |个人分类:stm8|系统分类:单片机
/* Includes ------------------------------------------------------------------*/
#include "math.h"
#include "stm8s.h"
#include "sysclock.h"
#include "uart1.h"
#include "spi_flash.h"
#include "lis3dh_driver.h"
#include "led.h"
/* Private macro -------------------------------------------------------------*/
#define  acchold    2000
/*void Init_Timer4(void)
        TIM4_TimeBaseInit(TIM4_PRESCALER_128, 0XFF);
  TIM4_ClearFlag(TIM4_FLAG_UPDATE);
        TIM4_ITConfig(TIM4_IT_UPDATE, ENABLE);
        TIM4_Cmd(ENABLE);
/* Private variables ---------------------------------------------------------*/
/* Private defines -----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void lis3dhinit(void)
  //u8 response=0;
//response =
LIS3DH_SetODR(LIS3DH_ODR_10Hz);
//printf("设置 ODR:%d\r\n",response);
//response =
LIS3DH_SetMode(LIS3DH_NORMAL);
//printf("设置 MODE:%d\r\n",response);
//response =
LIS3DH_SetFullScale(LIS3DH_FULLSCALE_2);
//printf("设置 SCALE:%d\r\n",response);
//response =
LIS3DH_SetAxis(LIS3DH_X_ENABLE| LIS3DH_Y_ENABLE | LIS3DH_Z_ENABLE);
//printf("设置 ENABLE:%d\r\n",response);
LIS3DH_SetTemperature(MEMS_ENABLE);
void Delay(u32 nCount);
void main(void)
  AxesRaw_t data;
 // u16 num;
  u8 lisid;
 // i16_t temp[2]={0};
  i16_t old_xdata=0;
  unsigned int minute_xdata=0;
    CLK_HSICmd(ENABLE);//开始内部高频RC
    CLK_HSIPrescalerConfig(CLK_PRESCALER_HSIDIV8);//8分频 2M
        /*设置外部24M晶振为主时钟*/
        //SystemClock_Init(HSE_Clock);
        //        SPI_FLASH_Init();        /* SPI初始化*/
        Uart1_Init();
   // Init_Timer4();
        //enableInterrupts();
         //lis3dhinit();
        LED_Init();
     //  LIS3DH_GetWHO_AM_I(&lisid);
      // printf("传感器ID:%x\r\n",lisid);
    while (1)
         // printf("传感器ID:%x\r\n",0X01);
        static u8 statis=0;
         statis++;
         if(statis==200)
           statis=0;
         if(statis%30==0)
                  lis3dhinit();
                 // statis=
            // statis=
               LIS3DH_GetAccAxesRaw(&data);
               if((unsigned int)(data.AXIS_X)>(unsigned int)(old_xdata)){minute_xdata=data.AXIS_X-old_xdata;}
               else{minute_xdata=old_xdata-data.AXIS_X;}
               old_xdata=data.AXIS_X;
             printf("LIS3DH_GetAccAxesRaw(&data):%d\r\n",minute_xdata);
           // printf("x=%8d,y=%8d,z=%8d\r\n",(int)(data.AXIS_X),data.AXIS_Y,data.AXIS_Z);
       /*if((statis%10)==0)
        {  static u8 num=0;
          num++;
          if(num==1)
          LED_Operation(LED_1,ON);
          if(num==1+minute_xdata%200){
            LED_Operation(LED_1,OFF); num=0;}
       // if((statis%25)==0)  LED_Operation(LED_1,OFF);;
     //LIS3DH_SetTemperature(MEMS_ENABLE);
          //LIS3DH_GetTempRaw(&temp[0]);{
  //printf("传感温度:%8x",temp[0]);
      Delay(650) ;
// Delay(650) ;
  /* Decrement nCount value */
  while (nCount != 0)
    nCount--;
#ifdef USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
